Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > Advance-Box
Old 05-27-2010, 20:34   #1 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
ATF 5.20 Update!! INFINEON, Standalone DCT4+ RSA, Real SX4 etc - Public Discussion:
ATF [Advance Turbo Flasher] Version 5.20 Update!! 28 May 2010!!
[DCT4 INFINEON Engine]
First in the World 3rd Party Box to Fully Support FULL Flashing, DEAD PHONE Flashing and CROSS Flashing DCT4 Infineon Chipsets Supports ALL DCT4 Infineon Phones in the Market !!! (Original Nokia Phones Only)
Current DCT4 Infineon Phones:
  • 1202 (RH-111) XGOLD 101/102
  • 1203 (RH-111) XGOLD 101/102
  • 1280 (RM-647) XGOLD 110
  • 1616-2 (RH-125) XGOLD 110
  • 1800 (RM-653) XGOLD 110
Partial Flashing (PPM and CNT only) is fully Supported.
Upgrade/Downgrade Firmware is not a problem.
Unique Fast Phone Booting Method (No need to press Power Button).
Compatible with regular FBUS Cables:
- 1616-2, 1280 and 1800 will work with regular 1616 FBUS cable
- 1202 and 1203 will work with regular FBUS cable or Easy Cable with RED WIRE
First in the world support for Infineon "CROSS-FLASHING" on same CPU Platform:
1202 can be Cross-Flashed with 1203 and vice versa
1616-2 can be Cross-Flashed with 1800 and vice versa
1616-2 and 1800 can EVEN be flashed with 1280 firmware, but only for testing .
DEAD PHONE Flashing is also FULLY supported (Software Problems Only)
Full Factory Reset for ALL DCT4 Infineon Chipsets
[BB5 Turbo Engine]
  • Multi SX4 Card Servers are now available (Original SX4 Cards)
  • Read and Write Camera Configuration is now Activated
  • Customized PM Read/Write is now Added (For reading specific sub fields)
  • Flash Mode Booting was adjusted to be more compatible with the 6700c
  • BB5 SL1 and SL2 Downgrade is now Activated
  • BB5 Self Test is now Activated
New Products Added in Nokia.ini
  • C1-00 RM-689
  • C3-00 RM-614
  • C5-00 RM-645
  • C6-00 RM-612
  • C6-01.1 RM-624
  • E5-00 RM-632
  • N8-00 RM-596
  • X2-00 RM-618
  • X3-01 RM-687
  • X3-01 RM-639
  • X6-00.1 RM-551
  • X6-00m RM-552
[DCT4+ Engine]
Stand Alone ASIC-11 RSA Forgery Unlocking and Relocking is now supported
Phone Model Support List:
Supported NOKIA models:
1110i, 1112b, 1200, 1202, 1208, 1208b, 1209, 1600b,
1661, 1662, 1650, 1680 Classic, 1680 Classic-2b, 2220
Slide, 2310, 2320 Classic, 2320 Classic-2b, 2323 CLassic,
2330 Classic, 2600, 2600a, 2610, 2610b, 2626, 2630, 2630b,
2660, 2660b, 2680 Slide, 2720 Fold, 2760, 2760b, 2760h, 5000,
5030 XM, 6030b,6060V,6060V, 7070 Prism, 7100 Supernova
DCT4 Self Test is now Activtated
[iTablet Engine]
  • Bug fixed for "Flash File Not Found" error in N900 USB Flashing
Changing Skin now is ENABLE!
Installation Path now set to Root directory (To avoid Windows 7 conflict).
ATF [Advance Turbo Flasher] official thread for UPDATES:
http://forum.gsmhosting.com/vbb/5893585-post14.html
Buy only from ATF [Advance Turbo Flasher] authorized resellers:
ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
ATF [Advance Turbo Flasher] official web sites:
International - http://www.advance-box.com/
ATF [Advance Turbo Flasher] official support forums:
World Wide: Advance Turbo Flasher - GSM-Forum
Indonesia: ATF (Advance Turbo Flasher))
Philippine: Gsmph
Syria: Arabic Support (Syria) GsmVIP
Chinese support forum : ATF Box
Vietnam: Saigonmobile
The Master Piece
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
Old 05-27-2010, 20:41   #2 (permalink)
aswancamel's Avatar
Member: 303402
Great update
thanks ATF, the best fbus flashing
aswancamel
Old 05-27-2010, 20:54   #3 (permalink)
Burebista's Avatar
Member: 235325
Sonork: 100.1593552
Heheee,
I was waiting for this upgrade.
