07-30-2014, 08:52
#16 (permalink)
Member: 1740101
Sonork: 100.1641580 Thanks Meter: 11 | Quote:
Originally Posted by advance-box here is the screenshot: here are the logs: Code: number of image files: 3
processing image file :
Rm840__02.03b.mcusw
Rm840__02.03b.ppm_s1
Rm840__02.03b.image_s1_059s0j6
[]: Found 1 active devices.
[nokia usb phonet]: Opening connection
[nokia usb phonet]: Port opened ok!
Sw: V 02.03b 08-04-13 rm-840 (c) nokia
imei: 355520052215199
start full pm backup
please wait...
Reading : Pm 0~400... Ok!
Full pm backup saved to:
C:\advancebox application_new\nokia\backup\355520052215199\usb_full_backup_v 02.03b 08-04-13 rm-840 (c) nokia_355520052215199__84157.pm
reading battery value : 3671 mv
rebooting phone...
Auto selected dead usb flashing...
If phone booting does not start in 5 seconds,
then perform steps 1, 2, 3 and 4...
1. Remove usb cable and battery...
2. Connect usb cable.
3. Connect battery.
***** if phone starts charging or does not boot *****
******* remove battery and put it back again. *******
infineon boot: F01650a9070100030101a0401409000cf0b148a001b5ffff
<<<< connect battery now >>>>
sending pbl...
Pbl successfully sent...
Sending sbl...
Sbl successfully sent...
Flash chip manufacturer: Stmicroelectronics
flash boot successful...
Unique data: A0401409000cf0b1-48a001b5
original product code: 059s5s8
reading : Ccc... Ok!
Reading : Hwc... Ok!
Reading : Npc... Ok!
Rpl backup was successful...
Plain rpl saved to:
C:\advancebox application_new\nokia\backup\355520052215199\355520052215199_84205.rpl
current file : Rm840__02.03b.mcusw
number of images: 8
psi_flash_unsigned.fls
slb_signed.fls
main_toc_signed.fls
rm840__02.03b.mcusw_signed_mcusw.fls
swap_signed.fls s
dynsw.fls
aeneas_signed.fls s
fota_signed.fls s
processing data block 0x00
erase block: 0x00090000~0x000a0fde
start erasing...
Erasing please wait...
Block erase done...
Start writing...
Finalizing...
Data block write done...
Processing data block 0x01
erase block: 0x60000000~0x6003fffe
start erasing...
Block erase done...
Start writing...
Finalizing...
Processing data block 0x02
erase block: 0x60040000~0x600403fe
start erasing...
Block erase done...
Start writing...
Finalizing...
Processing data block 0x03
erase block: 0x62e00000~0x63d03dca
start erasing...
Block erase done...
Start writing...
Finalizing...
Erase block: 0xfff00000~0xfff7fffe
start erasing...
Block erase done...
Processing data block 0x04
erase block: 0x80000000~0x80c13e9a
start erasing...
Block erase done...
Start writing...
Finalizing...
Processing data block 0x05
erase block: 0x62080000~0x620c3ffe
start erasing...
Block erase done...
Start writing...
Finalizing...
Processing data block 0x06
erase block: 0x63f79c00~0x63ff046e
start erasing...
Block erase done...
Start writing...
Finalizing...
Processing data block 0x07
erase block: 0x61f00004~0x62045396
start erasing...
Block erase done...
Start writing...
Finalizing...
Current file : Rm840__02.03b.ppm_s1
number of images: 1
package_s1.ppm_ebl_psi.fls
erase block: 0x80f00000~0x815f5e32
start erasing...
Block erase done...
Start writing...
Finalizing...
Current file : Rm840__02.03b.image_s1_059s0j6
number of images: 1
package_s1_059s0j6.image.fls
erase block: 0xa1000000~0xa27c47fe
start erasing...
Block erase done...
Start writing...
Finalizing...
Erase block: 0xae000000~0xae2ffffe
start erasing...
Block erase done...
Total flashing time (erase + flashing) : 00:00:13
(booting time is not included)
waiting for phone to start-up..(max 150 seconds)
scanning usb ports...
basic phone information
mcu version: V 02.03b 08-04-13 rm-840 (c) nokia
imei plain : 355520052215199
imei spare : A355520052215190
imei sv : 33555200522151904f
phone model: Nokia 301
category : Phone
phone type : Rm-840
extended phone information
product serial number: 026864abh
product code : 059s0j6
module code : 0205267
basic production code: 059p5r1
long production sn : 0
ppm sw version : V 02.03b 08-04-13 rm-840 (c) nokia s1
adsp version : Pmu_maxim8939b
mcu sw version : V 02.03b 08-04-13 rm-840 (c) nokia
hw version : 1000
upp version : Mfr:0x20,dev:0x40,rev:0x131
rfic version : 152
lcd version : Tpo
camera : 01035602006003
content pack version : Content: S1_059s0j6 v 02.03b 08-04-13 rm-840 (c) nokia
ahne version : 13
retu version : Pmu_maxim8939b
bluetooth id : C8:d1:0b:97:65:d5
cs type : Gsm850, gsm900, gsm1800, gsm1900, wcdma i, wcdma viii
********** simlock info **********
config_data : 0010100000000000
profile_bits : 800000000004000b
asic : 11
provider : Default test operator
lock counters: Keypress 0/3, fbus 0/10
block [1] 1:open 2:open 3:open 4:open 5:open
block [2] 1:open 2:open 3:open 4:open 5:open
block [3] 1:open 2:open 3:open 4:open 5:open
block [4] 1:open 2:open 3:open 4:open 5:open
block [5] 1:open 2:open 3:open 4:open 5:open
block [6] 1:open 2:open 3:open 4:open 5:open
block [7] 1:open 2:open 3:open 4:open 5:open
simlock_type : Pa_simloc30 (20-digit nck)
simlock_test : Passed
security_test : Passed
security_code : 12345
phone_mode : Test
dynamic camera configuration
dcc id : 01035602
dcc ver: 006003
status : Ok
selected vpl file:
Rm840_059s0j6_02.03b_031.vpl
variant details : Rm-840 swap_s1_black_light_swap_eng_ph
software version : 02.03b
product type : Rm-840
variant version : 031
factory set to : Full factory set
ok
factory set to : User data
ok
factory set to : Leave factory
ok
factory set to : Service center
ok
factory set to : Software upgrade
ok
factory set to : Production tune
ok
life timer data is not yet used...
Life timer: ----:-- here is my test phone: another tested flashing |
can u plss explain me about this phone nokia 301 (rm-839).... My question is in ur thread its show rm-840 but i have sam phone 301 in rm-839 what is the matter plss explain and how to flash in atf?????? I tiered but not booting |
