04-21-2010, 07:57 | #31 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | 5130 rm-495 Code: Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.95.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 0303192101033000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1178 Entry Point: 0x5057 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.95.ppm_qa CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 0303192101033000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 471 Entry Point: 0x00BE Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.95.image_qa_red CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 0303192101033000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 720 Entry Point: 0x00D0 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1C500217 ID DWORD 1 : A63A7D56 ID DWORD 2 : 052AFAF2 ID DWORD 3 : E2AC6D57 ID DWORD 4 : A8A6B457 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum A7 BootCodeLen : 61 SearchForBootstrap_DCT5.. KEYS KEYS 2ND 2ND SILO SILO 2ND 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 BCM21351_PI155_XSR16_usbalg.fg First Algo byte : 56 BCM21351_XSR16_usbalg.fg First Algo byte : 56 h3_xsr15_flash_alg.fg First Algo byte : 00 MICROv10_alg2nd.fg OMAP2420_XSR15_alg.fg First Algo byte : 56 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0003 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF00000003000000030000000200A40000013C0000000000040000000201E0000005140000000000080000000106F4000008B00000ED PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0003 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF00000003000000030000000200A40000013C0000000000040000000201E0000005140000000000080000000106F4000008B00000ED PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) Setting VPP to : 9.0V VPP Enabled by Software Using External VPP StartErase_DCT5... BlockLength : 0x0036 (54) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 33 0 ERASE_AREA_BB5 0x12 Block Length : 0x33 (51) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00040000-000BFFFF 3 : 000C0000-0013FFFF 4 : 00140000-0137FFFF 5 : 01380000-0151FFFF ERASE_REQUEST_BB5 : 5006120B00000000000000000006BF120B000000000006C00001FFFF120B00000000040000000BFFFF120B000000000C00000013FFFF120B000000001400000137FFFF120B000000013800000151FFFFC4 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds >> Time Elapsed 39 seconds >> Time Elapsed 42 seconds >> Time Elapsed 45 seconds >> Time Elapsed 48 seconds >> Time Elapsed 51 seconds >> Time Elapsed 54 seconds >> Time Elapsed 57 seconds >> Time Elapsed 60 seconds >> Time Elapsed 63 seconds >> Time Elapsed 66 seconds >> Time Elapsed 69 seconds >> Time Elapsed 72 seconds >> Time Elapsed 75 seconds >> Time Elapsed 78 seconds >> Time Elapsed 81 seconds >> Time Elapsed 84 seconds >> Time Elapsed 87 seconds >> Time Elapsed 90 seconds >> Time Elapsed 93 seconds >> Time Elapsed 96 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01520000-01DBFFFF ERASE_REQUEST_BB5 : 5001120B0000000152000001DBFFFFB4 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. StartErase_DCT5... BlockLength : 0x0016 (22) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 13 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01DC0000-0215FFFF 1 : 02160000-03FBFFFF ERASE_REQUEST_BB5 : 5002120B00000001DC00000215FFFF120B0000000216000003FBFFFFBD >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds >> Time Elapsed 39 seconds >> Time Elapsed 42 seconds >> Time Elapsed 45 seconds >> Time Elapsed 48 seconds >> Time Elapsed 51 seconds >> Time Elapsed 54 seconds >> Time Elapsed 57 seconds >> Time Elapsed 60 seconds >> Time Elapsed 63 seconds >> Time Elapsed 66 seconds >> Time Elapsed 69 seconds >> Time Elapsed 72 seconds >> Time Elapsed 75 seconds >> Time Elapsed 78 seconds >> Time Elapsed 81 seconds >> Time Elapsed 84 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:04:00 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : rm495__07.95.mcusw Total blocks to write : 1178 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW Processing : rm495__07.95.ppm_qa Total blocks to write : 471 Processing : rm495__07.95.image_qa_red Total blocks to write : 720 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:05 Total Flashing Time (Booting + Erase + Flashing) : 00:05:09 |
The Following User Says Thank You to gsmfun For This Useful Post: |
04-21-2010, 08:01 | #32 (permalink) |
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | 5230 rm-588 5230 RM-588 Code: Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_12.6.092_prd.core.C00 CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 387 Entry Point: 0x273CC2 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_12.6.092_prd.rofs2.V02 CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 98 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_12.6.092.383.01.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 28 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-588\RM588_12.0.092_006_000_U001.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 22 Entry Point: 0x00F9 Page Format : -1 MAX PAGE : 0x00040000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 09500119 ID DWORD 1 : F6890052 ID DWORD 2 : BDB4BF81 ID DWORD 3 : 50AA156F ID DWORD 4 : 99964B0A 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 5B BootCodeLen : 61 SearchForBootstrap_DCT5.. KEYS CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0231 Checksum : 04 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0231 RAPIDOv11_XSR15_alg.fg First Algo byte : 56 XSR 1.5 phone devicealgo : RAPIDOv11_XSR17_alg.fg First Algo byte : 56 XSR 1.6 phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR17_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 026A0000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 026A0000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 026A0000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 026A0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200080000026A000000000004000000020272000007740000000000080000000109E60000056200000000000A000000010F640000003C0000F5 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : 00000000 Num Partitions : 0003 Partition 1 ID : 00070000 NBL1 Attribute : 00680000 Start Address : 00000000 Size : 00010000 Partition 2 ID : 00070000 NBL1 Attribute : 00680000 Start Address : 00000000 Size : 00010000 Partition 3 ID : 00070000 NBL1 Attribute : 00680000 Start Address : 00000000 Size : 00010000 PARTITION_INFO_REQUEST_BB5 : 64012F3F0101000001000000000000000000030007000000680000000000000001000002B00000013D00000000000100010000006F000002410000000000000001000075 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) No partition info.... No partition info.... StartErase_DCT5... BlockLength : 0x0057 (87) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 23 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-00082FFF 1 : 00083400-003FFFFF 2 : 00800000-00D5FFFF 3 : 00D60000-09E5FFFF CurrPos : 28 CurrEraseLen : 2F 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID :0x02000000 Format Info :000000000000000A0000000000000002000000640000000B0000000200000001000000000000 ERASE_REQUEST_BB5 : 5004120B0003000004000000082FFF120B00030000083400003FFFFF120B0003000080000000D5FFFF120B00030000D6000009E5FFFFB3 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000000000002000000640000000B000000020000000100000000000033 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 06AA0000-0915FFFF ERASE_REQUEST_BB5 : 5001120B00030006AA00000915FFFF12 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 09160000-09E5FFFF ERASE_REQUEST_BB5 : 5001120B0003000916000009E5FFFFD3 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:02 Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : RM-588_12.6.092_prd.core.C00 Total blocks to write : 387 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 Processing : RM-588_12.6.092_prd.rofs2.V02 Total blocks to write : 98 >> CMT Rootkey Hash CERT : SOS+ROFS2 Processing : RM-588_12.6.092.383.01.rofs3.fpsx Total blocks to write : 28 >> CMT Rootkey Hash CERT : SOS+ROFS3 Processing : RM588_12.0.092_006_000_U001.uda.fpsx Total blocks to write : 22 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:58 Total Flashing Time (Booting + Erase + Flashing) : 00:01:04 |
04-21-2010, 08:04 | #33 (permalink) |
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | 6280 rm-78 6280 RM-78 Code: Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-78\rm7830006.430.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101003000 > 010C192101003000 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1041 Entry Point: 0x44D2 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-78\rm783006.43.ppm_t CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101003000 > 010C192101003000 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 294 Entry Point: 0x00A6 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-78\rm7830006.43.image_vg_nz_nj CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101003000 > 010C192101003000 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 176 Entry Point: 0x00AA Page Format : 0 MAX PAGE : 0x00004000 File detected Not 128K format.... Converting image to 128k bit..... Converted file created : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-78\rm7830006.43.image_vg_nz_nj_128k CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101003000 > 010C192101003000 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 176 Entry Point: 0x00AA Page Format : 0 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01003000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000352 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 26800119 ID DWORD 1 : C2950154 ID DWORD 2 : 241256B3 ID DWORD 3 : A44142BD ID DWORD 4 : 7B400ED7 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum FD BootCodeLen : 61 SearchForBootstrap_DCT5.. 