09-18-2012, 15:03 | #1 (permalink) |
Crazy Poster Join Date: May 2010 Location: Deutschland
Member: 1296428 Status: Offline Thanks Meter: 3 | After update , big problems - [FIXED INSIDE FOR ATF NITRO/LIGHTNING USERS] ImageFile:C:\Programme\Nokia\Phoenix\Products\RM-512\rm512__09.55.mcusw PhoneType : DCT4 Algorithm : DCT4 ALGORITHM Supported Hardwares : > 3160 > 3161 > 3162 > 3164 > 3166 > 3168 Secondary Sending Speed : 100000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 51000Hz Number of Blocks : 191 Entry Point: 0x00D8 Is128k: True Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 68 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 00EC - SAMSUNG (SEC) DevId0 : 2600 - Type not in database ExtId0 : 0000 RevId0 : 9221 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 00EC - SAMSUNG (SEC) DevId1 : 2600 - Type not in database ExtId1 : 0000 RevId1 : 9221 SectorSize1: 11 Reserved1 : 00 ExtBUSC : AD 7E B6 1B 23 10 03 40 C6 05 E4 01 20 A2 00 00 CheckSum : 67 ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_amd.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 842C19D8B5D9D6BFD04EA7B7EE DecodedMSID: 842C40BAE9000278D0A8000000 EncodedFAID: F19CDC491C0767F7D7A22E0C Authentication : SUCCESSFULL Erasing address: >> 01000000 : 0101FFFF BB_PROGRAMMING_STATUS_REQUEST : 04 FF ProgrammingStatus_DCT4 : No Error - 0 (0x00) >> 01020000 : 01CFFFFF BB_PROGRAMMING_STATUS_REQUEST : 04 FF ProgrammingStatus_DCT4 : No Error - 0 (0x00) Erasing Done Flashing ImageFile 8-BIT PROTOCOL ERROR: Phone did not Ack !!! FAILED.. Flashing FAILED... Flashing ERROR What did i wrong ? |
The Following User Says Thank You to krumpa For This Useful Post: |
09-20-2012, 08:27 | #8 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @krumpa This is ATF BIG Chrome Box or ATF Lightning/Nitro Box? It is possible that it is a firmware problem on 10.3.30 when flashing DCT4 phones. I can fix it after you confirm what box type you are using. B.R. |
09-20-2012, 10:52 | #12 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Old Box I am using the old box not new Nitro box i also face the same problem especially booting and flashing the Infinion base phones.. Solution please................ |
09-20-2012, 11:00 | #14 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL 1. Use ATF 9.11 2. Click "RESTORE BOX" in Product Support ---> Box Tools (this will downgrade your firmware) 3. Click "UPDATE FIRMWARE" in Product Support ---> Box Tools (this will upgrade your firmware with the new FIXED firmware for DCT4) This will give you the New 10.3.30 firmware for Nitro and Lightning which has the DCT4 Flashing Fix. B.R. |
09-20-2012, 11:10 | #15 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | 1680C Tested Ok. Code: ImageFile:C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-394\rm394__07.65.mcusw PhoneType : DCT4 Algorithm : DCT4 ALGORITHM Supported Hardwares : > 3160 > 3161 > 3162 > 3164 > 3166 Secondary Sending Speed : 100000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 51000Hz Number of Blocks : 327 Entry Point: 0x00D6 Is128k: True Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 62 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Application_NEW\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 ERROR: Secondary Loader not accepted 07 SearchForBootstrap_DCT4 : Error (Failed) Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 62 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Application_NEW\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 ERROR: Secondary Loader not accepted FF SearchForBootstrap_DCT4 : Error (Failed) Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 62 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Application_NEW\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 0089 - INTEL DevId0 : 8981 - NU48F256 ExtId0 : 0000 RevId0 : 9221 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0089 - INTEL DevId1 : 8981 - NU48F256 ExtId1 : 0000 RevId1 : 9221 SectorSize1: 11 Reserved1 : 00 ExtBUSC : AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00 CheckSum : FE ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Application_NEW\Nokia\DCT4_Loader\u3_intel.