07-22-2014, 14:29 | #31 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Brasil Salvador-Bahia
Member: 422649 Status: Offline Sonork: não Thanks Meter: 27 | Thank you for your help . |
07-22-2014, 18:54 | #33 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Br allumts | |
07-22-2014, 18:59 | #34 (permalink) | |
Now from "Device Manager" select one by one the 2 ATF USB DRIVER then "UPDATE DRIVERS" and manually put the Directory where you have folder with NEW DRIVER, if for x32 select these if for X64 select these. Warning, with X64 in Xp sp3 can be not run good how 32Bit XP, Br allumts | |
07-22-2014, 23:32 | #35 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @allumts I already put support CPU List in Page 1 Post 1 of this thread. If CPU is not there, then it is not supported. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
07-23-2014, 14:03 | #37 (permalink) | |
Br allumts | |
07-23-2014, 23:02 | #39 (permalink) | |
CPU: 32bit Qualcomm Snapdragon 800 MSM8974AB Br allumts | |
07-24-2014, 10:04 | #41 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | |
08-01-2014, 00:05 | #44 (permalink) |
Crazy Poster Join Date: Jul 2008 Location: bolivia
Member: 807029 Status: Offline Sonork: 100.1650872 Thanks Meter: 2 | hello factory the atf nitro my problem. ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.60 AdvanceBox SN : xxxxxxxxxxxxxxxxxxxxx ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done format my pc .. then install the new version 11.60 Now I can not change my atf .. even though it was already activated long ago. server does not work for now or what? I need some urgent information Greetings atf team |
