11-24-2013, 21:55 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: Jamaica
Member: 28559 Status: Offline Thanks Meter: 85 | asha 201 rm-799 simlock test failed phone sim lock failed. how do i fix this? full pm is attached. MCU: V 11.64 07-06-12 RM-799 (c) Nokia IMEI: 355950054389 Model : Nokia 201 Product Serial Number: FDE64BAAH Product Code : 059N287 Module Code : 0205326 Basic Production Code: 059P8Q0 Long Production SN : 0 PPM SW Version : V 11.64 07-06-12 RM-799 (c) Nokia L1 BT MCM Version : 19e2-47026 MCU SW Version : V 11.64 07-06-12 RM-799 (c) Nokia HW Version : 1202 RFIC Version : Dummy RFIC version LCD Version : TPO Content Pack Version : Content: l1_059K563 V 11.64 07-06-12 RM-799 (c) Nokia ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000003000B ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : FAILED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 MASTER_CODE : 0777277642 PHONE_MODE : NORMAL ================================================ Dynamic Camera Configuration ================================================ DCC ID : 0F5B6002 DCC Ver: 002003 Status : OK Changing Phone Mode... (Wait for 10 seconds) SELFT TEST Start.... SELFT TEST Done.... |
11-25-2013, 06:14 | #2 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Use recovery Level 2.- Other way is write Original PM (with 120 area) CLOSED (Not Unlocked) Checkit (need BKP) Paste log Here.- Maybe Angel can Fix your Problem Br P0lac0 |
11-25-2013, 12:14 | #3 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
@ thread starter Your PM looks good , Flash your phone as per product code & scan see this problem solved or not - ST_SIMLOCK_TEST : FAILED Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
11-25-2013, 16:33 | #4 (permalink) | |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | infineon and Simlock recovery Quote:
bad tips. sory p0lac0 | |
