08-27-2012, 16:17 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 41
Member: 79291 Status: Offline Thanks Meter: 9 | After update ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers |
08-28-2012, 00:21 | #3 (permalink) |
Freak Poster Join Date: Jan 2005
Member: 111423 Status: Offline Sonork: 100.1618414 Thanks Meter: 22 | disconect the box reboot PC remove drivers ... see inside ATF folder drivers reboot the pc connect again the box but in a new port not in USB hub see the version of the driver you use theres one post from ATF tem Up about that ... he must work ! And pay attention to all steps ! |
09-17-2012, 12:11 | #4 (permalink) | |
Member: 79291 Status: Offline Thanks Meter: 9 | Quote:
not working ...........................error 6 | |
==== FREE DOWNLOAD ==== site updated | cimbalo | GSM Mobile Links | 31 | 04-29-2012 20:43 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
