07-03-2010, 11:14 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | 3110c flash probleb plz ATF help Code: VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27E00007 ID DWORD 1 : 0D5C6E56 ID DWORD 2 : 9CE7DA9C ID DWORD 3 : 41D78FCE ID DWORD 4 : 6C521DAE 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum DD SearchForBootstrap_DCT5.. CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 881C -> M39L0R807 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0020 DevID :881C ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 Flash Descriptor Manufacturer Code : 0020 Device ID : 881C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D Scanning Simlock Type... OK ================================================ SL1/SL2 Phone detected ================================================ FlashInfo.RestartMode : 2 FBUS_TX Timeout... FBUS_TX Timeout... |
07-03-2010, 11:20 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @kabul After flash this means it cannot Factory Reset because phone unit is still dead. Please tell me what firmware version you flashed (and if possible give me the complete logs for flashing). If you are using firmware 7.30 already, then just reflash the phone using 5 Mhz speed and "SKIP ERASE" selected. |
07-03-2010, 11:37 | #3 (permalink) | |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Quote:
using firmware 7.30 already using 5 Mhz speed "SKIP ERASE" selected Bat not sovle thes problem Code: Number of Image Files: 3 ERROR : PHONE READ INFO FAILED Use "BUSCHECK" Button to Force the Phone into Local Mode... Then "SCANPHONE" after. For N95, N95-8GB and E90 Phones, you need a Test Mode Adapter to provide some Extra Power so that the Phone will go into Local Mode... FBUS_TX Timeout... FBUS_TX Timeout... PM 308 Found... 0 FBUS_TX Timeout... FBUS_TX Timeout... PM 308 Found... 0 FBUS_TX Timeout... FBUS_TX Timeout... PM 308 Found... 0 FBUS_TX Timeout... FBUS_TX Timeout... PM 308 Found... 0 ERROR : FAILED TO BACKUP, TRY AGAIN... Changing MODE : FLASH VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27E00007 ID DWORD 1 : 0D5C6E56 ID DWORD 2 : 9CE7DA9C ID DWORD 3 : 41D78FCE ID DWORD 4 : 6C521DAE 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum DD SearchForBootstrap_DCT5.. CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 881C -> M39L0R807 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0020 DevID :881C ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 Flash Descriptor Manufacturer Code : 0020 Device ID : 881C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D START READING RPL DATA Reading : NPC OK Reading : VARIANT OK Reading : CCC OK Reading : HWC OK Reading : R&D OK FINISHED READING RPL DATA RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\358672019369135\358672019369135_33442.rpl FlashInfo.RestartMode : 2 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\rm237__07.30.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 945 Entry Point: 0x453C Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27E00007 ID DWORD 1 : 0D5C6E56 ID DWORD 2 : 9CE7DA9C ID DWORD 3 : 41D78FCE ID DWORD 4 : 6C521DAE 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum DD SearchForBootstrap_DCT5.. CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 881C -> M39L0R807 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0020 DevID :881C ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 Flash Descriptor Manufacturer Code : 0020 Device ID : 881C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D No partition info.... VPP Enabled by Software Using Internal VPP ERASING Skipped ... TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 Processing : rm237__07.30.mcusw Total blocks to write : 945 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : PMM_CONF >> CMT Rootkey Hash CERT : SBIF_CONF ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 16 PROGRAMMING_ERROR_BB5 Block Length : 0F BB ASIC Index : 00 Error Type : 05 Error Spec : 08 Of*****ng Address : 00000400 Expected Content : 0000933D Detected Content : 00009300 Try to change the Flashing clock... Flashing FAILED BB5_WRITE_FlashFile_0 Operations Failed.... | |
07-03-2010, 12:00 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @kabul I see the problem: Of*****ng Address : 00000400 Expected Content : 0000933D Detected Content : 00009300 if you see Address 00000400 <--- This means your RX2 is not connected properly to the phone. 00000400 <-- This is the first address space for the firmware. If you get an error here, then it means your cable is not properly connected or does not have RX2 PIN. Confirm that you have 7-PIN cable (I think you do)... Then check the markings on the phone Pinout,, you will see some slight scratches to where the PINS actually "hit" on the back of the phone. You will notice it is not 100% alligned. Now reconnect the Cable and slightly adjust it accordingly to attempt to make it 100% alligned. Then put rubber band,,, flash... DO NOT SKIP ERASE... B/R |
07-03-2010, 13:11 | #5 (permalink) | |
Freak Poster Join Date: Jun 2010
Member: 1332469 Status: Offline Sonork: 244747 Thanks Meter: 12 | Quote:
07-03-2010, 13:25 | #8 (permalink) | |
Thenks sir, cheng cable flash ok but show only battry icon and blank display flash log; Code: Number of Image Files: 3 ERROR : PHONE READ INFO FAILED Use "BUSCHECK" Button to Force the Phone into Local Mode... Then "SCANPHONE" after. For N95, N95-8GB and E90 Phones, you need a Test Mode Adapter to provide some Extra Power so that the Phone will go into Local Mode... FBUS_TX Timeout... FBUS_TX Timeout... PM 308 Found... 0 FBUS_TX Timeout... FBUS_TX Timeout... PM 308 Found... 0 FBUS_TX Timeout... FBUS_TX Timeout... PM 308 Found... 0 FBUS_TX Timeout... FBUS_TX Timeout... PM 308 Found... 0 ERROR : FAILED TO BACKUP, TRY AGAIN... Changing MODE : FLASH VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27E00007 ID DWORD 1 : 0D5C6E56 ID DWORD 2 : 9CE7DA9C ID DWORD 3 : 41D78FCE ID DWORD 4 : 6C521DAE 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum DD SearchForBootstrap_DCT5.. CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 881C -> M39L0R807 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0020 DevID :881C ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 Flash Descriptor Manufacturer Code : 0020 Device ID : 881C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D START READING RPL DATA Reading : NPC OK Reading : VARIANT OK Reading : CCC OK Reading : HWC OK Reading : R&D OK FINISHED READING RPL DATA RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\358672019369135\358672019369135_51104.rpl FlashInfo.RestartMode : 2 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\rm237__07.30.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 945 Entry Point: 0x453C Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27E00007 ID DWORD 1 : 0D5C6E56 ID DWORD 2 : 9CE7DA9C ID DWORD 3 : 41D78FCE ID DWORD 4 : 6C521DAE 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum DD SearchForBootstrap_DCT5.. CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 881C -> M39L0R807 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0020 DevID :881C ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 Flash Descriptor Manufacturer Code : 0020 Device ID : 881C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x004E (78) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 4B 0 ERASE_AREA_BB5 0x12 Block Length : 0x4B (75) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00020000-0007FFFF 3 : 00080000-000DFFFF 4 : 00100000-001FFFFF 5 : 00200000-0031FFFF 6 : 00320000-0105FFFF 7 : 01060000-01067FFF 8 : 01068000-0107FFFF ERASE_REQUEST_BB5 : 5009120B00000000000000000006BF120B000000000006C00001FFFF120B000000000200000007FFFF120B00000000080000000DFFFF120B00000000100000001FFFFF120B000000002000000031FFFF120B000000003200000105FFFF120B0000000106000001067FFF120B000000010680000107FFFF82 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:39 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm237__07.30.mcusw Total blocks to write : 945 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : PMM_CONF >> CMT Rootkey Hash CERT : SBIF_CONF ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:10 Making delay between files for 5000ms Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\rm237__07.30.ppm_b CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 205 Entry Point: 0x00A6 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27E00007 ID DWORD 1 : 0D5C6E56 ID DWORD 2 : 9CE7DA9C ID DWORD 3 : 41D78FCE ID DWORD 4 : 6C521DAE 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191E65DF CRC 1 : AAF68FDD Checksum 00 SearchForBootstrap_DCT5.. CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 881C -> M39L0R807 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0020 DevID :881C ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 Flash Descriptor Manufacturer Code : 0020 Device ID : 881C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01080000-0151FFFF ERASE_REQUEST_BB5 : 5001120B000000010800000151FFFF88 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:02 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm237__07.30.ppm_b Total blocks to write : 205 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:16 Making delay between files for 5000ms Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\rm237__07.30.image_ora_pl CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 264 Entry Point: 0x00B2 Page Format : 0 MAX PAGE : 0x00004000 File detected Not 128K format.... Converting image to 128k bit..... Converted file created : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\rm237__07.30.image_ora_pl_128k CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 264 Entry Point: 0x00B2 Page Format : 0 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27E00007 ID DWORD 1 : 0D5C6E56 ID DWORD 2 : 9CE7DA9C ID DWORD 3 : 41D78FCE ID DWORD 4 : 6C521DAE 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum DD SearchForBootstrap_DCT5.. CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 881C -> M39L0R807 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0020 DevID :881C ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 Flash Descriptor Manufacturer Code : 0020 Device ID : 881C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01520000-01FDFFFF ERASE_REQUEST_BB5 : 5001120B0000000152000001FDFFFF92 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds >> Time Elapsed 39 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:45 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm237__07.30.image_ora_pl_128k Total blocks to write : 264 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:22 Total Flash Write Time (Flashing Only) : 00:01:50 Total Flashing Time (Booting + Erase + Flashing) : 00:03:23 Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 07.30 07-05-09 RM-237 (c) Nokia. IMEI: 358672019369135 Product code : 0550691 Model : Nokia 3110c ******** Reading SimLock ******** Simlock Version : SIMLOCK SERVER VERSION 63 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK | |
07-04-2010, 07:28 | #10 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @kabul Battery Icon and Blank Display??? Maybe Low Battery? NO need to add erase button now... Many phone is killed by this erase button. You can see already many people having 123456787654321 IMEI caused by other boxes option to "FULL ERASE". And they don't have backup RPL at all. There is a way to erase FULL PM only without erasing FULL Phone. This is what I will put in our software when I finish it. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
07-05-2010, 10:30 | #11 (permalink) | |
07-05-2010, 15:16 | #13 (permalink) |
Freak Poster Join Date: Apr 2007 Location: in ur heart
Member: 481933 Status: Offline Sonork: 100.1582701 Thanks Meter: 107 | IMPOTENT MSG TO ALL IF U DOWNLOAD LATEST VER& INSTALL THIS VERR 5.40 THEN U MUST HAVE UPDATE UR BOX FIREMWARE . I ALSO FACE THIS PROBLEM FBUS_TX Timeout... FBUS_TX Timeout... SO JUST UPDATE UR BOX FIREMWARE AFTERE INTALL NEW VER . THEN TRY & REPORT HERE THANKS WBR VICKY |
05-02-2012, 10:53 | #14 (permalink) |
No Life Poster Join Date: Mar 2012 Location: punjab
Member: 1732025 Status: Offline Sonork: 100.1615024 Thanks Meter: 329 | Hello atf team nokia 3110c boot failed error Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed ERROR: FBUS Boot FAILED |
05-02-2012, 11:06 | #15 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
this is connecetion error bro,,bcoz ur cable does not seem to be working cable..just buy new n modified cable n check pins thanx br | |
