03-12-2014, 11:22 | #1 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 746552 Status: Offline Sonork: 100.1594844 Thanks Meter: 110 | after write sdc file 2 pc 16 gb mmc damaged- need to repair N9005 Micro sd card dont work -anymore. my procedure - I downloas file form ATF JTAG AFP FILES by Linus H. - 4shared then write it- by atf- I insert the memory card in ATF mmc point. then write it. after write I dont see any response of my MMC card. I checd it by computer using card reader. Also no response -with phone. plz explain reason--- where the problem.. thanks |
03-12-2014, 12:20 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @vertex777 Are you saying ATF Damaged your SD Card beyond recognition by your PC? Relax and try to understand 1 thing... this is totally impossible to happen unless your SD card is defective. Anyway, perform this: 1. Total Erase SDC 2. Then Connect your SD Card to your Card Reader... Windows will ask you to format it. B.R. |
03-12-2014, 12:42 | #3 (permalink) | |
Member: 746552 Status: Offline Sonork: 100.1594844 Thanks Meter: 110 | Quote:
thanks. | |
03-12-2014, 13:02 | #4 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
03-12-2014, 13:19 | #5 (permalink) | |
03-12-2014, 15:08 | #6 (permalink) | |
Freak Poster Join Date: May 2011 Location: Himachal Pradesh,Kangra,India
Member: 1587904 Status: Offline Thanks Meter: 59 | Quote:
Now put your phone in download mode by pressing vol down + home+ power button when it comes flash the phone with odin | |
03-12-2014, 19:27 | #8 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @vertex N9005 does not need TP because it is qualcomm based phone. However, you need to match current bootloader inside phone with what ever sdc image you write to the sd card. So try first with 4.3 sdc, then 4.4.2 sdc etc... until the phone will finally enter download mode. B.R. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
04-12-2014, 08:56 | #9 (permalink) |
No Life Poster Join Date: Nov 2009 Location: BaNgLaDeSh Age: 41
Member: 1150957 Status: Offline Thanks Meter: 60 | i have 2 piece n9005, when i connect phone to pc 2 phone ask qualcom hs-usb qdloader 9008 driver i am try to repair with atf SDC file but not success, any idea ............................. |