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 002F -> 72NS256N Extended/Fixed ID : 0000 Revision ID : 0121 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 4E SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :002F ExtID :0000 RevID :0121 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0001 Device ID : 002F Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) Setting VPP to : 9.0V VPP Enabled by Software Using External VPP StartErase_DCT5... BlockLength : 0x004E (78) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 4B 0 ERASE_AREA_BB5 0x12 Block Length : 0x4B (75) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000202BF 1 : 00020300-000252FF 2 : 00020000-0007FFFF 3 : 00080000-000DFFFF 4 : 00200000-0037FFFF 5 : 00380000-011DDFFF 6 : 011DE000-011DEFFF 7 : 011DF000-011DFFFF 8 : 00100000-001FFFFF ERASE_REQUEST_BB5 : 5009120B00000000000000000202BF120B00000000020300000252FF120B000000000200000007FFFF120B00000000080000000DFFFF120B000000002000000037FFFF120B00000000380000011DDFFF120B000000011DE000011DEFFF120B000000011DF000011DFFFF120B00000000100000001FFFFFD2 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds >> Time Elapsed 39 seconds >> Time Elapsed 42 seconds >> Time Elapsed 45 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 011E0000-016DFFFF ERASE_REQUEST_BB5 : 5001120B000000011E0000016DFFFF56 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 016E0000-01FDFFFF ERASE_REQUEST_BB5 : 5001120B000000016E000001FDFFFF76 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:32 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : rm7830006.430.mcusw Total blocks to write : 1041 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : PMM_CONF >> CMT Rootkey Hash CERT : SBIF_CONF Processing : rm783006.43.ppm_t Total blocks to write : 294 Processing : rm7830006.43.image_vg_nz_nj_128k Total blocks to write : 176 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:10 Total Flashing Time (Booting + Erase + Flashing) : 00:02:45 |
04-21-2010, 08:06 | #34 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Indonesia
Member: 90761 Status: Offline Sonork: 1617079 Thanks Meter: 95 | 3110c reset factory failed flashing 3110c ok from dead phone 14:59:47 : ************************************************** **** 14:59:47 : TIME START HERE 14:59:47 : ************************************************** **** 14:59:47 : 14:59:47 : BootFlashModeDCT5Ex Succeeded First Time 14:59:47 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 14:59:47 : Number of Sub Blocks 7 (0x07) 14:59:47 : 1 SYSTEM_ASIC_ID 01 14:59:47 : Block Length : 21 (15) 14:59:47 : BB ASIC Index : 0 (00) CMT 14:59:47 : ID DWORD 0 : 00000001 14:59:47 : ID DWORD 1 : 00000226 14:59:47 : ID DWORD 2 : 00010006 14:59:47 : ID DWORD 3 : 010C1921 14:59:47 : ID DWORD 4 : 01001101 14:59:47 : 2 ROM_ID 15 14:59:47 : Block Length : 5 (05) 14:59:47 : BB ASIC Index : 0 (00) CMT 14:59:47 : ID DWORD 0 : 00000232 14:59:47 : 3 ROM_ID 15 14:59:47 : Block Length : 5 (05) 14:59:47 : BB ASIC Index : 0 (00) CMT 14:59:47 : ID DWORD 0 : 00000353 14:59:47 : 4 PUBLIC_ID 12 14:59:47 : Block Length : 21 (15) 14:59:47 : BB ASIC Index : 0 (00) CMT 14:59:47 : ID DWORD 0 : 0A400112 14:59:47 : ID DWORD 1 : C8027F56 14:59:47 : ID DWORD 2 : E91052D0 14:59:47 : ID DWORD 3 : 4A6C4D1A 14:59:47 : ID DWORD 4 : E52F4EEC 14:59:47 : 5 ASIC_MODE_ID 13 14:59:47 : Block Length : 2 (02) 14:59:47 : BB ASIC Index : 0 (00) CMT 14:59:47 : Mode Id : 00 14:59:47 : 6 ROOT_KEY_HASH 14 14:59:47 : Block Length : 17 (11) 14:59:47 : BB ASIC Index : 0 (00) CMT 14:59:47 : Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 14:59:47 : 7 ROM_ID 15 14:59:47 : Block Length : 9 (09) 14:59:47 : BB ASIC Index : 0 (00) CMT 14:59:47 : CRC 0 : 191EC665 14:59:47 : CRC 1 : DFAAF68F 14:59:47 : Checksum 8D 14:59:47 : BootCodeLen : 61 14:59:47 : SearchForBootstrap_DCT5.. 14:59:47 : 2ND 14:59:47 : KEYS 14:59:47 : 2ND 14:59:47 : CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg 14:59:47 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 14:59:47 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 14:59:47 : MCU_CONFIGURATION_RESPONSE_BB5: 14:59:47 : MessageID : C1 14:59:47 : SubBlocks : 03 14:59:47 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 14:59:47 : Block Length : 0B 14:59:47 : BB ASIC Index : CMT 00 14:59:47 : Device Type : NOR 00 14:59:47 : Device Index : 00 14:59:47 : Manufacturer Code : 0089 -> 14:59:47 : Device ID : 8981 -> Type not in database 14:59:47 : Extended/Fixed ID : 0000 14:59:47 : Revision ID : 6A21 14:59:47 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 14:59:47 : Block Length : 13 14:59:47 : BB ASIC Index : CMT 00 14:59:47 : Device Type : NOR 00 14:59:47 : Device Index : 00 14:59:47 : Device Contents : 00000000000000000000 14:59:47 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 14:59:47 : Block Length : 0B 14:59:47 : BB ASIC Index : CMT 00 14:59:47 : Device Type : MMC 04 14:59:47 : Device Index : 00 14:59:48 : Manufacturer Code : FFFF -> Flash 14:59:48 : Device ID : 0000 -> BAD FLASH TYPE 14:59:48 : Extended/Fixed ID : 0000 14:59:48 : Revision ID : 0000 14:59:48 : Checksum : 82 14:59:48 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 14:59:48 : FLS1SendAlgoCodeEx.. 14:59:48 : SendAlgoCode_DCT5.. 14:59:48 : SearchForAlgorithm_DCT5.. 14:59:48 : Looking for ALL Devices... 14:59:48 : Searching Algorithm Files NOR (00) ManID :0089 DevID :8981 ExtID :0000 RevID :6A21 14:59:48 : RAP3Gv3_algo.fg 14:59:48 : First Algo byte : C0 14:59:48 : BB5 ALGORITHM 14:59:48 : phone devicealgo : 14:59:48 : Flash Descriptor 14:59:48 : Manufacturer Code : 0089 14:59:48 : Device ID : 8981 14:59:48 : Extended/Fixed ID : 0000 14:59:48 : Revision ID : 0000 14:59:48 : Size : 00200000 (2097152) 14:59:48 : VPP Info : 0009 14:59:48 : Erase10s : 28 14:59:48 : Block1s : 64 14:59:48 : BErase1s : 02 14:59:48 : Reserved0 : 00 14:59:48 : Reserved1 : 00 14:59:48 : Reserved2 : 00 14:59:48 : VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK 14:59:48 : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg 14:59:48 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 14:59:48 : TransmissionTypeRequest_DCT5... 14:59:48 : SuggestedType : 01 16BIT 14:59:48 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 14:59:48 : ReturnedType : 01 16BIT 14:59:48 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 14:59:48 : 14:59:48 : Uploading ALGO File... 14:59:48 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 14:59:48 : No partition info.... 14:59:48 : No partition info.... 14:59:48 : No partition info.... 14:59:48 : VPP Enabled by Software 14:59:48 : Using Internal VPP 14:59:48 : StartErase_DCT5... 14:59:48 : BlockLength : 0x004E (78) 14:59:48 : ERASE Blocks : 0x0001 (1) 14:59:49 : erase blocks : 1 14:59:49 : CurrPos : 03 14:59:49 : CurrEraseLen : 4B 14:59:49 : 0 ERASE_AREA_BB5 0x12 14:59:49 : Block Length : 0x4B (75) 14:59:49 : BB ASIC Index : 0x00 CMT 14:59:49 : Device Type : 0x00 NOR 14:59:49 : Device Index : 0x00 14:59:49 : 0 : 00000000-000006BF 14:59:49 : 1 : 000006C0-0001FFFF 14:59:49 : 2 : 00020000-0007FFFF 14:59:49 : 3 : 00080000-000DFFFF 14:59:49 : 4 : 00100000-001FFFFF 14:59:49 : 5 : 00200000-0031FFFF 14:59:49 : 6 : 00320000-0105FFFF 14:59:49 : 7 : 01060000-01067FFF 14:59:49 : 8 : 01068000-0107FFFF 14:59:49 : 14:59:49 : ERASE_REQUEST_BB5 : 5009120B00000000000000000006BF120B000000000006C000 01FFFF120B000000000200000007FFFF120B00000000080000 000DFFFF120B00000000100000001FFFFF120B000000002000 000031FFFF120B000000003200000105FFFF120B0000000106 000001067FFF120B000000010680000107FFFF82 14:59:52 : >> Time Elapsed 3 seconds 14:59:55 : >> Time Elapsed 6 seconds 14:59:58 : >> Time Elapsed 9 seconds 15:00:01 : >> Time Elapsed 12 seconds 15:00:04 : >> Time Elapsed 15 seconds 15:00:07 : >> Time Elapsed 18 seconds 15:00:10 : >> Time Elapsed 21 seconds 15:00:13 : >> Time Elapsed 24 seconds 15:00:16 : >> Time Elapsed 27 seconds 15:00:19 : >> Time Elapsed 30 seconds 15:00:22 : >> Time Elapsed 33 seconds 15:00:25 : >> Time Elapsed 36 seconds 15:00:28 : >> Time Elapsed 39 seconds 15:00:31 : >> Time Elapsed 42 seconds 15:00:35 : >> Time Elapsed 45 seconds 15:00:38 : >> Time Elapsed 48 seconds 15:00:41 : >> Time Elapsed 51 seconds 15:00:44 : >> Time Elapsed 54 seconds 15:00:47 : >> Time Elapsed 57 seconds 15:00:50 : >> Time Elapsed 60 seconds 15:00:53 : >> Time Elapsed 63 seconds 15:00:56 : >> Time Elapsed 66 seconds 15:00:59 : >> Time Elapsed 69 seconds 15:01:02 : >> Time Elapsed 72 seconds 15:01:05 : >> Time Elapsed 75 seconds 15:01:08 : >> Time Elapsed 78 seconds 15:01:11 : >> Time Elapsed 81 seconds 15:01:14 : >> Time Elapsed 84 seconds 15:01:17 : >> Time Elapsed 87 seconds 15:01:19 : Status_BB5 STATUS_REQUEST_BB5.. 15:01:19 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 15:01:19 : Block Length : 01 15:01:19 : BB ASIC Index : 00 15:01:19 : 15:01:19 : Successfully erased.. 15:01:19 : StartErase_DCT5... 15:01:19 : BlockLength : 0x000E (14) 15:01:19 : ERASE Blocks : 0x0001 (1) 15:01:19 : erase blocks : 1 15:01:19 : CurrPos : 03 15:01:19 : CurrEraseLen : 0B 15:01:19 : 0 ERASE_AREA_BB5 0x12 15:01:19 : Block Length : 0x0B (11) 15:01:19 : BB ASIC Index : 0x00 CMT 15:01:19 : Device Type : 0x00 NOR 15:01:19 : Device Index : 0x00 15:01:19 : 0 : 01080000-0151FFFF 15:01:19 : 15:01:20 : ERASE_REQUEST_BB5 : 5001120B000000010800000151FFFF88 15:01:23 : >> Time Elapsed 3 seconds 15:01:26 : >> Time Elapsed 6 seconds 15:01:29 : >> Time Elapsed 9 seconds 15:01:32 : >> Time Elapsed 12 seconds 15:01:35 : >> Time Elapsed 15 seconds 15:01:38 : >> Time Elapsed 18 seconds 15:01:41 : >> Time Elapsed 21 seconds 15:01:43 : Status_BB5 STATUS_REQUEST_BB5.. 15:01:43 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 15:01:43 : Block Length : 01 15:01:43 : BB ASIC Index : 00 15:01:43 : 15:01:43 : Successfully erased.. 15:01:43 : StartErase_DCT5... 15:01:43 : BlockLength : 0x000E (14) 15:01:43 : ERASE Blocks : 0x0001 (1) 15:01:43 : erase blocks : 1 15:01:43 : CurrPos : 03 15:01:43 : CurrEraseLen : 0B 15:01:43 : 0 ERASE_AREA_BB5 0x12 15:01:43 : Block Length : 0x0B (11) 15:01:43 : BB ASIC Index : 0x00 CMT 15:01:43 : Device Type : 0x00 NOR 15:01:43 : Device Index : 0x00 15:01:43 : 0 : 01520000-01FDFFFF 15:01:43 : 15:01:43 : ERASE_REQUEST_BB5 : 5001120B0000000152000001FDFFFF92 15:01:46 : >> Time Elapsed 3 seconds 15:01:49 : >> Time Elapsed 6 seconds 15:01:52 : >> Time Elapsed 9 seconds 15:01:55 : >> Time Elapsed 12 seconds 15:01:58 : >> Time Elapsed 15 seconds 15:02:01 : >> Time Elapsed 18 seconds 15:02:04 : >> Time Elapsed 21 seconds 15:02:07 : >> Time Elapsed 24 seconds 15:02:11 : >> Time Elapsed 27 seconds 15:02:14 : >> Time Elapsed 30 seconds 15:02:17 : >> Time Elapsed 33 seconds 15:02:20 : >> Time Elapsed 36 seconds 15:02:23 : >> Time Elapsed 39 seconds 15:02:26 : >> Time Elapsed 42 seconds 15:02:29 : >> Time Elapsed 45 seconds 15:02:29 : Status_BB5 STATUS_REQUEST_BB5.. 