11-12-2013, 02:17 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: tropical island
Member: 1568769 Status: Offline Sonork: 161.1167 Thanks Meter: 208 | atf big problem need help eMMC Test Point Connection Module 14:20:13 : ================================================== ==== 14:20:13 : ================================================== ==== 14:20:13 : 14:20:13 : 1. DO NOT USE THE PHONE"S BATTERY 14:20:13 : 2. Connect the Soldered TP Connections to ATF Box 14:20:13 : 3. Disconnect the USB Cable and Wait until the 14:20:13 : the ATF Software will tell you to Connect the USB. 14:20:13 : 14:20:13 : MMC_TP_SEND_CMD: 0200000000A9FF 14:20:13 : MMC_TP_SEND_CMD: 8202FF010191 14:20:13 : MMC_TP_SEND_CMD: 8202FF010191 14:20:13 : 14:20:13 : Interface Reset OK! 14:20:13 : eMMC Supported Voltage Range: 14:20:13 : 3.5-3.6V, 3.4-3.5V, 2.6-2.7V, 2.5-2.6V, 2.4-2.5V 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V, 1.9-2.0V 14:20:13 : MMC_TP_SEND_CMD: 4200000000B2 14:20:13 : ERROR: EMMC_ALL_SEND_CID FAILED (CMD2) 14:20:13 : Check your Test Point Soldering! 14:20:13 : Try to Adjust VCCIO Voltage |
11-12-2013, 12:49 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | TP picture - C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX If not there > Update Important file Br - srinibas |
