01-12-2014, 20:19 | #1 (permalink) |
Freak Poster Join Date: Jan 2005
Member: 111423 Status: Offline Sonork: 100.1618414 Thanks Meter: 22 | Asha 311 reset security code ATF team . I would ask how do you guys pretend to unlock / reset /mobile asha 311 if the phone are user locked ??? i m trying to reset user lock from one asha 311 i m using usb cable i m searching for fbus and got the correct log from phone but in the end the mobile stay in testmode and for unlock security code i need local mode correct ? but the mobile dosen t pass to local mode ,,, how your tool unlock ? can you guys or support explain ? tank s |
01-12-2014, 20:52 | #2 (permalink) |
Member: 111423 Status: Offline Sonork: 100.1618414 Thanks Meter: 22 | ATF team . I would ask how do you guys pretend to unlock / reset /mobile asha 311 if the phone are user locked ??? i m trying to reset user lock from one asha 311 i m using usb cable i m searching for fbus and got the correct log from phone but in the end the mobile stay in testmode and for unlock security code i need local mode correct ? but the mobile dosen t pass to local mode ,,, how your tool unlock ? can you guys or support explain ? tank s |
01-13-2014, 11:54 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, new flash files are not available on support area and will not be since Nokia is no more providing FULL SETUP files. You can download from NokiaCareSuite or Free Navifirm software via Product Code. BR |
01-13-2014, 20:38 | #6 (permalink) |
Member: 111423 Status: Offline Sonork: 100.1618414 Thanks Meter: 22 | Possible BUG in ATF ? hi i have follow your sugestion ... But it s the same .. i let here the LOG .... after flashing process do not end well ... Code: Number of Image Files: 3 (Mass Memory File Detected) Processing Image File : rm714__03.90.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 325 Entry Point: 0x02D0 Page Format : -1 MAX PAGE : 0x00020000 Processing Image File : rm714__03.90.ppm_c CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 96 Entry Point: 0x0158 Page Format : -1 MAX PAGE : 0x00020000 Processing Image File : 60A4C1E9_rm714__03.90_sd_iberia_2048.fpsimage CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 3479 Entry Point: 0x016E Page Format : -1 MAX PAGE : 0x00020000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 400C1921 ID DWORD 4 : 03032108 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001051 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001060 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 82050004 ID DWORD 1 : FFFB7C40 ID DWORD 2 : 707952BC ID DWORD 3 : 62452714 ID DWORD 4 : 284EAD04 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 2CAC45E2 CRC 1 : 3BC33C8B CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0241 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 355477050152694 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! NPC CERTIFICATE INFORMATION (CMT): IMEI : 355477050152694 PRODUCT CODE : 059R234 WLAN ID : B0:35:8D:C0:85:15 BLUETOOTH ID : B0:35:8D:B9:80:35 PUBLIC_ID : 82050004FFFB7C40707952BC62452714284EAD04 PAPUB_KEYS_HASH: A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28 CCC CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 059R234 HWC CERTIFICATE INFORMATION (CMT): PUBLIC_ID : 82050004FFFB7C40707952BC62452714284EAD04 PRODUCT CODE : 059R234 RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355477050152694\355477050152694_193234.rpl PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28 Reading : ISA-USER... OK! ====================================================== PHONE FIRMWARE VERSION: V 03.90 11-07-12 RM-714 (c) Nokia ====================================================== ImagePath: C:\Users\Ligia\Desktop\nokia navifirm\nokia firmw download\Asha 311 RM-714 ProdCode 059R435 SW 3.90\ ImageFilename: rm714__03.90.mcusw Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00140000 Size : 03D00000 Partition 2 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 04480000 Size : 0AC00000 Partition 3 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 0F080000 Size : 00600000 Partition 4 ID : 0000000B Attribute : 00000001 RW Start Address : 0F680000 Size : 00300000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF0000000400000003000000020014000003D000000000000800000001044800000AC000000000000A000000010F080000006000000000000B000000010F680000003000003C PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0xE9 (233) ERASE Blocks : 0x04 (4) 0 ERASE_AREA_BB5 0x12 Block Length : 0x53 (83) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-000403FF 1 : 000C0000-0013FFFF 2 : 00140000-004BFFFF 3 : 004C0000-0073FFFF 4 : 00740000-0173FFFF 