01-01-2014, 21:23 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | After update to 10.60 infineon not flashing by fbus - FIXED - GET 10.61 AUTOUPDATE how to solved? |
01-02-2014, 16:02 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @ALL Go to Product Support tab->Update Files->Check Software Update. You will get ATF v10.61 that fixes Infineon Flashing Problem... BR |
01-02-2014, 19:55 | #8 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | New version 10.61 that is available via Auto-Update already fixes Infineon flashing problem. And is always recommended to use latest version. |
The Following 5 Users Say Thank You to ..::Angel::.. For This Useful Post: |
01-04-2014, 13:57 | #13 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Anyway, post software logs, we will check where is the problem. Btw, here are logs of flashing Nokia 105 Infineon with ATF v10.61: Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00EF Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Processing Image File: D:\Flashes\Nokia\Products\RM-908\rm908_02.700 Checking Flash Image... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 0551 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 02 of 03 IMAGE Erase Block: 0x00C60000~0x00E8123E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2232896 bytes Data Checksum: 89F6 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 03 of 03 IMAGE Erase Block: 0x00FFC000~0x00FFC03E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: D:\Flashes\Nokia\Products\RM-908\rm908_02.70ij Checking Flash Image... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00210000~0x0039A33E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1614656 bytes Data Checksum: 6B15 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: D:\Flashes\Nokia\Products\RM-908\rm908_nai02.70ij Checking Flash Image... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00EB0000~0x00F161BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 418240 bytes Data Checksum: 7E6F Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:01:55 ****************************************************** You must Factory Reset the phone to enable the ringtones and other customized settings to work ****************************************************** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 02.70 22-02-13 RM-908 (c) Nokia IMEI: 358347052079103 Product Serial Number: 2242E65BH Product Code : 059R449 Module Code : 0205453 Basic Production Code: 059Q858 PPM SW Version : V 02.70 22-02-13 RM-908 (c) Nokia IJ ADSP Version : p V 02.70\n22-02-13\nRM-908\n(c) NMP\nij MCU SW Version : V 02.70 22-02-13 RM-908 (c) Nokia HW Version : 1001 UEM Version : 1328 UPP Version : 8850 LCD Version : CMI:BEIHAIv01 ILI9163C ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK | |
01-05-2014, 09:18 | #15 (permalink) |
No Life Poster Join Date: Mar 2013
Member: 1892312 Status: Offline Sonork: 100.1651296 Thanks Meter: 76 | plz admin chak this link , not solve my problem thes solution plz admin chak this link , not solve my problem thes solution http://forum.gsmhosting.com/vbb/f609...y-box-1755237/ |
