05-25-2014, 08:26 | #92 (permalink) |
Junior Member Join Date: Jan 2009
Member: 943222 Status: Offline Sonork: cc Thanks Meter: 0 | hi my box after update box not activated pls help me Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : E6BADB2D92C3C941E664E9AA Box Status : NOT ACTIVATED |
05-25-2014, 11:00 | #95 (permalink) |
Crazy Poster Join Date: Jan 2009 Location: morocco Fes City Age: 51
Member: 951371 Status: Offline Sonork: 100.1591411 Thanks Meter: 50 | hi i have same problem after update my box is disabled here log from my box ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : ED8AB57ED96CA35CBE798102 Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Fill in the Required Information 5. Click "Activate Box" button ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Report Post Reply With Quote |
05-25-2014, 12:39 | #96 (permalink) | |
Junior Member Join Date: Oct 2011 Location: ᘱ
Member: 1680128 Status: Offline Thanks Meter: 11 | Quote:
05-26-2014, 05:26 | #98 (permalink) |
Junior Member Join Date: May 2014 Location: indonesia
Member: 2192656 Status: Offline Thanks Meter: 0 | help Activation Problem after latest Update and firmware CONTACT ATF PRODUCT SUPPORTER ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software |
05-26-2014, 07:52 | #99 (permalink) |
Junior Member Join Date: Apr 2012 Location: TIRUR KERALA
Member: 1752853 Status: Offline Sonork: 100.1615684 Thanks Meter: 3 | activation problem Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.20 AdvanceBox SN : E1D09E40AF448245DEDCCE34 Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Fill in the Required Information 5. Click "Activate Box" button ================================================ Box Successfully Initialized ================================================ Your Box Distributor/Reseller has requested that your Box should be Disabled. Please Contact your Box Distributor/Reseller and settle the Problem. If you think you are getting this Message by Mistake, please visit ATF |
05-26-2014, 08:08 | #100 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: Satcom Bangalore INDIA Age: 53
Member: 17098 Status: Offline Thanks Meter: 51 | Thanks Support Team My Box Activated. Quote:
Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : BCAC4D1CE88BE913EBB88262 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done B.R Saro | |
05-26-2014, 14:05 | #101 (permalink) |
Junior Member Join Date: May 2004 Location: egypt Age: 40
Member: 65833 Status: Offline Thanks Meter: 0 | ============================= Advance Turbo Flasher Found ================================================ Driver Version : 00020416 Library Version : 00030118 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.00 AdvanceBox SN : 9E9E48AEF9E22DDCAABA0612 Box Status : NOT ACTIVATED |
05-27-2014, 02:26 | #103 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1515005 Status: Offline Sonork: pk-afzal-gsm Thanks Meter: 4 | Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : 854CEC60AD375483AAE4F113 Box Status : NOT ACTIVATED |
05-27-2014, 08:03 | #104 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
05-28-2014, 06:01 | #105 (permalink) | |
Br - srinibas | |