15:02:29 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 15:02:29 : Block Length : 01 15:02:29 : BB ASIC Index : 00 15:02:29 : 15:02:29 : Successfully erased.. 15:02:29 : Time Taken to Erase : 00:02:40 15:02:29 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 15:02:29 : ReturnedType : 04 DDRand2TX 15:02:29 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 15:02:29 : 15:02:30 : Is Flashing CLOCK AUTO : -1 15:02:30 : 15:02:30 : //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// 15:02:30 : 15:02:30 : Processing : rm237__07.21.mcusw 15:02:30 : Total blocks to write : 944 15:02:38 : >> CMT Rootkey Hash CERT : NOLO 15:02:39 : >> CMT Rootkey Hash CERT : KEYS 15:02:39 : >> CMT Rootkey Hash CERT : PRIMAPP 15:02:39 : >> CMT Rootkey Hash CERT : PASUBTOC 15:02:43 : >> CMT Rootkey Hash CERT : PAPUBKEYS 15:02:43 : >> CMT Rootkey Hash CERT : UPDAPP 15:02:43 : >> CMT Rootkey Hash CERT : DSP0 15:02:45 : >> CMT Rootkey Hash CERT : MCUSW 15:03:13 : >> CMT Rootkey Hash CERT : PMM_CONF 15:03:13 : >> CMT Rootkey Hash CERT : SBIF_CONF 15:03:14 : Processing : rm237__07.21.ppm_x 15:03:14 : Total blocks to write : 279 15:03:23 : Processing : rm237__07.21.image_x_128k 15:03:23 : Total blocks to write : 360 15:03:35 : ContinueFlash_DCT5 Complete 15:03:35 : Status_BB5 STATUS_REQUEST_BB5.. 15:03:35 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 15:03:35 : Block Length : 01 15:03:35 : BB ASIC Index : 00 15:03:35 : FlashInfo.RestartMode : 2 15:03:35 : Continue Flash Complete : : No Error - 0 (0x00) 15:03:35 : Time Taken to Flash : 00:01:05 15:03:35 : 15:03:35 : Total Flashing Time (Booting + Erase + Flashing) : 00:03:47 but, reset factory failed Reading Phone Information... MCU: V 07.21 05-11-08 RM-237 (c) Nokia. IMEI: 354206037837122 Product code : 0581834 ******** Reading SimLock ******** Simlock Version : SIMLOCK SERVER VERSION 63 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED FACTORY SET TO : Factory Set Full FAILED |
04-21-2010, 08:11 | #35 (permalink) |
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | 6500s RM-240 6500s RM-240 Code: Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.30.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101003000 > 010C192101003000 > 030C192101023000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1316 Entry Point: 0x4532 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.30.ppm_c CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101003000 > 010C192101003000 > 030C192101023000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 411 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.30_ISM_001.image_c_tr_ctv_tr CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101003000 > 010C192101003000 > 030C192101023000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 736 Entry Point: 0x00C2 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01003000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 2500010A ID DWORD 1 : 748C0254 ID DWORD 2 : 48C9CEEB ID DWORD 3 : FDC3ACD2 ID DWORD 4 : 34BE2961 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum E7 BootCodeLen : 61 SearchForBootstrap_DCT5.. 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 003F -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : B5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :003F ExtID :0000 RevID :8A21 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0001 Device ID : 003F Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 02940000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 02940000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 02940000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 02940000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200080000029400000000000400000002029C000008D6000000000008000000010B720000138600000000000A000000011F140000003C0000BE PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000000200A4000003000000000000040000000203A4000003500000000000080000000106F400000894000000000009000000010F880000001A000077 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) No partition info.... Setting VPP to : 9.0V VPP Enabled by Software Using External VPP StartErase_DCT5... BlockLength : 0x002E (46) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 2B 0 ERASE_AREA_BB5 0x12 Block Length : 0x2B (43) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-0001FFFF 1 : 00040000-000BFFFF 2 : 000C0000-0013FFFF 3 : 01480000-015FFFFF 4 : 00140000-0147FFFF ERASE_REQUEST_BB5 : 5005120B000000000000000001FFFF120B00000000040000000BFFFF120B000000000C00000013FFFF120B00000001480000015FFFFF120B000000001400000147FFFF3F >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01600000-01CBFFFF ERASE_REQUEST_BB5 : 5001120B0000000160000001CBFFFFB6 >> Time Elapsed 3 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. StartErase_DCT5... BlockLength : 0x0016 (22) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 13 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01FC0000-03F9FFFF 1 : 01CC0000-01FBFFFF ERASE_REQUEST_BB5 : 5002120B00000001FC000003F9FFFF120B00000001CC000001FBFFFF05 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:44 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : rm240__10.30.mcusw Total blocks to write : 1316 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW Processing : rm240__10.30.ppm_c Total blocks to write : 411 Processing : rm240__10.30_ISM_001.image_c_tr_ctv_tr Total blocks to write : 736 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:02:48 Total Flashing Time (Booting + Erase + Flashing) : 00:03:35 |
04-21-2010, 09:33 | #36 (permalink) |
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | 6700c RM-470 6700c RM-470 Code: Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-470\rm470__10.50.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 6003192102021104 > 600C192102021104 > 6003192102011104 > 600C192102011104 > 0400000200000000 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 229 Entry Point: 0x021B Page Format : -1 MAX PAGE : 0x00020000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-470\rm470__10.50.ppm_p CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 6003192102021104 > 600C192102021104 > 6003192102011104 > 600C192102011104 > 0400030000000002 > 000000A000000028 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 53 Entry Point: 0x011D Page Format : -1 MAX PAGE : 0x00020000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-470\rm470__10.50_ISM_014.image_p_black CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 6003192102021104 > 600C192102021104 > 6003192102011104 > 600C192102011104 > 0400000200000000 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 227 Entry Point: 0x014C Page Format : -1 MAX PAGE : 0x00020000 Changing MODE : FLASH VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02011104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C34 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 06F00005 ID DWORD 1 : 83330344 ID DWORD 2 : 114E4BD0 ID DWORD 3 : B4BE8E2B ID DWORD 4 : 35DDFAE3 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 25 B9 77 A0 55 BE 9B 5D EC 0C 38 A2 A2 79 C6 95 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 3E273BF6 CRC 1 : 37BE26FA Checksum 69 BootCodeLen : 61 SearchForBootstrap_DCT5.. KEYS CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 19 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121 RAPUv11_XSR17_alg.fg First Algo byte : 56 XSR 1.6 phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02860000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02860000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02860000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02860000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002860000000000080000000102FC00000C3000000000000A000000010F2C0000006000000000000B000000010F8C0000001800003D PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02860000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02860000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02860000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02860000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002860000000000080000000102FC00000C3000000000000A000000010F2C0000006000000000000B000000010F8C0000001800003D PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02860000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02860000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02860000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02860000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002860000000000080000000102FC00000C3000000000000A000000010F2C0000006000000000000B000000010F8C0000001800003D PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x00D1 (209) ERASE Blocks : 0x0004 (4) erase blocks : 4 CurrPos : 03 CurrEraseLen : 3B 0 ERASE_AREA_BB5 0x12 Block Length : 0x3B (59) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00020000-000203FF 1 : 00060000-0009FFFF 2 : 000A0000-0041FFFF 3 : 00420000-0069FFFF 4 : 006A0000-01F1FFFF 5 : 02900000-02FBFFFF 6 : 0F2C0000-0F8BFFFF CurrPos : 40 CurrEraseLen : 2F 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID :0x02000000 Format Info :0000000000000008000000000000000200000064000000020000000200000001000000000000 CurrPos : 71 CurrEraseLen : 2F 2 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID :0x02000000 Format Info :000000000000000A000000010000000200000064000000020000000200000001000000000000 CurrPos : A2 CurrEraseLen : 2F 3 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID :0x02000000 Format Info :000000000000000B000000000000000200000064000000020000000200000001000000000000 ERASE_REQUEST_BB5 : 5007120B00030000020000000203FF120B000300000600000009FFFF120B000300000A00000041FFFF120B000300004200000069FFFF120B000300006A000001F1FFFF120B0003000290000002FBFFFF120B0003000F2C00000F8BFFFF59 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 ERASE_REQUEST_BB5 : 5001192F0003000000000200000000000000080000000000000002000000640000000200000002000000010000000000003E Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000100000002000000640000000200000002000000010000000000003B Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B0000000000000002000000640000000200000002000000010000000000003B Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 01F20000-028FFFFF ERASE_REQUEST_BB5 : 5001120B00030001F20000028FFFFF5C Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:02 Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : rm470__10.50.mcusw Total blocks to write : 229 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : ISA+DYNSW Processing : rm470__10.50.ppm_p Total blocks to write : 53 Processing : rm470__10.50_ISM_014.image_p_black Total blocks to write : 227 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:30 Total Flashing Time (Booting + Erase + Flashing) : 00:00:36 |
