09-14-2014, 10:33 | #1 (permalink) |
Registered User Join Date: Jan 2010 Location: INDIA
Member: 1214756 Status: Offline Thanks Meter: 53 | ATF advance turbo flasher firmware update error how can i solve this problem........... pls share any one............ |
09-15-2014, 09:54 | #3 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
You need to: 1. Disconnect ATF BOX from your PC + Disconnect other Boxes as well. 2. Close ATF Software. 3. Open ATF Software (BOX NOT CONNECTED) 4. Go to Product Support Tab ---> Box Tools 5. Connect BOX To USB Port 6. Click "RESTORE EEPROM" *** Make sure correct drivers are installed after RESTORE EEPROM 7. Click "RESTORE BOX" 8. Final Step, click "UPDATE FIRMWARE" | |
09-15-2014, 11:04 | #5 (permalink) | |
Freak Poster Join Date: Dec 2010 Location: Uzbekistan/Jizzakh
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | Quote:
The Following User Says Thank You to mastersgsm For This Useful Post: |
09-15-2014, 11:15 | #6 (permalink) |
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | restore eeprom ATF Box Connected... Erasing EEPROM Data... EEPROM Erase Successful... Writing EEPROM Data... EEPROM Programming Successful... Trying to cycle usb port... Process Done!.... ********** FINAL 3 STEPS ********** 1. Disconnect ATF Box from USB Port 2. Reconnect ATF Box to USB Port 3. Restart ATF Software restore box Advance-Box Secure AES-128 Channel Open Port Success... Error return code 11 Error return code Elapsed time = 00:03:15 Verifying Array........... |
09-15-2014, 12:23 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @mastersgsm Change USB Cable, connect direct to USB port. Make sure drivers are ok and updated If Still problem, then setup teamviewer so I can check. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
09-15-2014, 15:26 | #8 (permalink) |
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | drivers all is ok, software version last 11.60 pls add me my sonork 100.1638921 i am waiting your answer, i am sending you teamviewer id ! |
10-19-2014, 17:33 | #10 (permalink) | |
Major Poster Join Date: Feb 2009 Location: WARANGAL,TELANGANA,INDIA Age: 38
Member: 962803 Status: Offline Thanks Meter: 3 | Quote:
The Following User Says Thank You to sandeep_kolluri For This Useful Post: |
11-13-2014, 18:20 | #11 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Jammu and Kashmir Baramulla
Member: 1963898 Status: Offline Thanks Meter: 52 | sir after uninstall atf setup....i want to re install atf soft....i hv installed atf,there after need to update box firmware,,,,when i click update box firmware it shows error |
12-03-2014, 15:45 | #12 (permalink) |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | There is no solution to this PROBLEM have two new box never used still lack ACTIVE and so the error problem ATF team please let us help this problem WAIT |
The Following User Says Thank You to paulo pessoa For This Useful Post: |
12-08-2014, 13:55 | #13 (permalink) |
12-09-2014, 15:18 | #14 (permalink) |
Member: 1963898 Status: Offline Thanks Meter: 52 | Atf box update error $ when i try to update atf it shows error $....any one help me please |
The Following User Says Thank You to D saakib elec For This Useful Post: |
12-10-2014, 08:27 | #15 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Darwin Northern Teretory Age: 40
Member: 136173 Status: Offline Sonork: 108426:ind Thanks Meter: 97 | i have same probl;em eprom repair ok but update firmware error always for folling serial numberr is now 000000000 sticker on box is b92efa31 bought from gsmserver |
The Following User Says Thank You to zipzap_kill For This Useful Post: |
