06-26-2013, 10:11 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | anyone with a solution to n9 'camera not responding problem' ''THE CAMERA IS NOT RESPONDING.TRY AGAIN OR RESTART THE DEVICE IF THE PROBLEM CONTINUES'',, I have tried almost everything that i know,,factory reset,wipe device,,select mass storage on usb and format on computer,,almost not working,the camera was working before i flash n9, is there any other way i need help please |
06-26-2013, 10:42 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, Full Flash phone with MCU + eMMC file + Factory Set checked in ATF Software. The whole process will take about 20-25 minutes. Make sure battery is charged enough. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
06-26-2013, 12:01 | #4 (permalink) | |
Member: 1507693 Status: Offline Thanks Meter: 131 | Quote:
thanks bro,the batry is fully charged,but as soon as im trying to flash this phone,,a weird problem starts,,, when want to flash again it shows that error,,bro i checked the firmware that i first flashed with,its not same product code,can that be a problem causing this?,i was not aware there are some n9 with 64gb,but mine is 16gb,i think i killed my phone,,i changed almost all usb ports,but phone is no longer detect,but with a wall charger its charging, is there anyway to get it detect so i can flash with right firmware,? | |
06-26-2013, 12:08 | #5 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, are you connecting powered off phone to USB cable? Try to clean phone's USB jack or change USB cable/port. You need to flash with same Product Code and according your phone's mass storage file. BR |
07-02-2013, 15:27 | #8 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Answer this - http://forum.gsmhosting.com/vbb/9527932-post5.html 1st solve the USB recognize problem Br - srinibas |
07-02-2013, 15:43 | #9 (permalink) | |
bro yes,,before usb not recognised ,soon after flashing,i formated the mass memory,i even go to settings and clear device,also factory reset,,bro ANGEL told me to flash again phone with emmc,,then i tried flashing,,the phone is no longer recognised by pc,,so i can not flash it anymore,even charging it on computer,its not charging,but it charges with a wall charger,i can not connect it with pc when its on or when its off,when i connect it it asks for me to select MASS STORAGE,CONNECT AND SYNC,AND CHARGING,,when i select one of the above,it shows not enough power to charge device,then on computer it shows USB NOT RECOGNISED,,i changed usd ports on my laptop,and even desktop ports that are at the back,but still not recognised,,i want to flash it with emmc,but when i switch it off,then click flash,,i connect a switched off phone to usb port,it shows USB NOT RECOGNISED | |
