12-25-2013, 17:04 | #136 (permalink) |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | Code: Default language ID 0x0409 JTAG Interface Connected, S/N 0xF7XXXX8E Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 12/1/2013 4:18:00 PM ========================================================== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 15 Seconds after First Vibration <--- Very Important 4. Disconnect USB Cable from Phone 5. Click RESTORE BOOT Button Again OK Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 15 Seconds after First Vibration <--- Very Important 4. Disconnect USB Cable from Phone 5. Click RESTORE BOOT Button Again OK Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 14275774 - LOCKED PUK LEVEL 1: 84558050 - LOCKED PIN LEVEL 2: 36620280 PUK LEVEL 2: 75775949 PIN LEVEL 3: 42631834 PUK LEVEL 3: 29807434 PIN LEVEL 4: 60200660 PUK LEVEL 4: 12849381 PIN LEVEL 5: 06835791 PUK LEVEL 5: 27656747 ========================= Reading Unlock Codes Done! ============================================================================ 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ============================================================================ All Done!OK JTAG Interface Disconnected! followed the procedure as mentioned above and have succesfully unlocked about 10phones apart from this 2 phones! SO IAM NOT A NOOB! WBR ReyTech. |
12-28-2013, 14:47 | #137 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Hello I make Testpoint for 610 and PC detects the phone in Qualcomm Mode I install the drivers but unable to detect the phone by software so that I can unlock it. What can be the problem? Phone is detected in Device Manager as Qualcomm HS-USB QDLoader 9008 Is that correct for these models, as I never succeeded in unlocking any such phone previously? Below is the log from software: Code: Default language ID 0x0409 JTAG Interface Connected, S/N 0xDE97D65F Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:48:00 ========================================================== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...Timeout During Operation! Loading AFP (Please Wait)...OK AFP revision 4, compiled 12/02/2013 10:01:00 ========================================================== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button, then Connect USB Cable ---------------------------------------------------------- Waiting for Device Connection 10 second(s)...Timeout During Operation! Waiting for Device Connection 10 second(s)...Timeout During Operation! Also the software of Advance box tries to connect to phone but doesn't read it fully as below log: says target detected but then hangs ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x5E5E5E5E |
12-28-2013, 17:43 | #139 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | Now main ATF software detected the phone: ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V CID : 110100303038473442009C54301A CSD : D00E00320F5903FFFFFFFFE79640001F eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED Lumia 610/610C Detected eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 008G4B Product Rev : 0.0 Product SN : 9C54301A Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO but the JTAG exe doesn't detect the phone at all |
12-28-2013, 18:01 | #140 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | PFFFFFFFFFFF Very bad support. ON ATF folder I found different pinout for Nokia 610 and seems that I needed to do this JTAG connection, and not the one at TP_PIX folder inside software https://www.dropbox.com/s/6si23pe5xz...2012.57.00.jpg |
12-29-2013, 14:27 | #142 (permalink) | |
Member: 135945 Status: Offline Thanks Meter: 85 | Quote:
pls share as i too have 2pcs and they are still the same DEAD! ReyTech. | |
12-29-2013, 14:42 | #143 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Man,,, the JTAG Pinouts POP-UPS each time you try to unlock a phone with ATF JTAG... Why you didn't you follow the pinouts there??? | |
12-29-2013, 14:45 | #144 (permalink) | |
ATF JTAG only reads codes from phone... It does not write anything to eMMC... So if problem shows up after unlock, then you can be 100% sure that it is hardware problem caused soldering + desoldering of wires... So just check hardware side. Flash phone, charge battery, etc... | |
12-31-2013, 08:58 | #145 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | Code: Default language ID 0x040C JTAG Interface Connected, S/N Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 02/12/2013 10:01:00 ========================================================== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button, then Connect USB Cable ---------------------------------------------------------- Waiting for Device Connection 10 second(s)...Timeout During Operation! Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 12423543 - LOCKED PUK LEVEL 1: 35703008 - LOCKED PIN LEVEL 2: 98923324 PUK LEVEL 2: 23819072 PIN LEVEL 3: 49183107 PUK LEVEL 3: 66657005 PIN LEVEL 4: 95244896 PUK LEVEL 4: 47879197 PIN LEVEL 5: 33309229 PUK LEVEL 5: 38608729 ========================= Reading Unlock Codes Done! ============================================================================ 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ============================================================================ All Done!OK |
01-11-2014, 10:40 | #146 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Home Sweet Home
Member: 1322701 Status: Offline Thanks Meter: 127 | please help bro i did exactly as instructed but it doesnt connect phone always viberate and turn on Default language ID 0x0809 JTAG Interface Connected, S/N 0xEAB8E948 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 27/11/2013 13:43:00 ================================================== ======== Phone Type : Lumia 610 RM-835, RM-849 CPU Type : Qualcomm MSM7227A Storage TYpe: eMMC 8GB ================================================== ======= 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...Timeout During Operation! Restore Boot... Waiting for Device Connection 20 second(s)...Timeout During Operation! Restore Boot... Waiting for Device Connection 20 second(s)...User break! Loading AFP (Please Wait)...OK AFP revision 4, compiled 26/11/2013 10:48:00 ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...Timeout During Operation! |
01-11-2014, 12:38 | #147 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Unlock World
Member: 807734 Status: Offline Thanks Meter: 196 | Default language ID 0x0419 JTAG Interface Connected, S/N 0xD69574D0 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 01.12.2013 16:18:00 ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 83467399 - LOCKED PUK LEVEL 1: 95071020 - LOCKED PIN LEVEL 2: 18376636 PUK LEVEL 2: 71143042 PIN LEVEL 3: 55620249 PUK LEVEL 3: 31949346 PIN LEVEL 4: 63527600 PUK LEVEL 4: 55155753 PIN LEVEL 5: 37371447 PUK LEVEL 5: 68514029 ========================= Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== All Done!OK VERY FAST & GOOD JOB ATF super Nokia BOX ******* )))) |
The Following User Says Thank You to Raminbek For This Useful Post: |
