05-19-2013, 11:11 | #1 (permalink) |
Banned Join Date: Nov 2011 Location: okara pakistan
Member: 1696883 Status: Offline Sonork: 100.1623251-JAMIL MOBILE Thanks Meter: 202 | asha 206 rpl corrupt plz help me atf team <<< SOLVED >>> Processing Image File : 6EB4B2F1_rm873__03.58.mcusw Processing Image File : 6080CA4F_rm873__03.58.ppm_m2 Processing Image File : 565D354B_rm873__03.58.image_m2_059Q4F9 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 1250000AA612282D Data Sections : 04 Current File : 6EB4B2F1_rm873__03.58.mcusw Compile Name: rm873__03.58.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26480008 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: ED3A Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A66 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: FA33 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41A7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 25165824 bytes Data Checksum: B696 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : 6080CA4F_rm873__03.58.ppm_m2 Compile Name: package_m2.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 4158212 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41A80000~0x420FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4154868 bytes Data Checksum: A6A3 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : 565D354B_rm873__03.58.image_m2_059Q4F9 Compile Name: package_m2_059Q4F9.image.fls Image Type : CONTENT Package Data Size : 15338768 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42100000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 15335424 bytes Data Checksum: AD81 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:06:02 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 03.58 05-12-12 RM-873 (c) Nokia IMEI Plain : 12345610654321? IMEI Spare : A123456106543210 IMEI SV : 31234561065432105F Phone Model: K 206 Category : Entry Phone Phone Type : RM-873 ================================================ Extended Phone Information ================================================ Product Serial Number: F87A674AH Product Code : 059Q4J7 Module Code : 0205283 Basic Production Code: 059P6H2 Long Production SN : 0 PPM SW Version : V 03.58 05-12-12 RM-873 (c) Nokia M2 BT MCM Version : 19b5-22012 MCU SW Version : V 03.58 05-12-12 RM-873 (c) Nokia HW Version : 1600 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: m2_059Q4F9 V 03.58 05-12-12 RM-873 (c) Nokia Bluetooth ID : 00:02:5B:00:A5:A5 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0000000000000000 PROFILE_BITS : 0000000000040000 ASIC : 11 PROVIDER : Unknown Provider LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Unable to read SP Data.. SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 0FD00F22 DCC Ver: 004004 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK |
05-20-2013, 09:23 | #4 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Pakistan Chakwal
Member: 1652269 Status: Offline Sonork: 100.1638989 Thanks Meter: 54 | fahad see this MCU Version: V 03.58 05-12-12 RM-873 (c) Nokia IMEI Plain : 12345610654321? IMEI Spare : A123456106543210 IMEI SV : 31234561065432105F Phone Model: K 206 Category : Entry Phone Phone Type : RM-873 rpl problem |
