03-12-2010, 14:46 | #62 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: INDONESIA Age: 38
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | Quote:
already try it before start posting here, still same problem facing with latest version, what driver version that must be corectly installed with CDM20600 ? this red mark, can be a problem? br, kevin168 | |
03-12-2010, 15:19 | #63 (permalink) |
Product Supporter Join Date: Sep 2004 Location: PHILIPPINES Age: 46
Member: 81952 Status: Offline Sonork: 1597268 Thanks Meter: 2,364 | hi! catch me @sonork 1588069 btw, you can clean your ftdi drivers. C:\Program Files\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers br, |
03-15-2010, 11:10 | #66 (permalink) | |
already make clean install on computer, and same problem still occured. br, kevin168 | |
03-18-2010, 06:42 | #67 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Back to GSM from AV
Member: 325999 Status: Offline Thanks Meter: 113 | How to activate ,there is no my reseller (GSMSOLUTION,india) in new update ? one more thing for auto backup need two diffrant option tick rpl,pm couse in dead or hang set pm backup is not possible but we need rpl backup. REGARDS |
03-18-2010, 07:51 | #69 (permalink) |
No Life Poster Join Date: Apr 2006 Location: I.N.D.I.A
Member: 256247 Status: Offline Thanks Meter: 444 | Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : B5461C1B9CD3C90D960E0EEF BOX Status : ACTIVATED INIT : OK AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : B5461C1B9CD3C90D960E0EEF BOX Status : ACTIVATED INIT : OK ImageFile:\Program Files\Nokia\Phoenix\Products\RM-51\RM51PE405262.C1 PhoneType : WD2 BT2 Algorithm : WD2 ALGORITHM Supported Hardwares : > 0082 > 1081 Secondary Sending Speed : 100000Hz Algorithm Sending Speed : 333000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 51000Hz Number of Blocks : 0 Entry Point: 0x00E2 Flashing FAILED... Flashing ERROR Time Elapse : 00:00:00 ok perfect mobile totaly done with hwk uni mx key |
03-18-2010, 07:55 | #70 (permalink) |
Member: 256247 Status: Offline Thanks Meter: 444 | AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : B5461C1B9CD3C90D960E0EEF BOX Status : ACTIVATED INIT : OK Processing Image File : D:\Program Files\Nokia\Phoenix\Products\RM-133\N73_4.0850.43.0.1_western_C00_PRD_cc.fpsx CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101003000 > 010C192101003000 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP1710 UNISTORE-II-1.2.1 ALG APE Supported Hardwares : > 17100708 Number of Blocks : 1732 Entry Point: 0x1B5C6 Page Format : -1 MAX PAGE : 0x00008000 Processing Image File : D:\Program Files\Nokia\Phoenix\Products\RM-133\N73_rofx_4.0850.43.0.1_PRD.V77 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0000000000000000 > 0003192101002000 > 000C192101002000 > 0003192101002100 > 000C192101002100 > 0003192101002200 > 000C192101002200 > 0103192101003000 > 010C192101003000 > 0103192101013000 > 010C192101013000 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 100000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP1710 UNISTORE-II-1.2.1 ALG APE Supported Hardwares : > 17100700 > 17100701 > 17100702 > 17100708 Number of Blocks : 2184 Entry Point: 0x0172 Page Format : -1 MAX PAGE : 0x00002000 Processing Image File : D:\Program Files\Nokia\Phoenix\Products\RM-133\N73_userarea_4.0850.43.0.1.U03 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0000000000000000 > 0003192101002000 > 000C192101002000 > 0003192101002100 > 000C192101002100 > 0003192101002200 > 000C192101002200 > 0103192101003000 > 010C192101003000 > 0103192101013000 > 010C192101013000 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 100000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP1710 UNISTORE-II-1.2.1 ALG APE Supported Hardwares : > 17100708 Number of Blocks : 164 Entry Point: 0x011B Page Format : -1 MAX PAGE : 0x00008000 AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : B5461C1B9CD3C90D960E0EEF BOX Status : ACTIVATED INIT : OK BootFlashModeDCT5Ex Failed Operations Failed.... ok mobile done with hwk |
03-18-2010, 08:26 | #71 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | @irfanboss In between the 2 RJ-45 sockets, there are 3 LEDS BLUE = USB Power GREEN = VBATT Power ORANGE = VPP Power When you run AdvanceBox.exe, you must see BLUE and GREEN turn on. When you click BUSCheck, you should see GREEN turn OFF for 1.5 seconds, then turn ON again. ORANGE will only turn ON during flashing, if you selected EXTERNAL VPP option. Check the GREEN LED if it is working the way that I described it. B.R. |
The Following User Says Thank You to X-Shadow For This Useful Post: |
03-23-2010, 14:38 | #73 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | i got massive error with init ATF box, logs attached below, u will see really hard to get this box working. already do. reprogram ftdi. update box, re-install driver, re-install OS. nothing solved my problem. br, kevin168 |
ATF v12.70 Update!! 31 MAR 2017!! | gsmfun | Advance-Box | 79 | 03-31-2017 15:31 |
ATF [Advance Turbo Flasher] version v2010.0.1.21 discussion thread | gsmfun | Advance-Box | 32 | 07-24-2010 19:09 |
ATF [Advance Turbo Flasher] Version 4.50 update[old thread] | Javajohn | Advance-Box | 27 | 03-21-2010 21:43 |
Advance Turbo Flasher Beta Version 4.0 | Javajohn | Service Products News & Updates | 0 | 03-03-2010 16:55 |
Advance Box > Advance Turbo Flasher===BETA Software Download Area== | FullFLASHgSMPH | Service Products News & Updates | 0 | 02-17-2010 07:46 |
