11-03-2012, 11:51 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: saqez - iran
Member: 1474571 Status: Offline Sonork: 100.1614377 Thanks Meter: 72 | again n73 security test faild 2. full backup pm 3. erase phone 4. flash with latest firmware 5. write rpl back 6. repair sdd 7. do local sx4auth but not solved writ rpl without nps but not solved please give me variant with prodact code 0544952 .. |
11-03-2012, 12:06 | #3 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: .::: Madina :::.
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Quote:
Which You Use Tool For Repair Security Test Faild ????? Last edited by ::SYED MOBILE::; 11-03-2012 at 12:11. | |
11-03-2012, 12:57 | #9 (permalink) |
No Life Poster Join Date: Sep 2007 Location: EARTH Age: 42
Member: 582682 Status: Offline Sonork: 100.1607124 Thanks Meter: 136 | backup rpl reset npc than erase pm than write good pm with lock aria with sx4 than write rpl |
The Following User Says Thank You to way2unlock For This Useful Post: |
11-05-2012, 05:07 | #12 (permalink) |
Banned Join Date: Aug 2011 Location: Bhairahawa_Nepal
Member: 1638066 Status: Offline Thanks Meter: 170 | Basic Phone Information 09:05:50 : ================================================ 09:05:50 : MCU Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. 09:05:50 : IMEI Plain : 355718025994029 09:05:50 : IMEI Spare : A355718025994020 09:05:50 : IMEI SV : 33557180259940281F 09:05:51 : Phone Model: Nokia N73 09:05:51 : Category : Imaging Phone 09:05:51 : Phone Type : RM-133 09:05:51 : 09:05:51 : ================================================ 09:05:51 : Extended Phone Information 09:05:51 : ================================================ 09:05:51 : Product Serial Number: CNF178756 09:05:51 : Product Code : 0539691 09:05:51 : Module Code : 0202855 09:05:51 : Basic Production Code: 0527006 09:05:52 : MCU SW Version : V 05wk47v62 05-12-08 RM-133 (c) Nokia. 09:05:52 : HW Version : 6000 09:05:52 : RFIC Version : 17211721 09:05:52 : DSP Version : scarfe_mc.05wk46v50p2 09:05:53 : Camera : 1 09:05:53 : APE BT Version : HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. 09:05:53 : AHNE Version : 30 09:05:53 : APE SW Core Version : V 4.0850.43.0.1 12-12-2008 RM-133 09:05:54 : Variant Version : V 4.0850.43.0.1-77 12-12-2008 RM-133 09:05:54 : RETU Version : 15 09:05:54 : TAHVO Version : 22 09:05:54 : APE HW Version : 1 09:05:54 : APE ADSP SW Version : 256 09:05:54 : Bluetooth ID : 00:24:03:3F:BE:B7 09:05:54 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I 09:05:54 : 09:05:54 : ================================================ 09:05:54 : Simlock Information 09:05:54 : ================================================ 09:05:56 : CONFIG KEY : 0000000000000000 09:05:56 : PROVIDER KEY : 2440700000000000 09:05:56 : NETWORK NAME : Nokia Default;Finland 09:05:56 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 09:05:56 : SIMLOCK TABLE : 09:05:56 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 09:05:56 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 09:05:56 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 09:05:56 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 09:05:56 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 09:05:56 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 09:05:56 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 09:05:56 : SIMLOCK STATE : Not Locked 09:05:56 : 09:05:56 : SIMLOCK_TYPE : PA_SL1 09:05:56 : SIMLOCK_TEST : PASSED 09:05:56 : SECURITY_TEST : FAILED 09:05:56 : > Try SX4 "PM AUTH" 09:05:56 : > Then Write PM 1 and 309 09:05:56 : SECURITY_CODE : 12345 09:05:57 : PHONE_MODE : LOCAL 09:05:57 : DCC ID : NOT USED 09:05:57 : 09:05:57 : 09:05:57 : ================================================== ==== 09:05:57 : Selected VPL File: 09:05:57 : RM133_0514756_4.0850.43.0.1_007.vpl 09:05:57 : ================================================== ==== 09:05:57 : Variant Details : HK CV WM 09:05:57 : Software Version : 4.0850.43.0.1 09:05:57 : Product Type : RM-133 09:05:57 : Product Code : 0514756 09:05:57 : Variant Version : 007 09:05:57 : 09:06:11 : 09:06:11 : ================================================ 09:06:11 : Basic Phone Information 09:06:11 : ================================================ 09:06:11 : MCU Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. 