Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 01-23-2013, 08:36   #1 (permalink)
Member: 1189402
Sonork: 10000.00
again problem n73 security test filed
hi
pls help me.
erase-full flash-write pm filed 1.309
sd repiar-write pm
not solved.
      SX4 Custom Keys Stand Alone Edition
>>> : SX4 Auth Successfull
Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-133.pm
Start Uploading PM...
Field : 1 Sub : 0 Byte(s): 114  - Ok
Field : 1 Sub : 2 Byte(s): 98  - Ok
Field : 1 Sub : 4 Byte(s): 110  - Ok
Field : 1 Sub : 6 Byte(s): 98  - Ok
Field : 1 Sub : 8 Byte(s): 110  - Ok
Field : 1 Sub : 13 Byte(s): 98  - Ok
Field : 1 Sub : 16 Byte(s): 98  - Ok
Field : 1 Sub : 18 Byte(s): 98  - Ok
Field : 1 Sub : 20 Byte(s): 98  - Ok
Field : 1 Sub : 22 Byte(s): 16  - Ok
Field : 1 Sub : 23 Byte(s): 4  - Ok
Field : 1 Sub : 24 Byte(s): 84  - Ok
Field : 1 Sub : 25 Byte(s): 4  - Ok
Field : 1 Sub : 26 Byte(s): 110  - Ok
Field : 1 Sub : 28 Byte(s): 98  - Ok
Field : 1 Sub : 29 Byte(s): 6  - Ok
Field : 1 Sub : 31 Byte(s): 98  - Ok
Field : 1 Sub : 33 Byte(s): 36  - Ok
Field : 1 Sub : 34 Byte(s): 80  - Ok
Field : 1 Sub : 44 Byte(s): 182  - Ok
Field : 309 Sub : 0 Byte(s): 4  - Ok
Field : 309 Sub : 1 Byte(s): 2  - Ok
Field : 309 Sub : 2 Byte(s): 12  - Ok
Field : 309 Sub : 4 Byte(s): 12  - Ok
Field : 309 Sub : 5 Byte(s): 12  - Ok
Field : 309 Sub : 7 Byte(s): 12  - Ok
Field : 309 Sub : 8 Byte(s): 12  - Ok
Field : 309 Sub : 17 Byte(s): 12  - Ok
Field : 309 Sub : 22 Byte(s): 12  - Ok
PM  Upload Done!...
write variant:
Erase_SendEraseBlock_BB5_NAND
Task in Progress... Please Wait...
Successfully erased..
Now Writing : CMT VARIANT Certificate 0x0118 Bytes
STATUS_REQUEST_BB5...
1  Sub Block ID      : 14 STATUS_NOR_OK_BB5
           Block Length      : 01
           BB ASIC Index     : 00
2  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  01
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00504A09
          Additional Bad    :  00E26126
          Correctable ECC   :  0014FCD8
VARIANT Write Successful...
Write Certificates OK!
RPL Upload Finished!!!
scan:
SIMLOCK_TYPE             : PA_SL1
SIMLOCK_TEST             : PASSED
SECURITY_TEST     : FAILED
      >  Try SX4 "PM AUTH"
      >  Then Write PM 1 and 309
SECURITY_CODE          : 12345
PHONE_MODE              : LOCAL
Old 01-23-2013, 09:13   #2 (permalink)
rahul_rocks3's Avatar
Member: 1312746
Sonork: 100.1604777
try writing any other pm doing sx4 authorisation and then again right rm-133 pm
Old 01-23-2013, 09:27   #3 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Hi,
Click on Backup RPL and post here logs...
Old 01-23-2013, 09:28   #4 (permalink)
Member: 1189402
Sonork: 10000.00
not solved me dear.
Old 01-23-2013, 10:12   #5 (permalink)
.::RAM MOBILE::.'s Avatar
Member: 1681461
Sonork: 100.1637223
Many people posted in this forum about security test failed !
we know that_______
when come security test failed ______
solution_____
1. super sd auth or pmm auth __than write good or modified pm ( must need pm 1 & 309)
or, 2. sd repair ___ super sd auth or pmm auth ____ than write good or modified pm ( must need pm 1 & 309)
My question ______
when we not success by up system
than what can we do for repair security test failed?
yes! we have this solution______
1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl)
2. erase old pm ( go > pm tab > erase )
3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this)
4. Erase pm again (go > pm tab > erase )
5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei)
6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309)
7. erase pm again
8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert)
9. give full factory reset
your phone must come back from security test failed
it is 100% tasted by me.
wbr ; tejaram
Old 01-23-2013, 12:19   #6 (permalink)
Member: 1189402
Sonork: 10000.00
Originally Posted by ..::Angel::.. View Post
Hi,
thx angel
pls help me.
APE PAPUBKEYS HASH:
5E8D0D504A0902E261268C14FCD8A2C9093523BC
( CMT and APE PAPUBKEYS HASH are Identical )
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
OK
Reading : CCC (CMT)
 CCC :  Empty
Reading : HWC (CMT)
 HWC :  Empty
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
 PARTNERC :  Empty
Reading : MDM_KEYS (CMT)
 MDM_KEYS :  Empty
Reading : NPC (APE)
 NPC :  Empty
Reading : VARIANT (APE)
 VARIANT :  Empty
Reading : CCC (APE)
 CCC :  Empty
Reading : HWC (APE)
 HWC :  Empty
Reading : R&D (APE)
OK
Reading : PARTNERC (APE)
 PARTNERC :  Empty
Reading : MDM_KEYS (APE)
 MDM_KEYS :  Empty
NPC CERTIFICATE INFORMATION (CMT):
IMEI           : 353640012243123
PRODUCT CODE   : 0529803
BLUETOOTH ID   : 00:19:79:CF:BD:91
PUBLIC_ID      : 11500210C99F0154874EB81026A2333519E77CE0
PAPUB_KEYS_HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
VARIANT CERTIFICATE INFORMATION (CMT):
PRODUCT CODE   : 0541421
WARNING: PRODUCT CODES MISMATCH
This might cause SECURITY TEST FAILED
in Phones which require them to match
FINISHED READING RPL DATA
 RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\353640012243123\353640012243123_035321.rpl
Old 01-23-2013, 12:21   #7 (permalink)
Member: 1189402
Sonork: 10000.00
we know that_______
solution_____
My question ______
7. erase pm again
wbr ; tejaram
mxkey
Recover CERT for n73 server down.
Old 01-24-2013, 14:40   #8 (permalink)
Member: 1189402
Sonork: 10000.00
conot help me??
angel or sirnibas?
Old 01-29-2013, 12:34   #9 (permalink)
Member: 643472
Sonork: 100.96901
Hi,
Solution is in Backup RPL logs... Read what ATF SW is saying..
Page generated in 0.33241 seconds with 11 queries