Tomorrow I'll test it
Regards!
Old 05-27-2010, 20:55   #4 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
master piece
thanx
Old 05-27-2010, 21:01   #5 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
Thanks ATF Team
End of waiting DCT4 Infineon Phones Support Fbus Flashing.
All Is Well
Br.
Shashank
Old 05-27-2010, 21:02   #6 (permalink)
dreams_bd's Avatar
Member: 772645
Sonork: 100.1591509
Nice update ATF. If make your continous update and new protocol. Then your product will be a new milestone in nokia market. I hope you will be beter in future.
Old 05-27-2010, 21:18   #7 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
C5-00 Full Flashing AT 52 SEC!!
Processing Image File : C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-645\rm645_031.022_prd.core.fpsx
CMT Type : BB5
CMT Algorithm : XSR 1.6
CMT Supported Hardwares :
                         > 4003192102001104
                         > 400C192102001104
                         > 6003192102001104
                         > 600C192102001104
                         > 6003192102011104
                         > 600C192102011104
                         > 6003192102021104
                         > 600C192102021104
                         > 600C192102031104
Secondary Sending Speed    : 650000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 13000000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  428
Entry Point:  0x01E2
Page Format : -1
MAX PAGE : 0x00040000
Changing MODE : FLASH
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
                  TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000003
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010007
     ID DWORD    3 : 600C1921
     ID DWORD    4 : 02031104
  2  ROM_ID 15
     Block Length  : 5  (05)
     ID DWORD    0 : 00000C35
  3  ROM_ID 15
     ID DWORD    0 : 00000C30
  4  PUBLIC_ID 12
     ID DWORD    0 : 27E00012
     ID DWORD    1 : 2C770E49
     ID DWORD    2 : DECA7C54
     ID DWORD    3 : 3D9607FE
     ID DWORD    4 : 65DC805E
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : E693EF0D
     CRC         1 : AC22615B
Checksum           CC
BootCodeLen : 61
SearchForBootstrap_DCT5..
CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 05
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> not detected
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 0020 ->
   Device ID         : 0040 -> Type not in database
   Revision ID       : 0031
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> not used
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Revision ID       : 0031
 Checksum   : 45
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031
 RAPUv11_XSR17_alg.fg
First Algo byte : 56
Flash Descriptor
   Device ID         : 0040
   Revision ID       : 0000
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPP INFO :
C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            BB ASIC Index     : 0x00 CMT
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00020000
            Spare             : FFFFFFFF
            Num Partitions    : 0004
            Partition    1
              Attribute       : 00000002
              Start Address   : 000A0000
            Partition    2
            Partition    3
            Partition    4
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF000000040000000300000002000A0000030A000000000004000000020314000007D0000000000008000000010AE40000048000000000000A000000010F640000003C000036
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0x004F  (79)
ERASE Blocks :  0x0002  (2)
erase blocks : 2
CurrPos : 03
CurrEraseLen : 1B
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x1B (27)
            Device Index     : 0x00
               0             : 00020000-0003FFFF
               1             : 00060000-004DFFFF
               2             : 008E0000-0AE3FFFF
CurrPos : 20
CurrEraseLen : 2F
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
             Format Info ID   :0x02000000
             Format Info      :000000000000000A0000000000000002000000640000000B0000000200000001000000000000
ERASE_REQUEST_BB5 : 5003120B000300000200000003FFFF120B00030000060000004DFFFF120B000300008E00000AE3FFFFCF
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00000001
          Additional Bad    :  00000001
          Correctable ECC   :  00000000
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000000000002000000640000000B000000020000000100000000000033
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Successfully erased..
