09-02-2013, 16:01 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: morocco Age: 44
Member: 207447 Status: Offline Thanks Meter: 48 | after update box not worked - [FIXED] Advance Turbo Flasher Found Driver Version : 00020824 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 10.3.80 Software Version : v10.11 Info : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) PAPUB_KEYS_HASH_REQ_BB5 ERROR: FBUS Boot FAILED View image: ATF 2 LOG ALL OPERATION |
09-02-2013, 17:41 | #3 (permalink) |
Member: 207447 Status: Offline Thanks Meter: 48 | i have tested 3 worked cable nokia 2730 and cable 5130 problems in box after update box not read hash always recieved this error SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) OLD Protocol Detected... Using Turbo Mode... PAPUB_KEYS_HASH_REQ_BB5 ERROR: FBUS Boot FAILED |
09-02-2013, 17:58 | #5 (permalink) |
Member: 207447 Status: Offline Thanks Meter: 48 | Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 10.3.80 Software Version : v10.11 AdvanceBox SN : B1C91A1886DB Box Status : ACTIVATED http://postimg.org/image/kl7lylh87/ |
09-02-2013, 18:00 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Here are my logs from ATF v10.10: Decrypt PM120 Hashes from 6303c, same RAP3G phone as yours 5130, 2700c. Code: Booting Phone via FBUS... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0BD00003 ID DWORD 1 : 42B27D56 ID DWORD 2 : B071E6BB ID DWORD 3 : B3C46EF3 ID DWORD 4 : F6C9E715 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum AC SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 =========================================== PHONE FIRMWARE VERSION: V 10.12 08-04-10 RM-443 (c) Nokia =========================================== Scanning Simlock Applet Type... OK ================================================= PA_SL3 Applet detected ================================================= Dumping RSA Modulus... OK ================================================= RSA Modulus OK ================================================= ================================================ Decrypt SL3 PM 120 HASHES for Brute Force Unlock ================================================ Decrypting PM 120... PM 120 HASHES Extracted Successfully B75848CECAF3EC4B1124BB9007AE251278C416D9 4418732F1F75FECF90641DE0BA2096D3C2C7612B 61F4F1EB9D9B5DFFD1E4E126D6F1697422AAB232 A797037948B4A47CC8A1FFA6222D93F544FA09F3 49F7E48C8A4E54CC4F401817250A8E4B65D31485 DBB5F947E178F22473AD9DC418620D533AF5AB64 483BE001B220197A175E1042A76666758C5D0383 15630A61DFCA992ECEBF99886636415FAD163664 Log Files for Local Brute Force Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\353199039849107\353199039849107.job C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\353199039849107\353199039849107.log C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\353199039849107\353199039849107.bcl C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\353199039849107\353199039849107.sha Command Line for ighashgpu: Saved as MS Batch File: 353199039849107_ighashgpu.bat Command Line for oclHashcat-lite64 (AMD Cards 64-Bit OS): Saved as MS Batch File: 353199039849107_AMD_oclHashcat_64-bit.bat Command Line for oclHashcat-lite32 (AMD Cards 32-Bit OS): Saved as MS Batch File: 353199039849107_AMD_oclHashcat_32-bit.bat Command Line for cudaHashcat-lite64 (NVIDIA Cards 64-Bit OS): Saved as MS Batch File: 353199039849107_NVIDIA_cudaHashcat_64-bit.bat Command Line for cudaHashcat-lite32 (NVIDIA Cards 32-Bit OS): Saved as MS Batch File: 353199039849107_NVIDIA_cudaHashcat_32-bit.bat Process Done! BR |
09-02-2013, 18:09 | #7 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Here are logs from ATF v10.11 using ATF Lightning Box: You see now there is no problem in EXE or in box's firmware. Try to Bus Check or Backup RPL with GOOD QUALITY FBUS cable, if still you get error, then Restore Box and check.... BR |
09-02-2013, 18:15 | #8 (permalink) |
Member: 207447 Status: Offline Thanks Meter: 48 | look image my box worked perfect bat after i have updated not worked good alwyas this error in deferent model in operation the read hash and bus chek |
09-03-2013, 15:06 | #10 (permalink) | |
Member: 207447 Status: Offline Thanks Meter: 48 | problems solved by this method http://forum.gsmhosting.com/vbb/f609...ems-o-1021379/ Code:
