02-07-2015, 11:29 | #1 (permalink) |
Freak Poster Join Date: May 2014
Member: 2185407 Status: Offline Thanks Meter: 20 | asha 201 rm-799 flash stuck |
02-07-2015, 11:31 | #2 (permalink) |
Member: 2185407 Status: Offline Thanks Meter: 20 | Number of Image Files: 3 Processing Image File : rm799__11.95.mcusw Processing Image File : rm799__11.95.ppm_meg Processing Image File : rm799__11.95_008.image_mea12_mtn_za_v4_9p0r2 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 1260000282102815 Original Product Code: 059P0R2 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355186050442472\3551860504424 72_123123.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355186050442472\3551860504424 72_CERTIFICATE_0859B26B.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355186050442472\3551860504424 72_PMM_PROT_A4DE2686.bin Security Code: 073955 Data Sections : 04 Current File : rm799__11.95.mcusw Compile Name: rm799__11.95.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26217864 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: CC39 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A46 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 29D4 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41A3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24903680 bytes Data Checksum: D292 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm799__11.95.ppm_meg Compile Name: package_meg.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 5485356 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41A40000~0x4217FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5482012 bytes Data Checksum: 2FF1 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm799__11.95_008.image_mea12_mtn_za_v4_9p0r2 Compile Name: package_meg_mtn_za.image.fls Image Type : CONTENT Package Data Size : 16125200 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42180000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 16121856 bytes Data Checksum: 9336 Uploading Data Blocks to phone... |
