07-25-2013, 23:28 | #1 (permalink) |
Registered User Join Date: Apr 2008 Location: sadiqsajan
Member: 759011 Status: Offline Sonork: 164643 (server.sonork.com Thanks Meter: 152 | how to remove N900 enter code to remove 00:55:07 : 2. Connect the USB Cable to the PHONE Micro USB Port 00:55:07 : 3. Connect the USB Cable to the PC USB Port 00:55:07 : 00:55:18 : Communication Link Established! 00:55:18 : Reading Product Info... 00:55:18 : 00:55:18 : Product Code : RX-51 00:55:18 : Hardware Revision : 2101 00:55:18 : Software Release : RX-51_2009SE_21.2011.38-1.002_PR_002 00:55:18 : Software Platform : MAEMO 00:55:18 : 00:55:18 : Sending xloader (14848) bytes... 00:55:19 : Sending secondary (109440) bytes... 00:55:19 : Sending kernel (1746688) bytes... 00:55:22 : Sending cmt-2nd (81408) bytes... 00:55:22 : Sending cmt-algo (519808) bytes... 00:55:22 : Sending cmt-mcusw (5966464) bytes... 00:55:24 : Sending rootfs (190316544) bytes... 00:55:35 : 00:55:35 : Device Status: Erasing FLASH Areas... 00:56:21 : Device Status: Programming FLASH Areas... 00:56:49 : Total Flashing Time (Erase + Flashing) : 00:01:40 00:56:49 : (Booting time is NOT Included) 00:56:49 : 00:56:49 : Waiting for Phone to Start-Up..(Max 150 seconds) 00:56:49 : 00:57:04 : 00:57:04 : SW: RX-51_21.2011.38.1 V 0.0.000 RX-51 (c) NOKIA 00:57:06 : 00:57:06 : SW: RX-51_21.2011.38.1 V 0.0.000 RX-51 (c) NOKIA 00:57:07 : 00:57:09 : 00:57:09 : SW: RX-51_21.2011.38.1 V 0.0.000 RX-51 (c) NOKIA 00:57:09 : IMEI: 356938033452989 00:57:09 : CONFIG KEY : 0000000000000000 00:57:09 : PROVIDER KEY : 2440700000000000 00:57:09 : NETWORK NAME : Nokia Default;Finland 00:57:09 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 00:57:09 : SIMLOCK TABLE : 00:57:09 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 00:57:09 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 00:57:09 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 00:57:09 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 00:57:09 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 00:57:09 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 00:57:09 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 00:57:09 : SIMLOCK STATE : Not Locked 00:57:09 : FACTORY SET TO : Full Factory Set 00:57:10 : OK 00:57:10 : FACTORY SET TO : User Data 00:57:10 : OK 00:57:10 : FACTORY SET TO : Leave Factory 00:57:10 : OK 00:57:10 : FACTORY SET TO : Service Center 00:57:10 : OK 00:57:10 : FACTORY SET TO : Software Upgrade 00:57:10 : OK 00:57:10 : FACTORY SET TO : Production Tune 00:57:10 : OK 00:57:10 : 00:57:10 : 00:57:10 : ERROR: Life timer Reset Failed |
The Following User Says Thank You to sadiq123 For This Useful Post: |
07-25-2013, 23:30 | #2 (permalink) |
Member: 759011 Status: Offline Sonork: 164643 (server.sonork.com Thanks Meter: 152 | how to remove N900 enter code to remove alrdy full flash atf box and infenty best dongle but not remove cod help me |
07-27-2013, 19:39 | #3 (permalink) |
Member: 759011 Status: Offline Sonork: 164643 (server.sonork.com Thanks Meter: 152 | how to remove N900 enter code to remove alrdy full flash atf box and infenty best dongle but not remove cod help me hello 3 day not slove my problem help me how to slove this problem full flash 2 files 1 and 2 files meemo use but deta delet? |
07-28-2013, 06:20 | #4 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
07-28-2013, 19:10 | #5 (permalink) |
Member: 759011 Status: Offline Sonork: 164643 (server.sonork.com Thanks Meter: 152 | how to remove N900 enter code to remove Need to flash with eMMC file to reset security code how to flash give me idiya amd give me emmc files urgent |
07-28-2013, 20:35 | #6 (permalink) | |
Freak Poster Join Date: Dec 2012
Member: 1848106 Status: Offline Thanks Meter: 16 | Quote:
RX-51_2009SE_10.2010.13-2.VANILLA_PR_EMMC_MR0_ARM.bin RX-51_2009SE_10.2010.19-1_PR_COMBINED_MR0_ARM.bin << Global Release (Will vary depending on which one you download) Move both .bin files to C:\Program Files\maemo\flasher-3.5 Turn off N900. Connect MicroUSB cable but not N900. Whilst holding “U” on N900's keyboard, attach to MicroUSB. The Nokia logo will appear and a USB icon in top right corner. Do not at any point disconnect the cable or restart N900 until finished. On the PC, click Start>Run>CMD. You’ll see a black box appear. Type or copy and paste cd\program files\maemo\flasher-3.5 Type or copy and paste PR1.2 >> flasher-3.5 -F RX-51_2009SE_10.2010.19-1_PR_COMBINED_MR0_ARM.bin -f Leave it for a couple of minutes whilst it flashes your N900 with PR1.2. Wait until it says “CMT Flashed successfully”. Now copy and paste flasher-3.5 -FRX-51_2009SE_10.2010.13-2.VANILLA_PR_EMMC_MR0_ARM.bin -f -R Wait for it to finish it’s thing. You’ll know it’s finished when it says N900 will attempt to restart. If N900 hasn’t already restarted, restart it manually. Congratulations, you are now on PR1.2 / Have hard reset N900. THIS METHOD WORK FOR ME USE IT. | |
The Following User Says Thank You to mobilefixfult For This Useful Post: |
07-29-2013, 00:10 | #7 (permalink) |
Member: 759011 Status: Offline Sonork: 164643 (server.sonork.com Thanks Meter: 152 | how to remove N900 enter code to remove frist files mcu RX-51_2009SE_21.2011.38-1.002_PR_COMBINED_002_ARM scond files mmc idyia give me but geive me emmmc files |
