Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 05-18-2013, 18:49   #1 (permalink)
.::Gsm-Play::.'s Avatar
Member: 1615596
Sonork: 100.1607045
Thanks Meter: 663
Arrow ATF Big Chrome Box modified pcb Fbus booting problem ???.
Hi...ATF team...
I try to restore box and update firmware but still have same problem.
Im also using good quality [DITS & GPG] f bus cable.
Here is my log & screenshots...
1. bus check log....
Booting Phone via FBUS...
VBATT Powering Down <<<<
VBATT Powering Up   >>>>
SET VCCIO Level Done
SET BSI Load Done
SET BSI Load Done
SET BSI Load Done
BootFlashModeDCT5Ex Failed
ERROR: FBUS Boot FAILED
2. Scan log...
Forcing Test Mode via BUSCHECK...
SET BSI Load Done
SET BSI Load Done
SET BSI Load Done
             Basic Phone Information
ATF team please fix my problem. .
Old 05-19-2013, 12:56   #2 (permalink)
rasheedc007's Avatar
Member: 1245320
Sonork: 100.1612126
Thanks Meter: 137
also facing many persons...atf team give replay quickly..........
Old 05-20-2013, 04:09   #3 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,017
@ALL
When you are restoring the box, do you see
BLUE + GREEN + ORANGE LED **** ON?
When you are doing BUSCHECK, do you see GREEN + ORANGE Blinking???
Old 05-20-2013, 14:46   #4 (permalink)
Member: 1615596
Sonork: 100.1607045
Thanks Meter: 663
Originally Posted by Advance-Box View Post
@ALL
While restoring box LED BLUE + GREEN + ORANGE LED**** Yes ON
While update box firmware LED BLUE + GREEN + ORANGE LED****Yes ON
While bus check with my box LED GREEN + ORANGE Blinking Yes
Respect ATF team manager Advance-box waiting your good reply.
Old 05-20-2013, 17:30   #5 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,465
@.::SoFtWaRe ZoNe::.
Tick on "Modified PCB" and Restore Box.
Old 05-21-2013, 22:10   #6 (permalink)
Member: 1615596
Sonork: 100.1607045
Thanks Meter: 663
Hi... Ali..
I Ticked "Modified PCB" Option before Restore Box. You Can Check Post No;1 Screenshots. But No Luck Still Have Same Problem. Please Help Me ATF Team.
Old 05-22-2013, 09:32   #7 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,127
Originally Posted by .::SoFtWaRe ZoNe::. View Post
Hi... Ali..
Attach both side PCB photo here of your ATF
Br - srinibas
Old 06-07-2013, 23:53   #8 (permalink)
Member: 1282563
My box is not booting via Fbus since i bought it. i have restored and updated the box but no luck.
Also my PCB is different than picture shown, so cant modify my PCB as those four components i need to remove are not there.
BLUE + GREEN + ORANGE LED **** ON? YES
When you are doing BUSCHECK, do you see GREEN + ORANGE Blinking??? Blue is on and green blinking. Orange light does not turn on at all
PLS help me ..
thanks
Old 06-08-2013, 07:28   #9 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
PLS help me ..
thanks
You have new type of PCB inside the box so no need to modify it . Tick on normal PCB & update box firmware .
Br - srinibas
Old 06-08-2013, 08:52   #10 (permalink)
Member: 1282563
Hi Srinibas
i have updated box already still following error
PLS help
Old 06-08-2013, 10:43   #11 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Hi Srinibas
PLS help
Knock me on sonork , want to check it
Br - srinibas
Old 06-12-2013, 05:34   #12 (permalink)
talkways's Avatar
Member: 268887
Thanks Meter: 89
@ALL
When I update firmware I get only BLUE + Orange light, Green light is always off. I tried both Normal PCB and Modified firmware. Is my box okay?
Old 06-12-2013, 06:10   #13 (permalink)
mrrobin's Avatar
Member: 888712
Thanks Meter: 271
please try this ,i think solve your problem
modify_pcb - Download - 4shared
Old 06-28-2013, 09:40   #14 (permalink)
Member: 1615596
Sonork: 100.1607045
Thanks Meter: 663
Big ATF Box Fbus Boot Problem : Help
Old 06-28-2013, 12:35   #15 (permalink)
Member: 1930745
Sonork: 100.1621645
Thanks Meter: 29
try to change RJ45 PORT,,,
I HAVE EVER EXPERIENCED,Done with change rj45 .
Page generated in 0.42253 seconds with 7 queries