04-21-2010, 09:36 | #37 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | 7210c RM-436 7210c RM-436 Code: Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-436\rm436__07.23.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1170 Entry Point: 0x5047 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-436\rm436__07.23.ppm_t CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 473 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-436\rm436__07.23.image_t_ph CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 520 Entry Point: 0x00C2 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 16C00104 ID DWORD 1 : 8D137F56 ID DWORD 2 : A23716BC ID DWORD 3 : 08F99E42 ID DWORD 4 : 3FA2CD04 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 18 BootCodeLen : 61 SearchForBootstrap_DCT5.. KEYS KEYS 2ND 2ND SILO SILO 2ND 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 BCM21351_PI155_XSR16_usbalg.fg First Algo byte : 56 BCM21351_XSR16_usbalg.fg First Algo byte : 56 h3_xsr15_flash_alg.fg First Algo byte : 00 MICROv10_alg2nd.fg OMAP2420_XSR15_alg.fg First Algo byte : 56 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0003 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF00000003000000030000000200A40000013C0000000000040000000201E0000005140000000000080000000106F4000008B00000ED PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0003 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF00000003000000030000000200A40000013C0000000000040000000201E0000005140000000000080000000106F4000008B00000ED PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) Setting VPP to : 9.0V VPP Enabled by Software Using External VPP StartErase_DCT5... BlockLength : 0x0036 (54) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 33 0 ERASE_AREA_BB5 0x12 Block Length : 0x33 (51) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00040000-000BFFFF 3 : 000C0000-0013FFFF 4 : 00140000-0119FFFF 5 : 011A0000-0133FFFF ERASE_REQUEST_BB5 : 5006120B00000000000000000006BF120B000000000006C00001FFFF120B00000000040000000BFFFF120B000000000C00000013FFFF120B000000001400000119FFFF120B000000011A00000133FFFF1E >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds >> Time Elapsed 39 seconds >> Time Elapsed 42 seconds >> Time Elapsed 45 seconds >> Time Elapsed 48 seconds >> Time Elapsed 51 seconds >> Time Elapsed 54 seconds >> Time Elapsed 57 seconds >> Time Elapsed 60 seconds >> Time Elapsed 63 seconds >> Time Elapsed 66 seconds >> Time Elapsed 69 seconds >> Time Elapsed 72 seconds >> Time Elapsed 75 seconds >> Time Elapsed 78 seconds >> Time Elapsed 81 seconds >> Time Elapsed 84 seconds >> Time Elapsed 87 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01340000-01BDFFFF ERASE_REQUEST_BB5 : 5001120B0000000134000001BDFFFFF0 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. StartErase_DCT5... BlockLength : 0x0016 (22) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 13 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01BE0000-01F7FFFF 1 : 01F80000-03FBFFFF ERASE_REQUEST_BB5 : 5002120B00000001BE000001F7FFFF120B00000001F8000003FBFFFF19 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds >> Time Elapsed 39 seconds >> Time Elapsed 42 seconds >> Time Elapsed 45 seconds >> Time Elapsed 48 seconds >> Time Elapsed 51 seconds >> Time Elapsed 54 seconds >> Time Elapsed 57 seconds >> Time Elapsed 60 seconds >> Time Elapsed 63 seconds >> Time Elapsed 66 seconds >> Time Elapsed 69 seconds >> Time Elapsed 72 seconds >> Time Elapsed 75 seconds >> Time Elapsed 78 seconds >> Time Elapsed 81 seconds >> Time Elapsed 84 seconds >> Time Elapsed 87 seconds >> Time Elapsed 90 seconds >> Time Elapsed 93 seconds >> Time Elapsed 96 seconds >> Time Elapsed 99 seconds >> Time Elapsed 102 seconds >> Time Elapsed 105 seconds >> Time Elapsed 108 seconds >> Time Elapsed 111 seconds >> Time Elapsed 114 seconds >> Time Elapsed 117 seconds >> Time Elapsed 120 seconds >> Time Elapsed 123 seconds >> Time Elapsed 126 seconds >> Time Elapsed 129 seconds >> Time Elapsed 132 seconds >> Time Elapsed 135 seconds >> Time Elapsed 138 seconds >> Time Elapsed 141 seconds >> Time Elapsed 144 seconds >> Time Elapsed 147 seconds >> Time Elapsed 150 seconds >> Time Elapsed 153 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:05:19 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : rm436__07.23.mcusw Total blocks to write : 1170 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW Processing : rm436__07.23.ppm_t Total blocks to write : 473 Processing : rm436__07.23.image_t_ph Total blocks to write : 520 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:07 Total Flashing Time (Booting + Erase + Flashing) : 00:06:30 |
04-21-2010, 09:39 | #38 (permalink) |
Freak Poster Join Date: Dec 2007 Location: my dream
Member: 664744 Status: Offline Thanks Meter: 156 | 3110 RM 237 Code: Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 944 Entry Point: 0x44FC Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0F400104 ID DWORD 1 : C2787E56 ID DWORD 2 : F0132949 ID DWORD 3 : A7AA7234 ID DWORD 4 : 0F06D10C 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 4F BootCodeLen : 61 SearchForBootstrap_DCT5.. 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8981 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 82 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8981 ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0089 Device ID : 8981 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x004E (78) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 4B 0 ERASE_AREA_BB5 0x12 Block Length : 0x4B (75) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00020000-0007FFFF 3 : 00080000-000DFFFF 4 : 00100000-001FFFFF 5 : 00200000-0031FFFF 6 : 00320000-0105FFFF 7 : 01060000-01067FFF 8 : 01068000-0107FFFF ERASE_REQUEST_BB5 : 5009120B00000000000000000006BF120B000000000006C00001FFFF120B000000000200000007FFFF120B00000000080000000DFFFF120B00000000100000001FFFFF120B000000002000000031FFFF120B000000003200000105FFFF120B0000000106000001067FFF120B000000010680000107FFFF82 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds >> Time Elapsed 39 seconds >> Time Elapsed 42 seconds >> Time Elapsed 45 seconds >> Time Elapsed 48 seconds >> Time Elapsed 51 seconds >> Time Elapsed 54 seconds >> Time Elapsed 57 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:15 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm237__07.21.mcusw Total blocks to write : 944 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : PMM_CONF >> CMT Rootkey Hash CERT : SBIF_CONF ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:50 Making delay between files for 1500ms Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_x CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 279 Entry Point: 0x00A6 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0F400104 ID DWORD 1 : C2787E56 ID DWORD 2 : F0132949 ID DWORD 3 : A7AA7234 ID DWORD 4 : 0F06D10C 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 4F BootCodeLen : 61 SearchForBootstrap_DCT5.. 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8981 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 82 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8981 ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0089 Device ID : 8981 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01080000-0151FFFF ERASE_REQUEST_BB5 : 5001120B000000010800000151FFFF88 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:22 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm237__07.21.ppm_x Total blocks to write : 279 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:14 Making delay between files for 1500ms Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_x CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 356 Entry Point: 0x00B2 Page Format : 0 MAX PAGE : 0x00004000 File detected Not 128K format.... Converting image to 128k bit..... Converted file created : c:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_x_128k CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 360 Entry Point: 0x00B2 Page Format : 0 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0F400104 ID DWORD 1 : C2787E56 ID DWORD 2 : F0132949 ID DWORD 3 : A7AA7234 ID DWORD 4 : 0F06D10C 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 4F BootCodeLen : 61 SearchForBootstrap_DCT5.. 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8981 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 82 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8981 ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0089 Device ID : 8981 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01520000-01FDFFFF ERASE_REQUEST_BB5 : 5001120B0000000152000001FDFFFF92 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds >> Time Elapsed 39 seconds >> Time Elapsed 42 seconds >> Time Elapsed 45 seconds >> Time Elapsed 48 seconds >> Time Elapsed 51 seconds >> Time Elapsed 54 seconds >> Time Elapsed 57 seconds >> Time Elapsed 60 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:22 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm237__07.21.image_x_128k Total blocks to write : 360 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:31 Making delay between files for 1500ms Total Flashing Time (Booting + Erase + Flashing) : 00:04:51 |
04-21-2010, 09:39 | #39 (permalink) |