Time Taken to Erase : 00:00:01
Is Flashing CLOCK AUTO : 0
Processing  : rm645_031.022_prd.core.fpsx
Total blocks to write : 428
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : SOS+PMML
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS
>>  CMT Rootkey Hash CERT : GENIO_INIT
>>  CMT Rootkey Hash CERT : SOS*UPDAPP
>>  CMT Rootkey Hash CERT : SOS*DSP0
>>  CMT Rootkey Hash CERT : LDSP
>>  CMT Rootkey Hash CERT : SOS*ISASW
>>  CMT Rootkey Hash CERT : SOS+CORE
>>  CMT Rootkey Hash CERT : SOS+ROFS1
ContinueFlash_DCT5 Complete
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Continue Flash Complete :  : No Error - 0 (0x00)
Time Taken to Flash  : 00:00:32
Processing Image File : C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-645\rm645_031.022_C00.01_DEFAULT_prd.rofs3.fpsx
CMT Type : BB5
                         > 4003192102001104
                         > 400C192102001104
                         > 6003192102001104
                         > 600C192102001104
                         > 6003192102011104
                         > 600C192102011104
                         > 6003192102021104
                         > 600C192102021104
                         > 600C192102031104
Number of Blocks :  5
Entry Point:  0x00E7
Page Format : -1
MAX PAGE : 0x00000E00
No RESTORE CERTIFICATE FOUND IN IMAGE FILE
No partition info....
StartErase_DCT5...
BlockLength  :  0x000E  (14)
ERASE Blocks :  0x0001  (1)
erase blocks : 1
CurrPos : 03
CurrEraseLen : 0B
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 0A040000-0AE3FFFF
ERASE_REQUEST_BB5 : 5001120B0003000A0400000AE3FFFFE5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Time Taken to Erase : 00:00:00
Processing  : rm645_031.022_C00.01_DEFAULT_prd.rofs3.fpsx
Total blocks to write : 5
>>  CMT Rootkey Hash CERT : SOS+ROFS3
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Time Taken to Flash  : 00:00:00
Processing Image File : C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-645\rm645_031.022_17.01_Thai_prd.rofs2.fpsx
CMT Type : BB5
                         > 4003192102001104
                         > 400C192102001104
                         > 6003192102001104
                         > 600C192102001104
                         > 6003192102011104
                         > 600C192102011104
                         > 6003192102021104
                         > 600C192102021104
                         > 600C192102031104
Number of Blocks :  144
Entry Point:  0x00E7
Page Format : -1
StartErase_DCT5...
erase blocks : 1
CurrPos : 03
CurrEraseLen : 0B
            Device Index     : 0x00
               0             : 06D40000-0A03FFFF
ERASE_REQUEST_BB5 : 5001120B00030006D400000A03FFFFF9
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Processing  : rm645_031.022_17.01_Thai_prd.rofs2.fpsx
Total blocks to write : 144
>>  CMT Rootkey Hash CERT : SOS+ROFS2
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Time Taken to Flash  : 00:00:12
Processing Image File : C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-645\rm645_031.022_U000.000_prd.uda.fpsx
CMT Type : BB5
                         > 4003192102001104
                         > 400C192102001104
                         > 6003192102001104
                         > 600C192102001104
                         > 6003192102011104
                         > 600C192102011104
                         > 6003192102021104
                         > 600C192102021104
                         > 600C192102031104
Entry Point:  0x00E7
Page Format : -1
StartErase_DCT5...
erase blocks : 1
CurrPos : 03
CurrEraseLen : 0B
            Device Index     : 0x00
               0             : 0AE40000-0F63FFFF
ERASE_REQUEST_BB5 : 5001120B0003000AE400000F63FFFF80
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Processing  : rm645_031.022_U000.000_prd.uda.fpsx
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Time Taken to Flash  : 00:00:01
Total Flash Write Time (Flashing Only) : 00:00:46
Total Flashing Time (Booting + Erase + Flashing) : 00:00:52
FlashInfo.RestartMode : 2
The Following 7 Users Say Thank You to gsmfun For This Useful Post:
Old 05-27-2010, 21:29   #8 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
X3-00 Full Flashing Only 28 Sec now!!
