View Poll Results: Did ATF 9.40 "SKINLESS EDITION" Solved "Access Violation" Problems ??? | |||
YES IT WORKS - Even without Disabling Skins in Settings | 45 | 54.88% | |
YES IT WORKS - After I Disabled Skin in Settings | 12 | 14.63% | |
YES IT WORKS - But I never had problems with 9.00 to 9.40 at all | 15 | 18.29% | |
STILL PROBLEMS - I am still getting "Access Violation" | 10 | 12.20% | |
Voters: 82. You may not vote on this poll |
12-25-2012, 14:37 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | ATF 9.40 "SKINLESS EDITION" Test Results Try the new 9.40 "SKINLESS EDITION" via the ATF AutoUpdate Server and post your results here... B.R. |
The Following 14 Users Say Thank You to Advance-Box For This Useful Post: |
12-25-2012, 15:07 | #3 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @shoaibrao Give me TeamView ID Pass in PM... Your problem is different, it is not "Access Violation" Yours is "Access is denied" |
The Following User Says Thank You to Advance-Box For This Useful Post: |
12-25-2012, 16:17 | #11 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 51
Member: 78767 Status: Offline Sonork: 100.95137 Thanks Meter: 566 | hi my "Access is denied" problem solved by disable skin but still some usb flashing problem is there i faced usb flashing problem in C5-03 and N8 and e52 please chk it |
12-25-2012, 16:22 | #12 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @rajiv007 It is flashing OK ... Code: Number of Image Files: 4 Processing Image File : RM-779_113.010.1506_79u_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 587 Entry Point: 0x0272 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-779_113.010.1506_C07.01_UK_79u_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 8 Entry Point: 0x0153 Page Format : -1 MAX PAGE : 0x0000D800 Processing Image File : RM-779_113.010.1506_01.01_Euro_1_79u_prd.rofs2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 321 Entry Point: 0x014B Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-779_113.010.1506_U01.01_79u.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 781 Entry Point: 0x014B Page Format : -1 MAX PAGE : 0x00040000 []: Found 1 active devices. [Nokia 603 USB Phonet]: Opening Connection [Nokia 603 USB Phonet]: Port opened OK! SW: V 79u_sr2_12w20.8 20-08-12 RM-779 (c) Noki IMEI: 358647040584720 CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked START FULL PM BACKUP Please Wait... Reading : PM 0~400... OK! FULL PM Backup Saved to: C:\AdvanceBox Application_NEW\Nokia\Backup\358647040584720\USB_FULL_BACKUP_V 79u_sr2_12w20.8 20-08-12 RM-779 (c) Noki_358647040584720_Not Locked_72123.pm Reading Battery Value : 3856 mV Rebooting Phone... AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 400C1921 ID DWORD 4 : 03032108 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001060 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 14710000 ID DWORD 1 : FFFB3C40 ID DWORD 2 : 1EB7A681 ID DWORD 3 : 66A68102 ID DWORD 4 : 3753C54E 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 2CAC45E2 CRC 1 : 3BC33C8B CMT Secondary Loader: C:\AdvanceBox Application_NEW\Nokia\BB5_Loader\New\RAPUv21_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0060 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0032 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0060 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 40000000 (1024 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Application_NEW\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 358647040584720 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! Reading : PARTNERC... OK! NPC CERTIFICATE INFORMATION (CMT): IMEI : 358647040584720 PRODUCT CODE : 059L9V2 WLAN ID : 9C:CA:D9:D9:21:D4 BLUETOOTH ID : 9C:CA:D9:D9:12:34 PUBLIC_ID : 14710000FFFB3C401EB7A68166A681023753C54E PAPUB_KEYS_HASH: BC8F5330DDAE68D572ADF62FA254EB9EA2EEF364 CCC CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 059L9V2 HWC CERTIFICATE INFORMATION (CMT): PUBLIC_ID : 14710000FFFB3C401EB7A68166A681023753C54E PRODUCT CODE : 059L9V2 RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Application_NEW\Nokia\Backup\358647040584720\358647040584720_72131.rpl PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: BC8F5330DDAE68D572ADF62FA254EB9EA2EEF364 ImagePath: C:\Nokia Firmware\RM-779\ ImageFilename: RM-779_113.010.1506_79u_prd.core.fpsx Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 Certificate 5 Name : PARTNERC ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... PARTITION_INFO_REQUEST_BB5 : 64012F5F00030000020000FFFFFFFF0000000500000003000000020014000002DA0000000000040000000202EE0000142200000000000800000001171000001700000000000027000000012E100000105000000000000A000000013E6000000040000053 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x57 (87) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-0007FFFF 1 : 000C0000-008BFFFF 2 : 010C0000-170FFFFF 3 : 2E100000-3E5FFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x03000000 Format Info : 000000000000000A0000000000000002000000640018000000000002000000010000000000000000 ERASE_REQUEST_BB5 : 5004120B000300000400000007FFFF120B000300000C0000008BFFFF120B000300010C0000170FFFFF120B0003002E1000003E5FFFFFD3 FORMAT_REQUEST_BB5 : 5001192F00030000000003000000000000000A000000000000000200000064001800000000000200000001000000000000000025 Successfully Erased... Total blocks to write : 587 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : SOS+PMML >> CMT Rootkey Hash CERT : SOS+DECOMP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [BC8F5330DDAE68D572ADF62FA254EB9EA2EEF364] >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : SOS+IVE3A >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ImagePath: C:\Nokia Firmware\RM-779\ ImageFilename: RM-779_113.010.1506_C07.01_UK_79u_prd.rofs3.fpsx StartErase_DCT5... BlockLength : 0x16 (22) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 01678000-0169FFFF 1 : 135C0000-170FFFFF ERASE_REQUEST_BB5 : 5002120B000300016780000169FFFF120B000300135C0000170FFFFFDA Successfully Erased... Total blocks to write : 8 >> CMT Rootkey Hash CERT : SOS+ROFS3 >> CMT Rootkey Hash CERT : SOS+IVE3B ImagePath: C:\Nokia Firmware\RM-779\ ImageFilename: RM-779_113.010.1506_01.01_Euro_1_79u_prd.rofs2.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0D1C0000-135BFFFF ERASE_REQUEST_BB5 : 5001120B0003000D1C0000135BFFFF49 Successfully Erased... Total blocks to write : 321 >> CMT Rootkey Hash CERT : SOS+ROFS2 ImagePath: C:\Nokia Firmware\RM-779\ ImageFilename: RM-779_113.010.1506_U01.01_79u.uda.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 17100000-2E0FFFFF ERASE_REQUEST_BB5 : 5001120B000300171000002E0FFFFF7C Successfully Erased... Total blocks to write : 781 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:49 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) SW: V 79u_sr2_12w20.8 20-08-12 RM-779 (c) Noki IMEI: 358647040584720 CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK |