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | E52 rm-469 E52 RM-469 Code: Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-469\rm469_033.003_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 4003192102001104 > 400C192102001104 > 6003192102001104 > 600C192102001104 > 6003192102011104 > 600C192102011104 > 6003192102021104 > 600C192102021104 > 600C192102031104 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 447 Entry Point: 0x01E2 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-469\RM469_APE_ONLY_09w23v0.073.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 4003192102001104 > 400C192102001104 > 6003192102001104 > 600C192102001104 > 6003192102011104 > 600C192102011104 > 6003192102021104 > 600C192102021104 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 14 Entry Point: 0x0116 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-469\rm469_033.003_21.01_Taiwan_prd.rofs2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 4003192102001104 > 400C192102001104 > 6003192102001104 > 600C192102001104 > 6003192102011104 > 600C192102011104 > 6003192102021104 > 600C192102021104 > 600C192102031104 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 159 Entry Point: 0x00E7 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-469\rm469_033.003_243.03_TW_CV_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 4003192102001104 > 400C192102001104 > 6003192102001104 > 600C192102001104 > 6003192102011104 > 600C192102011104 > 6003192102021104 > 600C192102021104 > 600C192102031104 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 34 Entry Point: 0x00E7 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-469\rm469_033.003_U002.000_prd.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 4003192102001104 > 400C192102001104 > 6003192102001104 > 600C192102001104 > 6003192102011104 > 600C192102011104 > 6003192102021104 > 600C192102021104 > 600C192102031104 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 2 Entry Point: 0x00E7 Page Format : -1 MAX PAGE : 0x00040000 Changing MODE : FLASH VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02011104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C34 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 16500114 ID DWORD 1 : 4C340344 ID DWORD 2 : DE509AF2 ID DWORD 3 : 9450934C ID DWORD 4 : F08DCBA5 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 25 B9 77 A0 55 BE 9B 5D EC 0C 38 A2 A2 79 C6 95 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 3E273BF6 CRC 1 : 37BE26FA Checksum 49 BootCodeLen : 61 SearchForBootstrap_DCT5.. KEYS CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 19 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121 RAPUv11_XSR17_alg.fg First Algo byte : 56 XSR 1.6 phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok VPP Enabled by Software Using External VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00020000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 033E0000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 033E0000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 033E0000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 033E0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF000000040000000300000002000A0000033E000000000004000000020348000007CC000000000008000000010B140000041400000000000A000000010F640000003C00000D PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000000200A4000003000000000000040000000203A4000003500000000000080000000106F400000894000000000009000000010F880000001A000077 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) No partition info.... No partition info.... No partition info.... StartErase_DCT5... BlockLength : 0x004F (79) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 1B 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00020000-0003FFFF 1 : 00060000-004DFFFF 2 : 008E0000-0B13FFFF CurrPos : 20 CurrEraseLen : 2F 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID :0x02000000 Format Info :000000000000000A0000000000000002000000640000000B0000000200000001000000000000 ERASE_REQUEST_BB5 : 5003120B000300000200000003FFFF120B00030000060000004DFFFF120B000300008E00000B13FFFF9E Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000003 Additional Bad : 00000002 Correctable ECC : 00000000 ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000000000002000000640000000B000000020000000100000000000033 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000003 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 004E0000-008DFFFF ERASE_REQUEST_BB5 : 5001120B000300004E0000008DFFFF05 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000003 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 07340000-09CFFFFF ERASE_REQUEST_BB5 : 5001120B0003000734000009CFFFFFCD Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000003 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 09D00000-0B13FFFF ERASE_REQUEST_BB5 : 5001120B00030009D000000B13FFFFE9 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000003 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:03 Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : rm469_033.003_prd.core.fpsx Total blocks to write : 447 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : SOS+PMML >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 Processing : RM469_APE_ONLY_09w23v0.073.fpsx Total blocks to write : 14 >> CMT Rootkey Hash CERT : SOS*ENO Processing : rm469_033.003_21.01_Taiwan_prd.rofs2.fpsx Total blocks to write : 159 >> CMT Rootkey Hash CERT : SOS+ROFS2 Processing : rm469_033.003_243.03_TW_CV_prd.rofs3.fpsx Total blocks to write : 34 >> CMT Rootkey Hash CERT : SOS+ROFS3 Processing : rm469_033.003_U002.000_prd.uda.fpsx Total blocks to write : 2 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000003 Additional Bad : 00000002 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:07 Total Flashing Time (Booting + Erase + Flashing) : 00:01:14 |
04-21-2010, 09:42 | #40 (permalink) |
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | E90 ra-6 E90 RA-6 Code: Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RA-6\ra6_400.34.93_prd.c00 CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 0003192101001003 > 000C192101001003 > 0003192101001103 > 000C192101001103 > 0003192101001203 > 000C192101001203 > 0003192101002003 > 000C192101002003 > 4003192101001203 > 400C192101001203 > 4003192101002003 > 400C192101002003 > 400C192101011103 > 4003192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 3631 Entry Point: 0x02BC Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 893977DB ID DWORD 1 : 5E369F1A ID DWORD 2 : 03220DB9 ID DWORD 3 : 04A517D1 ID DWORD 4 : 1B45F9AE 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01011103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 12D00108 ID DWORD 1 : 59530058 ID DWORD 2 : A3FD1656 ID DWORD 3 : E660B208 ID DWORD 4 : 9DE4822D 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : F2C6EBAD CRC 1 : C86E6189 Checksum D7 BootCodeLen : 9A SearchForBootstrap_DCT5.. KEYS CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 2C7E -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :2C7E ExtID :0000 RevID :6921 RAPIDOv11_XSR15_alg.fg First Algo byte : 56 XSR 1.5 phone devicealgo : Flash Descriptor Manufacturer Code : 0001 Device ID : 2C7E Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00100000 (1048576) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Searching for APE Boot File.. SearchForBootstrap_DCT5... KEYS KEYS 2ND 2ND SILO SILO APE Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA2" FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0048 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 01 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 BCM21351_PI155_XSR16_usbalg.fg First Algo byte : 56 BCM21351_XSR16_usbalg.fg First Algo byte : 56 h3_sam_nand_format.fg First Algo byte : 00 h3_sam_nand_gbbm.fg First Algo byte : 00 h3_sam_nand_hdd.fg First Algo byte : 00 h3_sam_nand_xsr.fg First Algo byte : 00 h3_sam_nand_xsr_small.fg First Algo byte : 00 h3_xsr15_flash_alg.fg First Algo byte : 00 MICROv10_alg2nd.fg OMAP2420_XSR15_alg.fg First Algo byte : 56 OMAP2420 UNISTORE-II-1.5.1 ALG phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 0048 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : APE 1 Certificate 2 Name : HWC ASIC Index : APE 1 Certificate 3 Name : CCC ASIC Index : APE 1 Certificate 4 Name : R&D ASIC Index : APE 1 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 01 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 01 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 01 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 01 CF STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0003 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF00000003000000030000000200A40000013C0000000000040000000201E0000005140000000000080000000106F4000008B00000ED PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x0063 (99) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 1B 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00080000-007C26C5 1 : 00000000-0005FFFF 2 : 00880000-00FDFFFF CurrPos : 20 CurrEraseLen : 43 1 ERASE_AREA_BB5 0x12 Block Length : 0x43 (67) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 00000200-0000AFFF 1 : 0000B800-000AFFFF 2 : 00000000-00000FFF 3 : 0000D800-0000E9FF 4 : 00080000-000BFFFF 5 : 000C0000-0045FFFF 6 : 004C0000-0073FFFF 7 : 00A40000-06F3FFFF ERASE_REQUEST_BB5 : 5003120B00000000080000007C26C5120B000000000000000005FFFF120B0000000088000000FDFFFFB0 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 ERASE_REQUEST_BB5 : 5008120B010100000002000000AFFF120B0101000000B800000AFFFF120B0101000000000000000FFF120B0101000000D8000000E9FF120B01010000080000000BFFFF120B010100000C00000045FFFF120B010100004C00000073FFFF120B01010000A4000006F3FFFF09 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:05 Is Flashing CLOCK AUTO : 0 Processing : ra6_400.34.93_prd.c00 Total blocks to write : 3631 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : SOS+XZIP >> APE Rootkey Hash CERT : PASUBTOC >> APE Rootkey Hash CERT : PAPUBKEYS >> APE Rootkey Hash CERT : SOS+UPDAPP >> APE Rootkey Hash CERT : SOS*CORE >> APE Rootkey Hash CERT : SOS+ROFS ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:53 Making delay between files for 