Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 01-15-2011, 10:01   #1 (permalink)
shaikhaltaf_m's Avatar
Member: 510263
Sonork: altaf
angel brother
Number of Image Files: 3
Forcing Test Mode via BUSCHECK...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 66911452 (0xDC) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 ROM_ID 15
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 12100209
ID DWORD 1 : FDB14650
ID DWORD 2 : 611CF2BD
ID DWORD 3 : 32B81492
ID DWORD 4 : AD248EE6
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 33
SearchForBootstrap_DCT5..
CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 03
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 2400 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 8A31
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Checksum : D5
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :00EC DevID :2400 ExtID :0000 RevID :8A31
RAP3Gv3_algo.fg
First Algo byte : C0
Flash Descriptor
Device ID : 2400
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 01
PAPUB Keys Hash : 0C917F11196FDB7378C18EF7260698CA4489DCA0
Scanning Simlock Type...
OK
PA_SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FlashInfo.RestartMode : 2
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
ERROR : PHONE READ INFO FAILED
Use "BUSCHECK" Button to Force the Phone
into Local Mode... Then "SCANPHONE" after.
For N95, N95-8GB and E90 Phones, you need a
Test Mode Adapter to provide some Extra Power
so that the Phone will go into Local Mode...
ERROR : FAILED TO BACKUP, TRY AGAIN...
Changing MODE : FLASH
BootFlashMode_DCT5
TIME STARTS HERE
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 66911688 (0xC8) bytes returned
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 33
MessageID : C1
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : D5
SendAlgoCode_DCT5..
RAP3Gv3_algo.fg
Flash Descriptor
Device ID : 2400
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Pabub KEY Request
BB Asic Index : 01
START READING RPL DATA
Reading : NPC
OK
Reading : VARIANT
VARIANT : Empty
Reading : CCC
OK
Reading : HWC
OK
Reading : R&D
OK
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\359371037939628\3593710379396 28_12753.rpl
Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.97.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 1178
Entry Point: 0x5057
Page Format : -1
MAX PAGE : 0x00004000
VBATT OFF...
VBATT ON
Setting VBATT Done!...
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 66911720 (0xE8) bytes returned
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 33
MessageID : C1
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : D5
SendAlgoCode_DCT5..
RAP3Gv3_algo.fg
Flash Descriptor
Device ID : 2400
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Pabub KEY Request
BB Asic Index : 01
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
No partition info....
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x36 (54)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x33 (51)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 00000000-000006BF
1 : 000006C0-0001FFFF
2 : 00040000-000BFFFF
3 : 000C0000-0013FFFF
4 : 00140000-0137FFFF
5 : 01380000-0151FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 14 STATUS_NOR_OK_BB5
Block Length : 01
BB ASIC Index : 00
Successfully erased..
Time Taken to Erase : 00:01:17
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDRand2TX
Flashing Speed: 5.00 Mhz
Processing : rm495__07.97.mcusw
Total blocks to write : 1178
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
ContinueFlash_DCT5 Complete
Block Length : 01
BB ASIC Index : 00
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 01:30:49
Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.97.ppm_qa
CMT Type : BB5
Number of Blocks : 471
Entry Point: 0x00BE
Page Format : -1
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x0E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01520000-01DBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:00:28
Processing : rm495__07.97.ppm_qa
Total blocks to write : 471
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:26
Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.97.image_qa_red
CMT Type : BB5
Number of Blocks : 720
Entry Point: 0x00D0
Page Format : -1
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x16 (22)
Block Length : 0x13 (19)
Device Index : 0x00
0 : 01DC0000-0215FFFF
1 : 02160000-03FBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:00:57
Processing : rm495__07.97.image_qa_red
Total blocks to write : 720
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:38
Total Flash Write Time (Flashing Only) : 01:31:54
Total Flashing Time (Booting + Erase + Flashing) : 01:34:38
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 33
MessageID : C1
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : D5
SendAlgoCode_DCT5..
RAP3Gv3_algo.fg
Flash Descriptor
Device ID : 2400
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Pabub KEY Request
BB Asic Index : 01
OK
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
after this nokia logo then switch off
dear angel i rajister sonork id just accept my request
Old 01-15-2011, 10:04   #2 (permalink)
Member: 510263
Sonork: altaf
sorry angel this is 5130 model.
Old 01-16-2011, 07:13   #3 (permalink)
Member: 973412
bro check hw problem
Old 01-16-2011, 11:11   #4 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
@shaikhaltaf_m
1. backup RPL
2. write blank rpl - imei will be 1234
3. power on - and check ?
PS: It is just for test if phone has HW or SW problem
Old 01-16-2011, 17:40   #5 (permalink)
Member: 510263
Sonork: altaf
THANKS COSTEMER IS GONE
I THINK I NEED U 24hr.
GSM Brothers GSM Brothers GSM Mobile Links 3 06-10-2002 10:26
to gsm brothers aliwali Old Legacy Motorola (EMMI) 1 04-13-2002 03:45
I have Sagem unlock cracked by GSM Brothers but don't work!!!1 florinmar Infineon C16X M51 & ARM7 M52 BASED 0 04-01-2002 16:06
gsm-magik : you disturb brother hek Trash 0 01-22-2002 15:11
gsm brothers soft needed boganice x1x to x45/x50 2 01-20-2002 00:40
Page generated in 0.46956 seconds with 11 queries
