05-18-2015, 17:11 | #16 (permalink) |
Junior Member Join Date: May 2008 Location: Nigeria
Member: 774985 Status: Offline Thanks Meter: 3 | Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.80 AdvanceBox SN : D2ED7894A9E15A6182D0A04C ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Please solve this activation problem. Thanks |
05-23-2015, 16:01 | #17 (permalink) |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | ı same problem Referring to box running just does not work after the firmware update Restore box restore eprom update firmware and new driver but not working help me atf team here is the working box log B:R http://forum.gsmhosting.com/vbb/f609.../#post11066381 |
05-23-2015, 17:23 | #18 (permalink) | |
Member: 194907 Status: Offline Thanks Meter: 114 | Quote:
02-09-2016, 11:46 | #19 (permalink) |
No Life Poster Join Date: May 2007 Location: INDIA
Member: 511749 Status: Offline Thanks Meter: 335 | atf box activation problem Driver Version : 00020824 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.70 AdvanceBox SN : 9D7A71E99FDC9538F583FF1D Box Status : NOT ACTIVATED pls help to activate |
08-20-2018, 15:26 | #20 (permalink) |
Freak Poster Join Date: Nov 2014
Member: 2301015 Status: Offline Sonork: 100.1668279 Thanks Meter: 10 | NEED HELP ACTIVATED -Box Status : NOT ACTIVATED Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : CADC5294C40B8B949D5A08C4 Box Status : NOT ACTIVATED |
09-06-2018, 17:31 | #21 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | ATF Server Busy Advance Turbo Flasher Found ================================================ Driver Version : 00020808 Library Version : 00030202 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : 8232E3CFD07F1875E133A28E ========================================= Please Try Again Later (Server Busy) |
04-05-2019, 13:02 | #24 (permalink) |
Insane Poster Join Date: Jun 2016 Location: pakistan
Member: 2592409 Status: Offline Thanks Meter: 15 | plz solve my problm ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : A043248ED9849204EEEF0F51 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
04-05-2019, 13:03 | #25 (permalink) |
Member: 2592409 Status: Offline Thanks Meter: 15 | I need you help ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : A043248ED9849204EEEF0F51 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
04-15-2019, 18:27 | #26 (permalink) |
Freak Poster Join Date: Jan 2005 Location: iran Age: 41
Member: 103931 Status: Offline Thanks Meter: 31 | Dear Atf Box Supporter! please check this problem ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : FA7A04949BEA2E00ED980EE8 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-25-2020, 10:45 | #27 (permalink) |
Junior Member Join Date: Mar 2016 Location: Uzbekistan Samarkand City
Member: 2549492 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : B23D1208E316892E95C54D48 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done plz help |
04-25-2020, 13:58 | #28 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2327468 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.60 AdvanceBox SN : AF2AD1E9E25753A5ECDBFF0D ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
05-06-2020, 07:42 | #30 (permalink) |
Insane Poster Join Date: Aug 2012 Location: tajikistan
Member: 1793602 Status: Offline Thanks Meter: 6 | Dear Atf Box Supporter! please check this problem Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : B571A2CEA34FBE35D579D8B3 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