1500ms Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RA-6\ra6_400.34.93_prd.v01 CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101002003 > 400C192101002003 > 400C192101011103 > 400C192101021103 > 400C192101031103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 1094 Entry Point: 0x0138 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 893977DB ID DWORD 1 : 5E369F1A ID DWORD 2 : 03220DB9 ID DWORD 3 : 04A517D1 ID DWORD 4 : 1B45F9AE 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01011103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 12D00108 ID DWORD 1 : 59530058 ID DWORD 2 : A3FD1656 ID DWORD 3 : E660B208 ID DWORD 4 : 9DE4822D 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : F2C6EBAD CRC 1 : C86E6189 Checksum D7 BootCodeLen : 9A SearchForBootstrap_DCT5.. KEYS CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 2C7E -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :2C7E ExtID :0000 RevID :6921 RAPIDOv11_XSR15_alg.fg First Algo byte : 56 XSR 1.5 phone devicealgo : Flash Descriptor Manufacturer Code : 0001 Device ID : 2C7E Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00100000 (1048576) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Searching for APE Boot File.. SearchForBootstrap_DCT5... KEYS KEYS 2ND 2ND SILO SILO APE Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA2" FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0048 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 01 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 BCM21351_PI155_XSR16_usbalg.fg First Algo byte : 56 BCM21351_XSR16_usbalg.fg First Algo byte : 56 h3_sam_nand_format.fg First Algo byte : 00 h3_sam_nand_gbbm.fg First Algo byte : 00 h3_sam_nand_hdd.fg First Algo byte : 00 h3_sam_nand_xsr.fg First Algo byte : 00 h3_sam_nand_xsr_small.fg First Algo byte : 00 h3_xsr15_flash_alg.fg First Algo byte : 00 MICROv10_alg2nd.fg OMAP2420_XSR15_alg.fg First Algo byte : 56 OMAP2420 UNISTORE-II-1.5.1 ALG phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 0048 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0003 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 013C0000 PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF00000003000000030000000200A40000013C0000000000040000000201E0000005140000000000080000000106F4000008B00000ED PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 04E00000-06F3FFFF ERASE_REQUEST_BB5 : 5001120B01010004E0000006F3FFFF04 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:01 Is Flashing CLOCK AUTO : 0 Processing : ra6_400.34.93_prd.v01 Total blocks to write : 1094 >> APE Rootkey Hash CERT : SOS+ROFX ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:24 Making delay between files for 1500ms Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RA-6\ra6_400.34.93.01U CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101002003 > 400C192101002003 > 400C192101011103 > 400C192101021103 > 400C192101031103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 7 Entry Point: 0x00BD Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 893977DB ID DWORD 1 : 5E369F1A ID DWORD 2 : 03220DB9 ID DWORD 3 : 04A517D1 ID DWORD 4 : 1B45F9AE 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01011103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 12D00108 ID DWORD 1 : 59530058 ID DWORD 2 : A3FD1656 ID DWORD 3 : E660B208 ID DWORD 4 : 9DE4822D 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : F2C6EBAD CRC 1 : C86E6189 Checksum D7 BootCodeLen : 9A SearchForBootstrap_DCT5.. KEYS CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 2C7E -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :2C7E ExtID :0000 RevID :6921 RAPIDOv11_XSR15_alg.fg First Algo byte : 56 XSR 1.5 phone devicealgo : Flash Descriptor Manufacturer Code : 0001 Device ID : 2C7E Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00100000 (1048576) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Searching for APE Boot File.. SearchForBootstrap_DCT5... KEYS KEYS 2ND 2ND SILO SILO APE Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA2" FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0048 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 01 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 BCM21351_PI155_XSR16_usbalg.fg First Algo byte : 56 BCM21351_XSR16_usbalg.fg First Algo byte : 56 h3_sam_nand_format.fg First Algo byte : 00 h3_sam_nand_gbbm.fg First Algo byte : 00 h3_sam_nand_hdd.fg First Algo byte : 00 h3_sam_nand_xsr.fg First Algo byte : 00 h3_sam_nand_xsr_small.fg First Algo byte : 00 h3_xsr15_flash_alg.fg First Algo byte : 00 MICROv10_alg2nd.fg OMAP2420_XSR15_alg.fg First Algo byte : 56 OMAP2420 UNISTORE-II-1.5.1 ALG phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 0048 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 06F40000-0FA3FFFF ERASE_REQUEST_BB5 : 5001120B01010006F400000FA3FFFF35 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:02 Is Flashing CLOCK AUTO : 0 Processing : ra6_400.34.93.01U Total blocks to write : 7 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:04 Making delay between files for 1500ms Total Flashing Time (Booting + Erase + Flashing) : 00:02:45 |
04-21-2010, 09:44 | #41 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | N72 rm-180 N72 RM-180 Code: Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50819401.C0 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0003192101012200 > 000C192101012200 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP1610 GBBM-1.8.1 ALG APE Supported Hardwares : > 17100701 > 17100702 Number of Blocks : 1104 Entry Point: 0x0157 Page Format : -1 MAX PAGE : 0x00008000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50819401.V11 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0000000000000000 > 0003192101002000 > 000C192101002000 > 0003192101002100 > 000C192101002100 > 0003192101002200 > 000C192101002200 > 0003192101012200 > 000C192101012200 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 100000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP1610 GBBM-1.8.1 ALG APE Supported Hardwares : > 17100700 > 17100701 > 17100702 > 17100703 Number of Blocks : 1442 Entry Point: 0x0154 Page Format : -1 MAX PAGE : 0x00002000 Changing MODE : FLASH VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 12 (0x0C) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 17100701 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : C523C0BA ID DWORD 1 : 3610B12D ID DWORD 2 : 74F3804A ID DWORD 3 : DD8D9A45 ID DWORD 4 : 0A25F036 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : 2C 05 36 9F 57 CC 3C 4C F9 E7 83 E8 3D 9B 51 2B 00 00 00 00 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 1 (01) APE CRC 0 : AB5E4ADB CRC 1 : 27A06946 6 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 000C1921 ID DWORD 4 : 01012200 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 8 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000352 9 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0B500018 ID DWORD 1 : 6BE64F51 ID DWORD 2 : 5DCE1590 ID DWORD 3 : 723E821D ID DWORD 4 : EA263F19 10 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 11 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : E9 EF F4 BF AA 53 93 21 7C A6 B1 77 55 FC 3E 14 12 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : F28A211F CRC 1 : CEA7B19D Checksum 94 BootCodeLen : A5 SearchForBootstrap_DCT5.. 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv2_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 0002 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0111 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 8B SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :0002 ExtID :0000 RevID :0111 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0001 Device ID : 0002 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 08000000 (134217728) VPP Info : 001F Erase10s : 32 Block1s : 02 BErase1s : 00 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_5V_MASK VPP_INFO_12V_MASK VPP_INFO_9V_MASK VPP_INFO_ERASE_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Searching for APE Boot File.. SearchForBootstrap_DCT5... KEYS KEYS 2ND APE Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\helen3_2nd.fg TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. APE LOADER SIZE : 00003500 SendAPECodeRequest_DCT5 FLS1_NO_ERROR.. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0036 -> K5E1212ACM Extended/Fixed ID : 00A5 Revision ID : 00C0 2 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 19 BB ASIC Index : APE 01 Data : OMAP1610 GBBM-1.8.1 ALG 3 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Device Contents : 00020000000600000000 Checksum : 97 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 BCM21351_PI155_XSR16_usbalg.fg First Algo byte : 56 BCM21351_XSR16_usbalg.fg First Algo byte : 56 h3_sam_nand_format.fg First Algo byte : 00 OMAP1610 FORMAT ALG phone devicealgo : OMAP1610 GBBM-1.8.1 ALG h3_sam_nand_gbbm.fg First Algo byte : 00 OMAP1610 GBBM-1.8.1 ALG phone devicealgo : OMAP1610 GBBM-1.8.1 ALG Flash Descriptor Manufacturer Code : 00EC Device ID : 0036 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0015 Erase10s : 0F Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_12V_MASK VPP_INFO_ERASE_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\h3_sam_nand_gbbm.fg 0000A910 TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 01 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 010F72BF9DE5D6711B3B1133EBCAB5914FA419C78D ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : 00000000 Num Partitions : 0003 Partition 1 ID : 00070000 NBL1 Attribute : 00680000 Start Address : 00000000 Size : 00010000 Partition 2 ID : 00070000 NBL1 Attribute : 00680000 Start Address : 00000000 Size : 00010000 Partition 3 ID : 00070000 NBL1 Attribute : 00680000 Start Address : 00000000 Size : 00010000 PARTITION_INFO_REQUEST_BB5 : 64012F3F0101000001000000000000000000030007000000680000000000000001000002B00000013D00000000000100010000006F000002410000000000000001000075 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : 00000000 Num Partitions : 0003 Partition 1 ID : 00070000 NBL1 Attribute : 00680000 Start Address : 00000000 Size : 00010000 Partition 2 ID : 00070000 NBL1 Attribute : 