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 846E0AE5B0097182C759B18F6A DecodedMSID: 842C40BAE90082C53CA8000000 EncodedFAID: 8C0BC994598E1664F9B330AC Authentication : SUCCESSFULL Erasing address: >> 01000000 : 0101FFFF BB_PROGRAMMING_STATUS_REQUEST : 04 FF ProgrammingStatus_DCT4 : No Error - 0 (0x00) >> 01020000 : 01C3FFFF BB_PROGRAMMING_STATUS_REQUEST : 04 FF ProgrammingStatus_DCT4 : No Error - 0 (0x00) Erasing Done Flashing ImageFile ContinueFlash_DCT4 Complete Write Time Elapse : 00:00:40 FLASH Mode Set to : PHONEMODE_FLASHBUS ProgrammingStatus_DCT4 BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status First Byte OK Second Byte OK BB_PERM_DATA_RESTORE_REQ : 18 FF BB_RESTART : 07 FF MCURestart : SUCCESS Making delay between files for 6000ms ImageFile:C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-394\rm394__07.65.ppm_ad PhoneType : DCT4 Algorithm : DCT4 ALGORITHM Supported Hardwares : > 3160 > 3161 > 3162 > 3164 > 3166 Secondary Sending Speed : 100000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 51000Hz Number of Blocks : 89 Entry Point: 0x00D2 Is128k: True Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 62 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Application_NEW\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 0089 - INTEL DevId0 : 8981 - NU48F256 ExtId0 : 0000 RevId0 : 9221 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0089 - INTEL DevId1 : 8981 - NU48F256 ExtId1 : 0000 RevId1 : 9221 SectorSize1: 11 Reserved1 : 00 ExtBUSC : AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00 CheckSum : FE ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Application_NEW\Nokia\DCT4_Loader\u3_intel.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 84889AAAACD75979330A0AD530 DecodedMSID: 843E4EBAE90082C53CAA000000 EncodedFAID: 4DA3CBC4AD5371CB837E0C5B Authentication : SUCCESSFULL Erasing address: >> 01C40000 : 01FFFFFF BB_PROGRAMMING_STATUS_REQUEST : 04 FF ProgrammingStatus_DCT4 : No Error - 0 (0x00) Erasing Done Flashing ImageFile ContinueFlash_DCT4 Complete Write Time Elapse : 00:00:11 FLASH Mode Set to : PHONEMODE_FLASHBUS ProgrammingStatus_DCT4 BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status First Byte OK Second Byte OK BB_PERM_DATA_RESTORE_REQ : 18 FF BB_RESTART : 07 FF MCURestart : SUCCESS Making delay between files for 6000ms ImageFile:C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-394\rm394__07.65.image_ad PhoneType : DCT4 Algorithm : DCT4 ALGORITHM Supported Hardwares : > 3160 > 3161 > 3162 > 3164 > 3166 Secondary Sending Speed : 100000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 51000Hz Number of Blocks : 264 Entry Point: 0x00DD Is128k: True Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 62 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Application_NEW\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 0089 - INTEL DevId0 : 8981 - NU48F256 ExtId0 : 0000 RevId0 : 9221 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0089 - INTEL DevId1 : 8981 - NU48F256 ExtId1 : 0000 RevId1 : 9221 SectorSize1: 11 Reserved1 : 00 ExtBUSC : AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00 CheckSum : FE ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Application_NEW\Nokia\DCT4_Loader\u3_intel.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 84ECB5A7ABAD249FA9A5C5D4D0 DecodedMSID: 84D26EBAF10082C53CAA000610 EncodedFAID: 5C717D44B985697DBE47703B Authentication : SUCCESSFULL Erasing address: >> 02000000 : 02DBFFFF BB_PROGRAMMING_STATUS_REQUEST : 04 FF ProgrammingStatus_DCT4 : No Error - 0 (0x00) >> 02DC0000 : 02F9FFFF BB_PROGRAMMING_STATUS_REQUEST : 04 FF ProgrammingStatus_DCT4 : No Error - 0 (0x00) Erasing Done Flashing ImageFile ContinueFlash_DCT4 Complete Write Time Elapse : 00:00:21 FLASH Mode Set to : PHONEMODE_FLASHBUS ProgrammingStatus_DCT4 BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status First Byte OK Second Byte OK BB_PERM_DATA_RESTORE_REQ : 18 FF BB_RESTART : 07 FF MCURestart : SUCCESS Time Elapse : 00:05:28 Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 07.65 30-04-09 RM-394 (c) Nokia IMEI: 359354033131176 Model : Nokia 1680c-2 Product Serial Number: I9A072076 Product Code : 0562915 Module Code : 0203777 Basic Production Code: 0556746 Long Production SN : 0 PPM SW Version : V 07.65 30-04-09 RM-394 (c) Nokia AD MCU SW Version : V 07.65 30-04-09 RM-394 (c) Nokia HW Version : 3001 UEM Version : 1328 UPP Version : 12642 RFIC Version : 0500 DSP Version : ICPR62_08w36_UPP LCD Version : SUEZ Content Pack Version : Content: ad V 07.65 30-04-09 RM-394 (c) Nokia ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 000000000001000B ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED MASTER_CODE : 7257244061 PHONE_MODE : LOCAL ================================================ Dynamic Camera Configuration ================================================ DCC ID : GR0103D1012601022C00 DCC Ver: 001004 Status : OK FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
The Following User Says Thank You to Advance-Box For This Useful Post: |
