04-01-2013, 13:37 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: fatehabad Age: 41
Member: 570022 Status: Offline Thanks Meter: 67 | Advance- box i do rest eprom but restart computer than show this error your box has no serial number then not found hardware then this error show Unabla to read your box sn..... |
04-01-2013, 14:43 | #10 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Pakistan
Member: 1771086 Status: Offline Thanks Meter: 2,410 | I AM NEW TO ATF .LAST WEEK I BOUGHT A ATF BOX. IT IS ALREADY ACTIVATED I INSTALLED ATF7.60 AFTER INSTALL NEW ATF DRIVERS BUT ONLY BLUE LIGHT IS FLASHING WHEN I OPEN THE SOFT THIS DETAILS COME ============================================== ATF Box is not in USB 2.0 Mode ============================================== * Go to Product Support tab and click the * Restore Box Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers* Reboot PC* Reinstall **** If you are still Stuck... 1. Search your entire PC for ftdibus.sys 2. Delete all ftdibus.sys files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:AdvanceBox Turbo FlasherDriverRemove_ATF_DriversRemove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ****************************************** INIT : FAILED * CHECK YOUR BOX FIRMWARE ****************************************** AFTER I TRY TO RESTORE THE THE BOX AT THE END BOX ERROR I TRY TO UPDATE QUERY RESULT- NOT FOUND |