Processing Image File : C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-540\rm540__04.11.mcusw
CMT Type : BB5
                         > 020C192102034000
                         > 0203192102034000
                         > 020C192102034100
                         > 0203192102034100
                         > 0203192102054100
                         > 020C192102054100
Secondary Sending Speed    : 3250000Hz
Program Sending Speed      : 19500000Hz
Number of Blocks :  136
Entry Point:  0x0259
Page Format : -1
BootFlashMode_DCT5
                  TIME STARTS HERE
  1  SYSTEM_ASIC_ID 01
     ID DWORD    0 : 00000001
     ID DWORD    2 : 00000001
     ID DWORD    3 : 020C1921
     ID DWORD    4 : 02034100
  2  ROM_ID 15
     ID DWORD    0 : 00001040
  3  ROM_ID 15
     ID DWORD    0 : 00001030
  4  PUBLIC_ID 12
     ID DWORD    0 : 2EE00016
     ID DWORD    1 : 82670E49
     ID DWORD    2 : A672F973
     ID DWORD    3 : 1AB433C7
     ID DWORD    4 : 5FC993F8
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Hash          :  7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
  7  ROM_ID 15
     CRC         0 : 67E82268
     CRC         1 : F29CEA60
Checksum           D0
BootCodeLen : 61
CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg
 MessageID  : C1
 SubBlocks  : 05
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 01
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0030 -> K5W1G13ACB
   Revision ID       : 0321
 Checksum   : 27
SendAlgoCode_DCT5..
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0030 ExtID :0000 RevID :0321
 RAP3Gv40_XSR17_alg.fg
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   Size              : 00800000  (8388608)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPP INFO :
C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_XSR17_alg.fg
Algo Loader Sent...
FUR control Ok
Using Internal VPP
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
Partition Info
            Device Index      : 0x00
            Partition Version : 00010000
            Spare             : FFFFFFFF
            Partition    1
            Partition    2
            Partition    3
            Partition    4
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9
StartErase_DCT5...
BlockLength  :  0x00E1  (225)
ERASE Blocks :  0x0004  (4)
erase blocks : 4
CurrPos : 03
CurrEraseLen : 4B
            Block Length     : 0x4B (75)
            Device Index     : 0x00
               0             : 00020000-000203FF
               1             : 00060000-0009FFFF
               2             : 000A0000-0025FFFF
               3             : 003E0000-005DFFFF
               4             : 005E0000-010DFFFF
               5             : 01EC0000-01EDFFFF
               6             : 027C0000-02CBFFFF
               7             : 077C0000-07B3FFFF
               8             : 010E0000-01EBFFFF
CurrPos : 50
CurrEraseLen : 2F
            Device Index     : 0x00
             Format Info      :0000000000000008000000000000000200000064000000020000000200000001000000000000
CurrPos : 81
CurrEraseLen : 2F
     2   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
             Format Info      :000000000000000A000000010000000200000064000000020000000200000001000000000000
CurrPos : B2
CurrEraseLen : 2F
     3   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
             Format Info      :000000000000000B000000000000000200000064000000020000000200000001000000000000
ERASE_REQUEST_BB5 : 5009120B00030000020000000203FF120B000300000600000009FFFF120B000300000A00000025FFFF120B000300003E0000005DFFFF120B000300005E0000010DFFFF120B00030001EC000001EDFFFF120B000300027C000002CBFFFF120B000300077C000007B3FFFF120B000300010E000001EBFFFF3D
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
ERASE_REQUEST_BB5 : 5001192F0003000000000200000000000000080000000000000002000000640000000200000002000000010000000000003E
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000100000002000000640000000200000002000000010000000000003B
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B0000000000000002000000640000000200000002000000010000000000003B
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Processing  : rm540__04.11.mcusw
Total blocks to write : 136
>>  CMT Rootkey Hash CERT : UPDAPP
>>  CMT Rootkey Hash CERT : DSP0
>>  CMT Rootkey Hash CERT : MCUSW
>>  CMT Rootkey Hash CERT : MCUSW1
>>  CMT Rootkey Hash CERT : ISA+DYNSW
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Processing Image File : C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-540\rm540__04.11.ppm_s
CMT Type : BB5
                         > 020C192102034000
                         > 0203192102034000
                         > 020C192102034100
                         > 0203192102034100
                         > 0203192102054100
                         > 020C192102054100
Number of Blocks :  32
Entry Point:  0x011D
Page Format : -1
Partition Info
            Device Index      : 0x00
            Spare             : FFFFFFFF
            Partition    1
            Partition    2
            Partition    3
            Partition    4
StartErase_DCT5...
