Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 02-18-2012, 11:55   #1 (permalink)
Member: 545722
Sonork: 100.1619680
after flash only vibratsa nokia c5
after flash only vibratsa nokia c5 maybe it is hadware problem or
here log
ATF Software Version v8.10
ATF Box FBUS Flash Started...
Number of Image Files: 3
Basic Phone Information
WARNING:
Simlock Backup Failed
If this is a Dead Phone, just click YES
to Continue with the Flash Procedure...
Changing MODE : FLASH
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
AdvanceBox SendBootCodeEx
Initialise*****trap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000003
ID DWORD 1 : 00000226
ID DWORD 2 : 00010007
ID DWORD 3 : 600C1921
ID DWORD 4 : 02031104
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000C35
3 EM_ASIC_ID 02
ID DWORD 0 : 00000C30
4 PUBLIC_ID 12
ID DWORD 0 : 24D00112
ID DWORD 1 : CDA40344
ID DWORD 2 : E7DBC9A2
ID DWORD 3 : CC33FF72
ID DWORD 4 : 50747941
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : E693EF0D
CRC 1 : AC22615B
Checksum 74
SearchFor*****trap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
Boot File - Version 011.034.00
Boot File - Revision 0x0003 (3)
eBB5ProtocolType == New
Prepare*****trapFile_DCT5 replaced "SILO" with "2ND\0"
Prepare*****trapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchFor*****trap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : 06
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0020 ->
Device ID : 0040 -> Type not in database
Revision ID : 0031
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Revision ID : 0031
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.6
Checksum : 54
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031
Flash Descriptor
Device ID : 0040
Revision ID : 0000
Size : 10000000 (256 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
Algorithm File - Version 011.034.00
Algorithm File - Revision 0x0003 (3)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
PARTNERC : Empty
Reading : MDM_KEYS (CMT)
MDM_KEYS : Empty
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\355358049100228\3553580491002 28_165231.rpl
FlashInfo.RestartMode : 2
Processing Image File :
E:\Program Files\Nokia\Phoenix\Products\RM-645\rm645_071.005_prd.core.fpsx
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 13000000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 453
Entry Point : 0x01F0
Page Format : 128K
Maximum Page Size : 0x00040000
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : E693EF0D
CRC 1 : AC22615B
Checksum 74
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0031
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0031
Block Length : 09
Data : XSR 1.6
Checksum : 54
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0040
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00020000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 000A0000
Partition 2
ID : 00000004 DEMANDONOS
Start Address : 03140000
Partition 3
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 0AE40000
Partition 4
Start Address : 0F640000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF00000004000000030000 0002000A0000030A000000000004000000020314000007D000 0000000008000000010AE40000048000000000000A00000001 0F640000003C000036
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x4F (79)
ERASE Blocks : 0x02 (2)
0 ERASE_AREA_BB5 0x12
Block Length : 0x1B (27)
Device Index : 0x00
0 : 00020000-0003FFFF
1 : 00060000-004DFFFF
2 : 008E0000-0AE3FFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000
Erase_SendEraseBlock_BB5_NAND
Task in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000001
Additional Bad : 00000001
Correctable ECC : 00000000
Erase_SendFormatPartition_BB5_NAND
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Successfully erased..
Time Taken to Erase : 00:00:01
Flashing Speed: 5.00 Mhz (AUTO)
Processing : rm645_071.005_prd.core.fpsx
Total blocks to write : 453
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : SOS+PMML
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : LDSP
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS+CORE
>> CMT Rootkey Hash CERT : SOS+ROFS1
ContinueFlash_DCT5 Complete
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:01:06
E:\Program Files\Nokia\Phoenix\Products\RM-645\rm645_071.005_05.01_Russian_prd.rofs2.fpsx
CMT Type : BB5
Number of Blocks : 183
Entry Point : 0x012C
Page Format : 128K
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 06D40000-0A03FFFF
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Time Taken to Erase : 00:00:00
Processing : rm645_071.005_05.01_Russian_prd.rofs2.fpsx
Total blocks to write : 183
>> CMT Rootkey Hash CERT : SOS+ROFS2
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Time Taken to Flash : 00:00:30
E:\Program Files\Nokia\Phoenix\Products\RM-645\rm645_071.005_U000.000_prd.uda.fpsx
CMT Type : BB5
Number of Blocks : 6
Page Format : 128K
StartErase_DCT5...
Device Index : 0x00
0 : 0AE40000-0F63FFFF
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Processing : rm645_071.005_U000.000_prd.uda.fpsx
Total blocks to write : 6
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Time Taken to Flash : 00:00:01
Total Flash Write Time (Flashing Only) : 00:01:39
Total Flashing Time (Booting + Erase + Flashing) : 00:01:41
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Old 02-18-2012, 12:00   #2 (permalink)
Crazy Poster
Member: 925605
flash new fil
flash new fil
..........................iam some problem uk fil is ok
Old 02-18-2012, 12:56   #3 (permalink)
Member: 880497
Sonork: jabeshmobile@sonork.co.in
its a cable issue...... try with onother good one
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.39898 seconds with 11 queries
