08-27-2015, 07:02 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Asha 500 Rm-934.. dead after flash.. need help! need help here... Unit : Asha 500 RM-934 Problem : Security Code Tries : Download flash file (same product code) after flashing, handset is not powering on... need help... thanks! Code: Logs:Number of Image Files: 3 Processing Image File : rm934_14.0.6.mcusw.fls Processing Image File : rm934_14.0.8_059S9W1_s1_2088_08_453672.rofs.fls Processing Image File : rm934_14.0.8_059S9W1_s1_2088_08_453672.image.fls AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Infineon Boot: F0161942010213030101CAB21209825AD092599CC100FFFF CPU Type: Intel XG221 Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Boot Successful... Unique Data: CAB21209825AD092 Original Product Code: 059V524 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\352362060332705\352362060332705_15412.rpl Current File : rm934_14.0.6.mcusw.fls Number of Images: 2 rm934_14.0.6.mcusw.fls.fls rm934_14.0.6.mcusw.fls.fls Processing Data Block 0x00 Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x01 Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x40060000~0x401BFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x40340000~0x423B6496 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x47E00000~0x47E3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Current File : rm934_14.0.8_059S9W1_s1_2088_08_453672.rofs.fls Number of Images: 1 rofs_ebl_psi.fls Processing Data Block 0x00 Erase Block: 0x42880000~0x4353553A Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm934_14.0.8_059S9W1_s1_2088_08_453672.image.fls Number of Images: 1 rm934_14.0.8_059S9W1_s1_2088_08_453672.image.fls.image.fls Processing Data Block 0x00 Erase Block: 0x43800000~0x4605FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x47E40000~0x47F1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Total Flashing Time (Erase + Flashing) : 00:02:54 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) |
05-22-2016, 14:41 | #2 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Ghaziabad, India
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | I'm also facing this problem set had phone lock So, I flashed with 059V5G3 product code flash file set dead then, flash with same product code 059S9W9 flash file but set is still dead Code: AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Infineon Boot: F016194200021C030101CAB21A0982268CACF7716700FFFF CPU Type: Intel XG221 Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Boot Successful... Unique Data: CAB21A0982268CAC Original Product Code: 059S9W9 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\351747061881323\351747061881323_70254.rpl Current File : rm934_14.0.6.mcusw.fls Number of Images: 2 rm934_14.0.6.mcusw.fls.fls rm934_14.0.6.mcusw.fls.fls Processing Data Block 0x00 Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x01 Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x40060000~0x401BFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x40340000~0x423B6496 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x47E00000~0x47E3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Current File : rm934_14.0.6_059S9W9_i1.rofs.fls Number of Images: 1 rofs_ebl_psi.fls Processing Data Block 0x00 Erase Block: 0x42880000~0x431DF906 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm934_14.0.6_059S9W9_i1.image.fls Number of Images: 1 rm934_14.0.6_059S9W9_i1.image.fls.image.fls Processing Data Block 0x00 Erase Block: 0x43800000~0x459DFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x47E40000~0x47F1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Total Flashing Time (Erase + Flashing) : 00:02:11 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) WARNING: Phone is not in the Required Mode... Disconnect the Phone and Power it Up Manually. Scanning USB Ports... ====================================================== ERROR: Active Phone Handle was NOT DETECTED ====================================================== TIP: Make sure that Phone USB Connection Mode is OVI Suite Mode or PC Suite Mode ====================================================== |
05-25-2016, 08:34 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Its because you downgrade the PPM , Flash with higher PPM , Search in section about it Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
