09-07-2016, 16:41 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: in you are heart Age: 37
Member: 1733871 Status: Offline Sonork: 100.1627020 Thanks Meter: 28 | amsung s7562 deadboot repair error Phone Type : Samsung GT-S7562 CPU Type : Qualcomm MSM7227A Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore (4.0.4) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Phone BATTERY should be CONNECTED!!! 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to the Phone 5. Click RESET JTAG button to check JTAG Connection 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106230E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A5330304103F4D94E0D21DF Flash Description: Samsung JJS00A, 3.64 GiB, SN F4D94E0D, Feb 1998 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91924 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! Last edited by mds nadeem; 09-07-2016 at 16:47. |
07-20-2017, 17:25 | #2 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Bangladesh ,Rajshahi,
Member: 1342044 Status: Offline Thanks Meter: 51 | ATF JTAG v1.0.15.8544 (6/17/2015) Default language ID 0x0409, LR 14 JTAG Interface Connected, S/N 0xF92452B7 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 5/25/2014 6:53:00 PM ================================================== ======== Phone Type : Samsung GT-S7562 CPU Type : Qualcomm MSM7227A Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore (4.0.4) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Phone BATTERY should be CONNECTED!!! 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to the Phone 5. Click RESET JTAG button to check JTAG Connection 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A53303041038E31525640EF Flash Description: Samsung JJS00A, 3.64 GiB, SN 8E315256, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91464 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! Loading AFP (Please Wait)...OK AFP revision 4, compiled 5/25/2014 6:53:00 PM ================================================== ======== Phone Type : Samsung GT-S7562 CPU Type : Qualcomm MSM7227A Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore (4.0.4) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Phone BATTERY should be CONNECTED!!! 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to the Phone 5. Click RESET JTAG button to check JTAG Connection 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Resetting and Exploring JTAG chain...No Devices found in Chain! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A4A53303041038E31525640EF Flash Description: Samsung JJS00A, 3.64 GiB, SN 8E315256, Apr 1997 Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91460 Op/Sec) Restoring MBR Data...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! Saving "..\Logs\Screenshots\2017-07-20_22-17-00.jpg"...OK same brro |
