04-06-2013, 12:26 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Malaysia - KL Age: 38
Member: 260844 Status: Offline Sonork: 100.105548 Thanks Meter: 38 | after update flashing error - (Solution Inside) Code: ATF Software Version v9.70 ATF Box FBUS Flash Started... Number of Image Files: 5 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-505\RM-505_22.0.110_prd.core.C00 CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 13000000 Hz Program Sending Speed : 13000000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 477 Entry Point : 0x2A5E10 Page Format : 128K Maximum Page Size : 0x00040000 Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01031103 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 14000203 ID DWORD 1 : 18810052 ID DWORD 2 : 622EF2BB ID DWORD 3 : F32603A2 ID DWORD 4 : 06219458 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum B3 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 012.08.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 Checksum : 25 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algorithm File - Version 012.08.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00080000 Size : 019A0000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 01A20000 Size : 09180000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0ABA0000 Size : 04B80000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 0F8C0000 Size : 00160000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200080000019A0000000000040000000201A200000918000000000008000000010ABA000004B800000000000A000000010F8C000000160000C5 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x57 (87) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-00082FFF 1 : 00083400-003FFFFF 2 : 00800000-00D5FFFF 3 : 00D60000-0AB9FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x00000000 Format Info : 000000000000000A0000000000000002000000640000000300000001000000010000000000000000 Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Erase_SendFormatPartition_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:01 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-505_22.0.110_prd.core.C00 Total blocks to write : 477 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B] >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:00 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-505\RM-505_22.0.110_C01_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 13000000 Hz Program Sending Speed : 13000000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 6 Entry Point : 0x00FF Page Format : 128K Maximum Page Size : 0x00000E00 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 09CA0000-0AB9FFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-505_22.0.110_C01_prd.rofs3.fpsx Total blocks to write : 6 >> CMT Rootkey Hash CERT : SOS+ROFS3 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:00 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-505\RM-505_22.0.110_prd.rofs2.V19 CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 13000000 Hz Program Sending Speed : 13000000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 134 Entry Point : 0x00FF Page Format : 128K Maximum Page Size : 0x00040000 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 079A0000-09C9FFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-505_22.0.110_prd.rofs2.V19 Total blocks to write : 134 >> CMT Rootkey Hash CERT : SOS+ROFS2 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:18 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-505\RM505_507_22.0.110_uda_10_001.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 13000000 Hz Program Sending Speed : 13000000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 36 Entry Point : 0x00FF Page Format : 128K Maximum Page Size : 0x00040000 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0ABA0000-0F71FFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM505_507_22.0.110_uda_10_001.uda.fpsx Total blocks to write : 36 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:06 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-505\RM505_APE_ONLY_ENO_09w23_v0.072.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 16 Entry Point : 0x0136 Page Format : 128K Maximum Page Size : 0x00040000 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00400000-007FFFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM505_APE_ONLY_ENO_09w23_v0.072.fpsx Total blocks to write : 16 >> CMT Rootkey Hash CERT : SOS*ENO ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:01 Total Flash Write Time (Flashing Only) : 00:01:27 Total Flashing Time (Booting + Erase + Flashing) : 00:01:29 STATUS_REQUEST_BB5... 1 Sub Block ID : 16 PROGRAMMING_ERROR_BB5 Block Length : 0F BB ASIC Index : 00 Error Type : 05 Error Spec : 08 Of*****ng Address : 01220400 Expected Content : 0000F8B1 Detected Content : 0000FFB1 Try to change the Flashing clock... |
04-06-2013, 13:35 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @desmond5389 If you think your Box Firmware is the problem. You can: 1. Click Restore Box 2. Click Update Firmware if that does not solve your problem, you can re-install 9.60 then: 1. Click Restore Box 2. Click Update Firmware This will downgrade your Box Firmware to previous version. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
04-07-2013, 09:13 | #3 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Chittagong, Bangladesh Age: 40
Member: 866650 Status: Offline Sonork: mdsalimkhan_05 Thanks Meter: 147 | Quote:
Re-install 9.60 After Restore box can not update Here is loge Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List ================================================ Box Successfully Initialized ================================================ when click update show this massage | |
The Following User Says Thank You to Md Salim Khan For This Useful Post: |
04-07-2013, 12:19 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Md Salim Khan @desmond5389 Do this: 1. Remove ATF Box from USB port 2. Run ATF Software and go to Box Tools 3. Connect ATF Box to USB Port 4. Select Correct Box Type (ATF BIG + Normal PCB) 5. CLICK RESTORE BOX 6. Click Update Firmware |
04-07-2013, 15:05 | #5 (permalink) |
No Life Poster Join Date: Aug 2004 Location: E.A.P & E.A.S
Member: 76239 Status: Offline Sonork: 100.1584414 Thanks Meter: 210 | Same problem here : ================================================ INFO: RX2 PIN is OK ================================================ >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [C0E691EA16A7593A9BB28832D7312A39F7ED668D] >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : PMM_CONF >> CMT Rootkey Hash CERT : SBIF_CONF ContinueFlash_DCT5 Complete STATUS_REQUEST_BB5... 1 Sub Block ID : 16 PROGRAMMING_ERROR_BB5 Block Length : 0F BB ASIC Index : 00 Error Type : 05 Error Spec : 08 Of*****ng Address : 0004C400 Expected Content : 00005DF9 Detected Content : 00005DFD Reconnect your Cable Properly because RX2 PIN is NOT getting any DATA from the Box!!! Flashing FAILED BB5_WRITE_FlashFile_0 Go to Settings --> Nokia Settings --> FBUS DDR&2TX Synchronization Timeout Change the current value selected to a higher value and Restart AdvanceBox.exe software to apply it Operations Failed.... AMD machine Thanks |
04-07-2013, 17:28 | #6 (permalink) | |
You have latest firmware I have been suffering this problem since 10 days and I can not fbus flash any set. Please solve this problem as soon as possible | |
04-09-2013, 06:39 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL Problem can be solved by using 15 Mhz or just follow instructions here: http://forum.gsmhosting.com/vbb/f609...5/#post9335461 |