5 : 00160000-0017FFFF 6 : 03E40000-0447FFFF 7 : 0F080000-0F67FFFF 8 : 01740000-02ABFFFF 9 : 02AC0000-02F3FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 00000000000000080000000000000002000000640000000200000002000000010000000000000000 2 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000100000002000000640000000200000002000000010000000000000000 3 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info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uccessfully Erased... Total blocks to write : 325 >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PAPUBKEYS [A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28] >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : MCUSW1 >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : ISA+DYNSW >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : ISA+EXTDRV ImagePath: C:\Users\Ligia\Desktop\nokia navifirm\nokia firmw download\Asha 311 RM-714 ProdCode 059R435 SW 3.90\ ImageFilename: rm714__03.90.ppm_c StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 02F40000-03E3FFFF ERASE_REQUEST_BB5 : 5001120B00030002F4000003E3FFFF04 Successfully Erased... Total blocks to write : 96 ImagePath: C:\Users\Ligia\Desktop\nokia navifirm\nokia firmw download\Asha 311 RM-714 ProdCode 059R435 SW 3.90\ ImageFilename: 60A4C1E9_rm714__03.90_sd_iberia_2048.fpsimage ALG_CONF_REQUEST_BB5 : No Error - 0 (0x00) Total blocks to write : 3479 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000007 Additional Bad : 00000007 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:01:18 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) and stay like this and do not end the flashing procedure ... |
01-13-2014, 21:08 | #8 (permalink) | |
Member: 111423 Status: Offline Sonork: 100.1618414 Thanks Meter: 22 | Do you have a valid reason to support that ? because if i up one release append the same ... here is the log i pass from 3.90 to 5.92 and the result is the same .... Quote:
01-18-2014, 17:13 | #10 (permalink) |
Member: 111423 Status: Offline Sonork: 100.1618414 Thanks Meter: 22 | Asha 311 reset security code [SOLVED] The problem was fixed by reinstall firmware the same version 5.xx but this time using Nokia CareSuite (recovery)... After the recovery process Nokia care make default settings and security code was gonne.... This time the batle was not win by ATF but by NOKIA I regret that ATF do not assume that ATF software since version 10.40 was serious BUGS in the Asha family.... i m sorry 2 that ATF delete my last post when i m expressing my anger whit this support that some times closed itself .... |
01-18-2014, 18:19 | #11 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @Fatmox: Solution still in post #3 of this thread. And is NOT my fault or ATF software if YOU ARE AN IDIOT. You are flashing with WRONG FILES !!! I told you to full flash phone and it will remove security code. That's 100% right. First learn basic things about Nokia flashing, then come up here and blah blah.... WRONG File Selection: rm714__03.90.mcusw - THIS IS MCU rm714__03.90.ppm_c - THIS IS PPM 60A4C1E9_rm714__03.90_sd_iberia_2048.fpsimage - THIS IS NOT CNT FILE, is eMMC SD card file Flash 1000 (One Thousand) Times with these files and it won't remove the security code or make factory set... RIGHT File Selection: rm714__03.90.mcusw - THIS IS MCU rm714__03.90.ppm_c - THIS IS PPM rm714__03.90_image_xxx_059xxxx - THIS IS CNT FILE, and NOT eMMC SD card file Flashing this file will remove all USER DATA including SECURITY CODE of Phone There is NO BUG in flashing Nokia Asha Phones via ATF Software. But is the BUG in yourself... You made the mistake twice in selecting files with 3.90 and 5.92 both versions and crying over ATF Software.... About your last post: I deleted that post because YOU HAVE GOT NO RIGHT to be ANGRY here FOR YOUR VERY OWN MISTAKE. And I suggest you watch your words before posting, because this could lead to your box be BLOCKED forever... |
01-18-2014, 20:05 | #12 (permalink) |
Member: 111423 Status: Offline Sonork: 100.1618414 Thanks Meter: 22 | Tanks for warnig me about the stupid mistake that i have made ... but i think your response is a litle late ... no ? but you only advice after... and that i think that is bad from you guys ... yes have your rigth ... I see that i have made ch*t whit the files ... about the blocking ... well i think that is xtreme ... no ? i loose but you may loose a cust... 2 in the end i m not compare with the numbers ... even you must understand my angry because i have try and try, i even write PM asking for help and you guys silent..... do you like asking help and give nothing as the awnser ? |