00680000 Start Address : 00000000 Size : 00010000 Partition 3 ID : 00070000 NBL1 Attribute : 00680000 Start Address : 00000000 Size : 00010000 PARTITION_INFO_REQUEST_BB5 : 64012F3F0101000001000000000000000000030007000000680000000000000001000002B00000013D00000000000100010000006F000002410000000000000001000075 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x004B (75) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 23 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-0052B6C1 1 : 006A0000-006BFFFF 2 : 006DF000-006EFFFF 3 : 00700000-007EFFFF CurrPos : 28 CurrEraseLen : 23 1 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 00000000-0000FFFF 1 : 00010000-0001FFFF 2 : 00020000-000203FF 3 : 00050000-03ECFFFF ERASE_REQUEST_BB5 : 5004120B000000000000000052B6C1120B000000006A0000006BFFFF120B000000006DF000006EFFFF120B00000000700000007EFFFF36 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds >> Time Elapsed 39 seconds >> Time Elapsed 42 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 01 Device Type : 00 Num Bad Blocks : 009DE5D6 Additional Bad : 001B3B11 Correctable ECC : 00EBCAB5 ERASE_REQUEST_BB5 : 5004120B010100000000000000FFFF120B010100000100000001FFFF120B01010000020000000203FF120B0101000005000003ECFFFF89 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 01 Device Type : 00 Num Bad Blocks : 009DE5D6 Additional Bad : 001B3B11 Correctable ECC : 00EBCAB5 Successfully erased.. StartErase_DCT5... BlockLength : 0x0016 (22) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 13 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 01AE0000-02AFFFFF 1 : 02B00000-03ECFFFF ERASE_REQUEST_BB5 : 5002120B01010001AE000002AFFFFF120B01010002B0000003ECFFFFC2 >> Time Elapsed 3 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 01 Device Type : 00 Num Bad Blocks : 009DE5D6 Additional Bad : 001B3B11 Correctable ECC : 00EBCAB5 Successfully erased.. Time Taken to Erase : 00:00:59 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : RM180_50819401.C0 Total blocks to write : 1104 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : SOS+LOADER >> APE Rootkey Hash CERT : SOS+XZIP >> APE Rootkey Hash CERT : PASUBTOC >> APE Rootkey Hash CERT : PAPUBKEYS >> APE Rootkey Hash CERT : SOS*CORE Processing : RM180_50819401.V11 Total blocks to write : 1442 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 01 Device Type : 00 Num Bad Blocks : 009DE5D6 Additional Bad : 001B3B11 Correctable ECC : 00EBCAB5 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:25 Total Flashing Time (Booting + Erase + Flashing) : 00:02:29 |
04-21-2010, 09:46 | #42 (permalink) |
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | N73 rm-133 N73 RM-133 Code: Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-133\N73_4.0850.43.0.1_western_C00_PRD_cc.fpsx CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101003000 > 010C192101003000 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP1710 UNISTORE-II-1.2.1 ALG APE Supported Hardwares : > 17100708 Number of Blocks : 1732 Entry Point: 0x1B5C6 Page Format : -1 MAX PAGE : 0x00008000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-133\N73_rofx_4.0850.43.0.1_PRD.V77 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0000000000000000 > 0003192101002000 > 000C192101002000 > 0003192101002100 > 000C192101002100 > 0003192101002200 > 000C192101002200 > 0103192101003000 > 010C192101003000 > 0103192101013000 > 010C192101013000 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 100000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP1710 UNISTORE-II-1.2.1 ALG APE Supported Hardwares : > 17100700 > 17100701 > 17100702 > 17100708 Number of Blocks : 2184 Entry Point: 0x0172 Page Format : -1 MAX PAGE : 0x00002000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-133\N73_userarea_4.0850.43.0.1.U03 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0000000000000000 > 0003192101002000 > 000C192101002000 > 0003192101002100 > 000C192101002100 > 0003192101002200 > 000C192101002200 > 0103192101003000 > 010C192101003000 > 0103192101013000 > 010C192101013000 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 100000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP1710 UNISTORE-II-1.2.1 ALG APE Supported Hardwares : > 17100708 Number of Blocks : 164 Entry Point: 0x011B Page Format : -1 MAX PAGE : 0x00008000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 12 (0x0C) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 17100708 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 4F82F41F ID DWORD 1 : C5D95D3E ID DWORD 2 : E5CE04E7 ID DWORD 3 : 01529DBD ID DWORD 4 : F5A92B70 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : 49 A9 7E 82 6B 93 BA 20 B7 ED 0B 08 24 75 C0 05 00 00 00 00 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 1 (01) APE CRC 0 : 1DFD6613 CRC 1 : 2C872FD4 6 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01003000 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 8 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B21 9 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 16600114 ID DWORD 1 : 73BF0054 ID DWORD 2 : D668DB04 ID DWORD 3 : B223A590 ID DWORD 4 : 9D149608 10 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 11 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 12 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum D9 BootCodeLen : A5 SearchForBootstrap_DCT5.. 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 22E8 -> K5G2829ATC Extended/Fixed ID : 0000 Revision ID : 6921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 20 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :22E8 ExtID :0000 RevID :6921 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 22E8 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00100000 (1048576) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Searching for APE Boot File.. SearchForBootstrap_DCT5... KEYS KEYS 2ND APE Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\helen3_2nd.fg TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. APE LOADER SIZE : 00003500 SendAPECodeRequest_DCT5 FLS1_NO_ERROR.. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 02 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 00A1 -> K5E1G12ACM Extended/Fixed ID : 0080 Revision ID : 0015 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Device Contents : FFFFFFFFFFFFFFFFFFFF Checksum : A8 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 BCM21351_PI155_XSR16_usbalg.fg First Algo byte : 56 BCM21351_XSR16_usbalg.fg First Algo byte : 56 h3_sam_nand_format.fg First Algo byte : 00 OMAP1610 FORMAT ALG phone devicealgo : h3_sam_nand_gbbm.fg First Algo byte : 00 OMAP1610 GBBM-1.8.1 ALG phone devicealgo : h3_sam_nand_hdd.fg First Algo byte : 00 OMAP1610 GBBM-1.8.1 ALG phone devicealgo : h3_sam_nand_xsr.fg First Algo byte : 00 OMAP1710 UNISTORE-II-1.2.1 ALG phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 00A1 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00800000 (8388608) VPP Info : 0015 Erase10s : 0F Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_12V_MASK VPP_INFO_ERASE_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\h3_sam_nand_xsr.fg 00013AA8 TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 01 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 015E8D0D504A0902E261268C14FCD8A2C9093523BC ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0003 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00420000 Size : 00E80000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00420000 Size : 00E80000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00420000 Size : 00E80000 PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF0000000300000003000000020042000000E800000000000400000002012A000003B80000000000080000000104E2000002E800009A PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0003 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00420000 Size : 00E80000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00420000 Size : 00E80000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00420000 Size : 00E80000 PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF0000000300000003000000020042000000E800000000000400000002012A000003B80000000000080000000104E2000002E800009A PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) Setting VPP to : 9.0V VPP Enabled by Software Using External VPP StartErase_DCT5... BlockLength : 0x004B (75) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 23 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00080000-0073194D 1 : 00000000-0005FFFF 2 : 001E0000-001FFFFF 3 : 00880000-00FEFFFF CurrPos : 28 CurrEraseLen : 23 1 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 00000000-0007FFFF 1 : 00080000-000FFFFF 2 : 00100000-0025FFFF 3 : 003C0000-04E1FFFF ERASE_REQUEST_BB5 : 5004120B000000000800000073194D120B000000000000000005FFFF120B000000001E0000001FFFFF120B0000000088000000FEFFFFE4 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00504A09 Additional Bad : 00E26126 Correctable ECC : 0014FCD8 ERASE_REQUEST_BB5 : 5004120B010100000000000007FFFF120B01010000080000000FFFFF120B010100001000000025FFFF120B010100003C000004E1FFFF13 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00504A09 Additional Bad : 00E26126 Correctable ECC : 0014FCD8 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 03920000-04E1FFFF ERASE_REQUEST_BB5 : 5001120B0101000392000004E1FFFF67 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00504A09 Additional Bad : 00E26126 Correctable ECC : 0014FCD8 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 04E20000-07C9FFFF ERASE_REQUEST_BB5 : 5001120B01010004E2000007C9FFFF2B Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00504A09 Additional Bad : 00E26126 Correctable ECC : 0014FCD8 Successfully erased.. Time Taken to Erase : 00:00:39 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : N73_4.0850.43.0.1_western_C00_PRD_cc.fpsx Total blocks to write : 1732 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : ADL >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : SOS+LOADER >> APE Rootkey Hash CERT : SOS*UPDAPP >> APE Rootkey Hash CERT : SOS+UZIP >> APE Rootkey Hash CERT : PAPUBKEYS >> APE Rootkey Hash CERT : PASUBTOC >> APE Rootkey Hash CERT : ADL >> APE Rootkey Hash CERT : SOS+XZIP >> APE Rootkey Hash CERT : SOS*CORE >> APE Rootkey Hash CERT : SOS+ROFS >> APE Rootkey Hash CERT : SOS+ROFX Processing : N73_rofx_4.0850.43.0.1_PRD.V77 Total blocks to write : 2184 >> APE Rootkey Hash CERT : SOS+ROFX Processing : N73_userarea_4.0850.43.0.1.U03 Total blocks to write : 164 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00504A09 Additional Bad : 00E26126 Correctable ECC : 0014FCD8 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:20 Total Flashing Time (Booting + Erase + Flashing) : 00:02:07 |