erase blocks : 1
CurrPos : 03
CurrEraseLen : 0B
            Device Index     : 0x00
               0             : 01EE0000-027BFFFF
ERASE_REQUEST_BB5 : 5001120B00030001EE0000027BFFFF74
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Processing  : rm540__04.11.ppm_s
Total blocks to write : 32
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Time Taken to Flash  : 00:00:03
Processing Image File : C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-540\rm540__04.11.image_s_0592263_001
CMT Type : BB5
                         > 020C192102034000
                         > 0203192102034000
                         > 020C192102034100
                         > 0203192102034100
                         > 0203192102054100
                         > 020C192102054100
Number of Blocks :  54
Entry Point:  0x0154
Page Format : -1
Partition Info
            Device Index      : 0x00
            Spare             : FFFFFFFF
            Partition    1
            Partition    2
            Partition    3
            Partition    4
StartErase_DCT5...
BlockLength  :  0x003F  (63)
erase blocks : 2
CurrPos : 03
CurrEraseLen : 0B
            Device Index     : 0x00
               0             : 02CC0000-077BFFFF
CurrPos : 10
CurrEraseLen : 2F
            Device Index     : 0x00
ERASE_REQUEST_BB5 : 5001120B00030002CC0000077BFFFF90
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Processing  : rm540__04.11.image_s_0592263_001
Total blocks to write : 54
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Time Taken to Flash  : 00:00:06
Total Flash Write Time (Flashing Only) : 00:00:22
Total Flashing Time (Booting + Erase + Flashing) : 00:00:28
The Following 3 Users Say Thank You to gsmfun For This Useful Post:
Old 05-27-2010, 21:39   #9 (permalink)
Crazy Poster
Member: 1240161
Sonork: 100.1613544
Just another First in the World story from the Best Team, where great news always comes from!
"Ang galing mo Pinoy!" .. always on the top of the EDGE!
Old 05-27-2010, 21:43   #10 (permalink)
digiphone's Avatar
Member: 878925
Sonork: ;-)
that is real great work ,-
full nokia dct4 & bb5 support is good step .
thanks .
Old 05-27-2010, 22:12   #11 (permalink)
digiphone's Avatar
Member: 878925
Sonork: ;-)
Make sure that you plugged the cable to the
RJ-45 Port Marked << EXTENSION >>
EXTENSION Port is for DCT4 Infineon Phones Flashing ?
Old 05-27-2010, 22:16   #12 (permalink)
Advance-Box's Avatar
Member: 651945
@digiphone
Yes, the Primary use for the Extension Port is for DCT4 Infineon Flashing.
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 05-27-2010, 22:28   #13 (permalink)
digiphone's Avatar
Member: 878925
Sonork: ;-)
i see more future & many Skins
but there is one question about dc4 manual Code Calc , is for all Dct4 and + ?
and i see flash file download is supported , but it's Ready ?
Best regards .
Old 05-27-2010, 23:50   #14 (permalink)
Member: 272532
really nice update ATF teams, thx.
Old 05-28-2010, 00:29   #15 (permalink)
Little_Master's Avatar
Member: 1205146
Sonork: 100.1601660
Link to download please ????
LITTLE MASTER
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 10 03-10-2012 13:19
unlocking nokia 5110 version5.12 5.20 tomi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 9 02-25-2011 09:16
How unlock new nokia5110 version 5.20 ? Tomas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 01-21-2011 06:45
please help soft 5.20 Swiety Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-24-1999 01:15
How unlock Nokia version 5.20 Tomas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-17-1999 17:35
Powered by Searchlight © 2012 Axivo Inc.
- GSM Hosting Ltd. - 1999-2011
Page generated in 1.17652 seconds with 10 queries
