12-17-2012, 14:34 | #1 (permalink) |
No Life Poster Join Date: Mar 2009 Location: yasir telecom.. Age: 34
Member: 1001830 Status: Offline Sonork: 100.1652282 Thanks Meter: 242 | After update... 9.30 version always error in usb flashing in bb5.. - (BETA INSIDE) WHEN I UPDATE IT ON 9.30 ERROR IN USB FLASHING ???? HERE IS SCREEN SHOT |
12-18-2012, 07:48 | #7 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | All of you follow this steps to solve your problem as mention in this thread 1 - save this folder - C:\AdvanceBox Turbo Flasher\Nokia\Backup 2 - Uninstall ATF 3 - Delete ATF folder 4 - Install ATF V9.30 5 - Update Important Files Try to flash , 100% it will works if phone not have any hardware problem No bug in ATF setup . Allays use good type cable Full charged battery when UBS flashing . Use on board USB port not HUB Br - srinibas |
12-18-2012, 09:13 | #8 (permalink) | |
No Life Poster Join Date: May 2005 Location: Timisoara Age: 43
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 261 | Quote:
done exactly as you say same problem flash via fbus ok flash via usb failed Booting/Flashing Failed... Please Try Again... | |
12-18-2012, 10:05 | #11 (permalink) |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | yes i also facing this type of prblem with other tool ( best dongle ) easy li flash and atf booting faild pliz fix all bugs in new update u r best team atf user need bugs free update |
12-18-2012, 10:25 | #12 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL Try this BETA Software... http://174.120.45.27/tmp/beta/AdvanceBox_935_BETA.exe Put this exe inside C:\AdvanceBox Turbo Flasher\ Then run it... Report back. B.R. |
12-18-2012, 14:43 | #14 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: Great India
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 760 | Quote:
Beta version [9.35] working without any problem....... 9.30 version I faced same problem...... here my flash log & screen shot... Code: Number of Image Files: 5 Processing Image File : rm530_091.003_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 507 Entry Point: 0x01FD Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm530_091.003_C00.01_DEFAULT_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 39 Entry Point: 0x0139 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm530_091.003_26.01_MEA_A_QW1_TPO1_prd.rofs2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 251 Entry Point: 0x0139 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm530_091.003_U011.000_prd.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 51 Entry Point: 0x0139 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 16 Entry Point: 0x0131 Page Format : -1 MAX PAGE : 0x00040000 []: Found 1 active devices. [Nokia E72 USB Phonet]: Opening Connection [Nokia E72 USB Phonet]: Port opened OK! SW: V ICPR82_09w36.4 01-10-09 RM-530 (c) Nokia IMEI: 355239039926360 CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked START FULL PM BACKUP Please Wait... Reading : PM 0~400... OK! FULL PM Backup Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355239039926360\USB_FULL_BACKUP_V ICPR82_09w36.4 01-10-09 RM-530 (c) Nokia_355239039926360_Not Locked_43013.pm Reading Battery Value : 3993 mV Rebooting Phone... AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02011104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 14E00203 ID DWORD 1 : 96730344 ID DWORD 2 : FB94FA66 ID DWORD 3 : C49962AC ID DWORD 4 : 83188D1A 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 25 B9 77 A0 55 BE 9B 5D EC 0C 38 A2 A2 79 C6 95 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 3E273BF6 CRC 1 : 37BE26FA CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0058 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0121 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0058 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 20000000 (512 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 355239039926360 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! NPC CERTIFICATE INFORMATION (CMT): IMEI : 355239039926360 PRODUCT CODE : 0586203 WLAN ID : C8:97:9F:02:0F:EB BLUETOOTH ID : C8:97:9F:01:C1:CB PUBLIC_ID : 14E0020396730344FB94FA66C49962AC83188D1A PAPUB_KEYS_HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E CCC CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 0586203 HWC CERTIFICATE INFORMATION (CMT): PUBLIC_ID : 14E0020396730344FB94FA66C49962AC83188D1A PRODUCT CODE : 0586203 RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355239039926360\355239039926360_43041.rpl PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-530\ ImageFilename: rm530_091.003_prd.core.fpsx Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 Certificate 5 Name : PARTNERC ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00020000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 000A0000 Size : 033A0000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 03440000 Size : 0B340000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0E780000 Size : 109C0000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 1F140000 Size : 003C0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF000000040000000300000002000A0000033A00000000000400000002034400000B34000000000008000000010E780000109C00000000000A000000011F140000003C0000EE PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x4F (79) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00020000-0003FFFF 1 : 00060000-004DFFFF 2 : 008E0000-0E77FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000000000002000000640000000B00000002000000010000000000000000 ERASE_REQUEST_BB5 : 5003120B000300000200000003FFFF120B00030000060000004DFFFF120B000300008E00000E77FFFF37 FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000000000002000000640000000B0000000200000001000000000000000033 Successfully Erased... Total blocks to write : 507 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : SOS+PMML >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [660D81A4455F6F7F9B81D5D10F5336B14B50635E] >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-530\ ImageFilename: rm530_091.003_C00.01_DEFAULT_prd.rofs3.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0CDC0000-0E77FFFF ERASE_REQUEST_BB5 : 5001120B0003000CDC00000E77FFFF73 Successfully Erased... Total blocks to write : 39 >> CMT Rootkey Hash CERT : SOS+ROFS3 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-530\ ImageFilename: rm530_091.003_26.01_MEA_A_QW1_TPO1_prd.rofs2.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 07CC0000-0CDBFFFF ERASE_REQUEST_BB5 : 5001120B00030007CC00000CDBFFFF26 Successfully Erased... Total blocks to write : 251 >> CMT Rootkey Hash CERT : SOS+ROFS2 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-530\ ImageFilename: rm530_091.003_U011.000_prd.uda.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0E780000-1F13FFFF ERASE_REQUEST_BB5 : 5001120B0003000E7800001F13FFFF28 Successfully Erased... Total blocks to write : 51 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-530\ ImageFilename: RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 004E0000-008DFFFF ERASE_REQUEST_BB5 : 5001120B000300004E0000008DFFFF05 Successfully Erased... Total blocks to write : 16 >> CMT Rootkey Hash CERT : SOS*ENO ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000001 Additional Bad : 00000001 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:31 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) SW: V ICPR82_11w16.3.11 29-03-12 RM-530 (c) Nokia IMEI: 355239039926360 CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK My problem solved. Thnx Advance-Box for fast solution. | |