04-21-2010, 09:54 | #43 (permalink) |
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | N95 8gb rm-320 N95 8GB RM-320 Code: Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_35.0.001_PR.C0R CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 441 Entry Point: 0x026E Page Format : -1 MAX PAGE : 0x00030000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_35.0.001_PR.v26 CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101021103 > 400C192101021103 > 4003192101002003 > 400C192101002003 > 400C192101011103 > 4003192101011103 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 62 Entry Point: 0x0159 Page Format : -1 MAX PAGE : 0x00030000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-320\RM320_31.0.002_025_www_U04_uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101021103 > 400C192101021103 > 4003192101002003 > 400C192101002003 > 400C192101011103 > 4003192101011103 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 130 Entry Point: 0x00D7 Page Format : -1 MAX PAGE : 0x00030000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : BB64AB5A ID DWORD 1 : 4B8192BD ID DWORD 2 : 52A5C72E ID DWORD 3 : 8FACFEAA ID DWORD 4 : E1CC7E39 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 19C0000C ID DWORD 1 : 1E6E0058 ID DWORD 2 : CE70ED64 ID DWORD 3 : 9B19077C ID DWORD 4 : 453B0AE3 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum 79 BootCodeLen : 9A SearchForBootstrap_DCT5.. KEYS CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 2C7E -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :2C7E ExtID :0000 RevID :6921 RAPIDOv11_XSR15_alg.fg First Algo byte : 56 XSR 1.5 phone devicealgo : Flash Descriptor Manufacturer Code : 0001 Device ID : 2C7E Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00100000 (1048576) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok VPP Enabled by Software Using External VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Searching for APE Boot File.. SearchForBootstrap_DCT5... KEYS KEYS 2ND 2ND SILO SILO APE Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA2" FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 01 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 BCM21351_PI155_XSR16_usbalg.fg First Algo byte : 56 BCM21351_XSR16_usbalg.fg First Algo byte : 56 h3_sam_nand_format.fg First Algo byte : 00 h3_sam_nand_gbbm.fg First Algo byte : 00 h3_sam_nand_hdd.fg First Algo byte : 00 h3_sam_nand_xsr.fg First Algo byte : 00 h3_sam_nand_xsr_small.fg First Algo byte : 00 h3_xsr15_flash_alg.fg First Algo byte : 00 MICROv10_alg2nd.fg OMAP2420_XSR15_alg.fg First Algo byte : 56 OMAP2420 UNISTORE-II-1.5.1 ALG phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : APE 1 Certificate 2 Name : HWC ASIC Index : APE 1 Certificate 3 Name : CCC ASIC Index : APE 1 Certificate 4 Name : R&D ASIC Index : APE 1 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 01 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 01 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 01 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 01 CF STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000000200A4000003000000000000040000000203A4000003500000000000080000000106F400000894000000000009000000010F880000001A000077 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000000200A4000003000000000000040000000203A4000003500000000000080000000106F400000894000000000009000000010F880000001A000077 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) No partition info.... Setting VPP to : 9.0V StartErase_DCT5... BlockLength : 0x0063 (99) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 1B 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00080000-007CF385 1 : 00000000-0005FFFF 2 : 00880000-00FDFFFF CurrPos : 20 CurrEraseLen : 43 1 ERASE_AREA_BB5 0x12 Block Length : 0x43 (67) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 00000200-0000AFFF 1 : 0000B800-000AFFFF 2 : 00000000-00000FFF 3 : 0000D800-0000E9FF 4 : 00080000-000BFFFF 5 : 000E0000-0045FFFF 6 : 004C0000-0073FFFF 7 : 00A40000-06F3FFFF ERASE_REQUEST_BB5 : 5003120B00000000080000007CF385120B000000000000000005FFFF120B0000000088000000FDFFFF23 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 ERASE_REQUEST_BB5 : 5008120B010100000002000000AFFF120B0101000000B800000AFFFF120B0101000000000000000FFF120B0101000000D8000000E9FF120B01010000080000000BFFFF120B010100000E00000045FFFF120B010100004C00000073FFFF120B01010000A4000006F3FFFF07 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000005 Additional Bad : 00000005 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 05140000-06F3FFFF ERASE_REQUEST_BB5 : 5001120B0101000514000006F3FFFFCF Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000005 Additional Bad : 00000005 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:31 Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : RM-320_35.0.001_PR.C0R Total blocks to write : 441 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : SOS+XZIP >> APE Rootkey Hash CERT : PASUBTOC >> APE Rootkey Hash CERT : PAPUBKEYS >> APE Rootkey Hash CERT : SOS+UPDAPP >> APE Rootkey Hash CERT : SOS+CORE >> APE Rootkey Hash CERT : SOS+ROFS Processing : RM-320_35.0.001_PR.v26 Total blocks to write : 62 >> APE Rootkey Hash CERT : SOS+ROFX Processing : RM320_31.0.002_025_www_U04_uda.fpsx Total blocks to write : 130 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000005 Additional Bad : 00000005 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:18 Total Flashing Time (Booting + Erase + Flashing) : 00:01:55 |
04-21-2010, 09:56 | #44 (permalink) |
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | X6 rm-559 X6 RM-559 Code: Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-559\RM-559_12.0.091_prd.core.C00 CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 429 Entry Point: 0x2A6810 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-559\RM-559_12.0.091_prd.rofs2.V20 CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 76 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-559\RM-559_12.0.091_C04_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 26 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-559\RM559_12.0.091_011_000_U001.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 33 Entry Point: 0x00F9 Page Format : -1 MAX PAGE : 0x00040000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0ED00019 ID DWORD 1 : DF8A0052 ID DWORD 2 : D8E531D3 ID DWORD 3 : A136C42D ID DWORD 4 : C9C23495 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum C3 BootCodeLen : 61 SearchForBootstrap_DCT5.. KEYS CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0058 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : FD SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0058 ExtID :0000 RevID :0121 RAPIDOv11_XSR15_alg.fg First Algo byte : 56 XSR 1.5 phone devicealgo : RAPIDOv11_XSR17_alg.fg First Algo byte : 56 XSR 1.6 phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 0058 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00020000 (131072) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR17_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok VPP Enabled by Software Using External VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 02940000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 02940000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 02940000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 02940000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200080000029400000000000400000002029C000008D6000000000008000000010B720000138600000000000A000000011F140000003C0000BE PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000000200A4000003000000000000040000000203A4000003500000000000080000000106F400000894000000000009000000010F880000001A000077 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) No partition info.... No partition info.... StartErase_DCT5... BlockLength : 0x0057 (87) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 23 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-00082FFF 1 : 00083400-003FFFFF 2 : 00800000-00D5FFFF 3 : 00D60000-0B71FFFF CurrPos : 28 CurrEraseLen : 2F 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID :0x02000000 Format Info :000000000000000A0000000000000002000000640000000B0000000200000001000000000000 ERASE_REQUEST_BB5 : 5004120B0003000004000000082FFF120B00030000083400003FFFFF120B0003000080000000D5FFFF120B00030000D600000B71FFFF25 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000000000002000000640000000B000000020000000100000000000033 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 07920000-0A2FFFFF ERASE_REQUEST_BB5 : 5001120B000300079200000A2FFFFF0E Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0A300000-0B71FFFF ERASE_REQUEST_BB5 : 5001120B0003000A3000000B71FFFF2A Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:02 Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : RM-559_12.0.091_prd.core.C00 Total blocks to write : 429 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 Processing : RM-559_12.0.091_prd.rofs2.V20 Total blocks to write : 76 >> CMT Rootkey Hash CERT : SOS+ROFS2 Processing : RM-559_12.0.091_C04_prd.rofs3.fpsx Total blocks to write : 26 >> CMT Rootkey Hash CERT : SOS+ROFS3 Processing : RM559_12.0.091_011_000_U001.uda.fpsx Total blocks to write : 33 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:00 Total Flashing Time (Booting + Erase + Flashing) : 00:01:06 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
How unlock new nokia5110 version 5.20 ? | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 01-21-2011 07:45 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
How unlock Nokia version 5.20 | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-17-1999 17:35 |
