02-16-2013, 23:12 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: GRAPECITY, India
Member: 277582 Status: Offline Sonork: 100.1601198 Thanks Meter: 59 | atf 9.51 have problem with model 1202 flashing Same handset flash ok with version 8.90 |
02-19-2013, 10:28 | #10 (permalink) | |
Major Poster Join Date: May 2006
Member: 278409 Status: Offline Thanks Meter: 3 | Quote:
Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 10.3.30 Software Version : v9.51 AdvanceBox SN : ........................................... Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 11.10 13-05-11 RM-721 (c) Nokia IMEI Plain : 351936051178655 IMEI Spare : A351936053378670 IMEI SV : 33519360511786551F Phone Model: Nokia C2-01 Category : Phone Phone Type : RM-721 ================================================ Extended Phone Information ================================================ Product Serial Number: M4I105486 Product Code : 059D678 Module Code : 0204769 Basic Production Code: 059C872 Long Production SN : 0 PPM SW Version : V 11.10 13-05-11 RM-721 (c) Nokia E BT MCM Version : 1673-46038 MCU SW Version : V 11.10 13-05-11 RM-721 (c) Nokia HW Version : 4001 RFIC Version : |Vapaus_6.5 | Mikki_1.1 DSP Version : SPR91_09w09_11w02 LCD Version : SEIKO Content Pack Version : Content: e_059D678 V 11.10 13-05-11 RM-721 (c) Nokia AHNE Version : 41 RETU Version : 51 TAHVO Version : 00 Bluetooth ID : 04:5A:95:E5:8B:B6 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : NORMAL ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0301035602 DCC Ver: 001002 Status : OK Here is the log but only scan work. Buscheck and flash does not work. When i press shortly power - just start charge. (3 phones) | |
02-19-2013, 11:05 | #11 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Nokia 1280 Flashing LOG Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm647_006.510 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 5EF5 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2069312 bytes Data Checksum: F587 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm647_006.51en PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x003773FE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1471488 bytes Data Checksum: A242 Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm6470_nai06.51en CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00F0677E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 354176 bytes Data Checksum: 53D6 Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:02:32 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Buscheck Screenshot |
02-19-2013, 13:27 | #12 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: EGYPT Age: 37
Member: 1544111 Status: Offline Sonork: 100.1611711 Thanks Meter: 80 | x2-02 error in write flashing but in other tool flashing ok Quote:
02-19-2013, 15:02 | #13 (permalink) |
Member: 1544111 Status: Offline Sonork: 100.1611711 Thanks Meter: 80 | nokia 110 error in write flashing but in other tool flashing ok PHP Code: |
