10-28-2014, 10:00 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Gampaha, Srilanka
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | After update serial 0x00000000.... http://forum.gsmhosting.com/vbb/f609...issue-1872418/ After this I updated it to 11.70 and I saw some unusual things like home screen Just appears "Turbo Nitro". And not connecting to phones. Last I saw serial 0x00000000. I saw few tutorials here. But that are old. Therefore I didn't test with it.... My box is big metal chrome type. Please guide me how to fix this.... Serial here |
10-28-2014, 12:21 | #3 (permalink) | |
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | Quote: | |
10-30-2014, 11:44 | #5 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Check Windows device manager, is your box detected there? If it is detected as a dual-rs232 device, install drivers from: http://www.ftdichip.com/Drivers/CDM/...0Certified.zip After your box is detected in device manager with correct drivers, then goto Product Support ----> Box Tools Click ----> Restore EEPROM Then at this point, re-install ATF drivers from C:\AdvanceBox Turbo Flasher\Drivers\ATF_NEW_DRIVERS\ or directly from Windows Support if you are using win7, win8 and higher... After you box is detected as AdvanceBox Turbo Flasher, then goto Product Support ----> Box Tools Click ----> Restore Box then Update Firmware if necessary Last edited by Advance-Box; 10-30-2014 at 11:51. | |
10-31-2014, 22:20 | #6 (permalink) |
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | After restore EEPROM all ok. And http://forum.gsmhosting.com/vbb/f609...issue-1872418/ this problem also fix. Great support..... |
02-27-2015, 09:29 | #9 (permalink) | |
The Following User Says Thank You to Ransiri For This Useful Post: |
02-27-2015, 10:47 | #10 (permalink) |
Freak Poster Join Date: Aug 2008 Location: kenya
Member: 839673 Status: Offline Sonork: pastorshaggy Thanks Meter: 66 | Quote: Originally Posted by Advance-Box View Post Check Windows device manager, is your box detected there? If it is detected as a dual-rs232 device, install drivers from: http://www.ftdichip.com/Drivers/CDM/...0Certified.zip After your box is detected in device manager with correct drivers, then goto Product Support ----> Box Tools Click ----> Restore EEPROM Then at this point, re-install ATF drivers from C:\AdvanceBox Turbo Flasher\Drivers\ATF_NEW_DRIVERS\ or directly from Windows Support if you are using win7, win8 and higher... After you box is detected as AdvanceBox Turbo Flasher, then goto Product Support ----> Box Tools Click ----> Restore Box then Update Firmware if necessary Tested and working.... it work now box working perfect |
