03-26-2013, 05:57 | #4 (permalink) |
Freak Poster Join Date: Mar 2010 Location: pune
Member: 1263646 Status: Offline Sonork: 1625091 Thanks Meter: 17 | orignal post by MR. ANGEL Follow my post correctly: - run the batch file to remove ATF Box Drivers from here: "c:\AdvanceBox Turbo Flasher\Drivers\Remove_ATF_Drivers" - uninstall ATF Box Software from Windows Add/Remove Programm - delete also the root folder from "c:\" - install Full Setup of ATF Software v9.50 - connect ATF Box and Install Drivers from here: "c:\AdvanceBox Turbo Flasher\Drivers\ATF_NEW_Drivers" - open EXE and click on Restore Box button from Product Support tab - Update Box Firmware only if needed or said by software to do then otherwise skip this step from ATF Software and update important files as well... BR |
03-26-2013, 07:43 | #5 (permalink) |
Freak Poster Join Date: May 2009 Location: *JAVA*
Member: 1026340 Status: Offline Sonork: 100.1621159 Thanks Meter: 142 | problem solved :D -run the batch file to remove ATF Box Drivers from here: "c:\AdvanceBox Turbo Flasher\Drivers\Remove_ATF_Drivers" -connect ATF Box and Install Drivers from here: "c:\AdvanceBox Turbo Flasher\Drivers\ATF_NEW_Drivers" open atf sofwere klik restore box..... done.. next,,,click buton update firmware ....done close/restart sofwere atf box.. open sofwere atf box problem solved |
03-26-2013, 14:26 | #6 (permalink) | |
No Life Poster Join Date: Apr 2011
Member: 1552610 Status: Offline Sonork: 100.1604734 Thanks Meter: 1,370 | Quote:
all done as told but at end result is | |
03-28-2013, 14:25 | #10 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Hi.. After Write last Logicore 10.50.xx http://forum.gsmhosting.com/vbb/f609...0/#post9305396 Br Polaco |
03-29-2013, 00:23 | #11 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Australia, HK. Age: 39
Member: 538861 Status: Offline Sonork: 100.1578309 Thanks Meter: 117 | I am also getting errors with this update that I never get before. 08:48:50 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPUv21_XSR17_alg .fg 08:48:50 : Algorithm File - Version 011.048.00 08:48:50 : Algorithm File - Revision 0x0003 (3) 08:48:50 : eBB5ProtocolType == New 08:48:50 : Algo Loader Sent... 08:48:50 : SendCodeStart_NewProtocol : 08:48:55 : SendAlgoCodeFile_DCT5 : Error 08:48:55 : Try TO UNPLUG RJ45 AND TRY AGAIN 08:48:55 : VBATT Powering Down <<<< 08:48:59 : VBATT Powering Up >>>> 08:48:59 : SET VCCIO Level Done 08:48:59 : SET BSI Load Done |
03-29-2013, 00:26 | #12 (permalink) |
Member: 538861 Status: Offline Sonork: 100.1578309 Thanks Meter: 117 | SearchForBootstrap_DCT5.. ERROR: SECONDARY LOADER NOT FOUND ERROR: Sending Loader Failed... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-29-2013, 01:10 | #13 (permalink) | |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Quote:
install winusb drivers x86 for xp or x64 for 64 bit with usb work fine? polaco | |
03-29-2013, 07:18 | #14 (permalink) |
Member: 538861 Status: Offline Sonork: 100.1578309 Thanks Meter: 117 | I update all files and still same problem. I thought this is fbus problem but I also have problem with usb. I am trying with Nokia 300 Asha, all phones is new never used 100 pcs so can not be phone problem. I also try 2 different fbus cables so can not be cable problem either. |
03-30-2013, 06:50 | #15 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | 1. Make sure no other gsm box connected to your PC 2. Make sure atf box not connected to your pc 3. Run ATF software, it will say box not found 4. Go to product support ---> box tools and select Correct box type 5. Now connect ATF Box to usb port 6. Click restore box If you get same error code 6, then you need to this means you need to check legs of IC in your Box as some legs nog connected to pcb. http://forum.gsmhosting.com/vbb/9308957-post6.html Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