09:06:11 : IMEI Plain : 355718025994029 09:06:11 : IMEI Spare : A355718025994020 09:06:11 : IMEI SV : 33557180259940281F 09:06:11 : Phone Model: Nokia N73 09:06:11 : Category : Imaging Phone 09:06:11 : Phone Type : RM-133 09:06:11 : 09:06:11 : 09:06:11 : 09:06:11 : ================================================ 09:06:11 : SX4 Custom Keys Stand Alone Edition 09:06:11 : ================================================ 09:06:11 : 09:06:11 : >>> : SX4 Auth Successfull 09:06:11 : Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-133.pm 09:06:11 : Start Uploading PM... 09:06:11 : Field : 1 Sub : 0 Byte(s): 114 - Ok 09:06:11 : Field : 1 Sub : 2 Byte(s): 98 - Ok 09:06:12 : Field : 1 Sub : 4 Byte(s): 110 - Ok 09:06:12 : Field : 1 Sub : 6 Byte(s): 98 - Ok 09:06:12 : Field : 1 Sub : 8 Byte(s): 110 - Ok 09:06:12 : Field : 1 Sub : 13 Byte(s): 98 - Ok 09:06:12 : Field : 1 Sub : 16 Byte(s): 98 - Ok 09:06:12 : Field : 1 Sub : 18 Byte(s): 98 - Ok 09:06:12 : Field : 1 Sub : 20 Byte(s): 98 - Ok 09:06:12 : Field : 1 Sub : 22 Byte(s): 16 - Ok 09:06:12 : Field : 1 Sub : 23 Byte(s): 4 - Ok 09:06:12 : Field : 1 Sub : 24 Byte(s): 84 - Ok 09:06:12 : Field : 1 Sub : 25 Byte(s): 4 - Ok 09:06:12 : Field : 1 Sub : 26 Byte(s): 110 - Ok 09:06:12 : Field : 1 Sub : 28 Byte(s): 98 - Ok 09:06:12 : Field : 1 Sub : 29 Byte(s): 6 - Ok 09:06:12 : Field : 1 Sub : 31 Byte(s): 98 - Ok 09:06:12 : Field : 1 Sub : 33 Byte(s): 36 - Ok 09:06:13 : Field : 1 Sub : 34 Byte(s): 80 - Ok 09:06:13 : Field : 1 Sub : 44 Byte(s): 182 - Ok 09:06:13 : Field : 309 Sub : 0 Byte(s): 4 - Ok 09:06:13 : Field : 309 Sub : 1 Byte(s): 2 - Ok 09:06:13 : Field : 309 Sub : 2 Byte(s): 12 - Ok 09:06:13 : Field : 309 Sub : 4 Byte(s): 12 - Ok 09:06:13 : Field : 309 Sub : 5 Byte(s): 12 - Ok 09:06:13 : Field : 309 Sub : 7 Byte(s): 12 - Ok 09:06:13 : Field : 309 Sub : 8 Byte(s): 12 - Ok 09:06:13 : Field : 309 Sub : 17 Byte(s): 12 - Ok 09:06:13 : Field : 309 Sub : 22 Byte(s): 12 - Ok 09:06:13 : PM Upload Done!... 09:06:18 : 09:06:18 : FACTORY SET TO : Full Factory Set 09:06:19 : OK 09:06:19 : FACTORY SET TO : User Data 09:06:19 : OK 09:06:19 : FACTORY SET TO : Leave Factory 09:06:19 : OK 09:06:19 : FACTORY SET TO : Service Center 09:06:19 : OK 09:06:19 : FACTORY SET TO : Software Upgrade 09:06:19 : OK 09:06:19 : FACTORY SET TO : Production Tune 09:06:19 : OK 09:06:20 : 09:06:21 : 09:06:21 : ================================================ 09:06:21 : Basic Phone Information 09:06:21 : ================================================ 09:06:21 : MCU Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. 09:06:21 : IMEI Plain : 355718025994029 09:06:21 : IMEI Spare : A355718025994020 09:06:21 : IMEI SV : 33557180259940281F 09:06:21 : Phone Model: Nokia N73 09:06:21 : Category : Imaging Phone 09:06:21 : Phone Type : RM-133 09:06:21 : 09:06:21 : ================================================ 09:06:21 : Extended Phone Information 09:06:21 : ================================================ 09:06:21 : Product Serial Number: CNF178756 09:06:22 : Product Code : 0539691 09:06:22 : Module Code : 0202855 09:06:22 : Basic Production Code: 0527006 09:06:22 : MCU SW Version : V 05wk47v62 05-12-08 RM-133 (c) Nokia. 09:06:22 : HW Version : 6000 09:06:23 : RFIC Version : 17211721 09:06:23 : DSP Version : scarfe_mc.05wk46v50p2 09:06:24 : Camera : 1 09:06:24 : APE BT Version : HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. 09:06:24 : AHNE Version : 30 09:06:24 : APE SW Core Version : V 4.0850.43.0.1 12-12-2008 RM-133 09:06:24 : Variant Version : V 4.0850.43.0.1-77 12-12-2008 RM-133 09:06:24 : RETU Version : 15 09:06:24 : TAHVO Version : 22 09:06:24 : APE HW Version : 1 09:06:24 : APE ADSP SW Version : 256 09:06:24 : Bluetooth ID : 00:24:03:3F:BE:B7 09:06:25 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I 09:06:25 : 09:06:25 : ================================================ 09:06:25 : Simlock Information 09:06:25 : ================================================ 09:06:26 : CONFIG KEY : 0000000000000000 09:06:26 : PROVIDER KEY : 2440700000000000 09:06:26 : NETWORK NAME : Nokia Default;Finland 09:06:26 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 09:06:26 : SIMLOCK TABLE : 09:06:26 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 09:06:26 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 09:06:26 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 09:06:26 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 09:06:26 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 09:06:26 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 09:06:26 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 09:06:26 : SIMLOCK STATE : Not Locked 09:06:26 : 09:06:26 : SIMLOCK_TYPE : PA_SL1 09:06:26 : SIMLOCK_TEST : PASSED 09:06:26 : SECURITY_TEST : PASSED 09:06:26 : SECURITY_CODE : 12345 09:06:27 : PHONE_MODE : LOCAL 09:06:27 : DCC ID : NOT USED |
