09-30-2014, 14:34 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | <<<< ALL Samsung eMMC Direct Test Points .mmc Files >>>> CPU: MSM8226 eMMC Size: 8GB eMMC BOOT Repair 4.4.2 G7102DXUBNH1 SM-G7102_4.4.2_G7102DXUBNH1.mmc Test Point Picture (ONLY 4 Wires + USB Cable): |
The Following 8 Users Say Thank You to Advance-Box For This Useful Post: |
09-30-2014, 15:53 | #2 (permalink) |
Freak Poster Join Date: Mar 2012 Location: BARNALA
Member: 1734313 Status: Offline Sonork: 100.1620886 Thanks Meter: 70 | sir how to use this procedure......pls explain 1. if this file is to use as sdc file thn why we need to jumpering wires... 2. if we have to solder these wires thn r we to work as emmc write method ????? |
The Following User Says Thank You to mobirepair For This Useful Post: |
09-30-2014, 16:09 | #3 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @mobirepair This is for demonstration Purposes only (just for blah blah...). ALL SM-G7102 can be FIXED using SDC Unbrick Method. (YOU DO NOT NEED eMMC Direct Method from post #1) Even if you remove eMMC from Phone PCB, phone will still BOOT UP via SD CARD. I just put this here because I bought this phone and I took nice pictures of it... and I don't want to waste the effort I made. .mmc Files need to open it via ATF Plus -----> eMMC Tool After you load it there, all will be automatic. B.R. P.S. Easier Method (SDC Ubrick) can be found here: http://forum.gsmhosting.com/vbb/10584791-post8.html You do not need to OPEN Phone, unless phone does not respond to SD Card... |
The Following 7 Users Say Thank You to Advance-Box For This Useful Post: |
10-11-2014, 09:55 | #6 (permalink) |
Freak Poster Join Date: Jan 2008 Location: phone care
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | need i9082 pin out and mmc file Dear atf supporter tnx for usefull post about g7102 its very good.but now i looking for i9082 emmc pin out and repair file for atf please can share it or can tell me any link.....plzzz |
11-10-2014, 07:06 | #10 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | Quote:
12-22-2014, 13:08 | #11 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Br allumts | |
12-23-2014, 13:11 | #12 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | This phone is one that can Unbrick only loocking, read carefully the procedure with TP or also W/O any TP just use Right Sdc file whith Sd Card ORIGINAL like San Disk, Samsung itc..., no FAKE Sd Card tested almoust on 20 devices all unbricked just using Most recent Sdc file and ORIGINAL Sd Card... Read more here: http://forum.gsmhosting.com/vbb/10584791-post8.html BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
02-18-2015, 16:46 | #15 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @abcd9 Why hi-jack bthread of other members?, open you thread and have all aswere you want. For you proble, Use "ATF SUPPORT AREA", put this in the PREFERED and first of ask search inside this, use search button always, last time atfsupport.com BR allumts |
