Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-25-2010, 09:38   #1 (permalink)
Member: 823633
Thanks Meter: 1,705
atf box driver prob here
not conect atf box please help
after box blue led on
phone not flash bus check error
Old 09-25-2010, 11:25   #2 (permalink)
Member: 823633
Thanks Meter: 1,705
i am try MProg 3.5 Release but not work
Old 09-26-2010, 05:46   #3 (permalink)
Member: 1401866
Thanks Meter: 2
http://forum.gsmhosting.com/vbb/f609...18/index2.html
pls use this reply.
Old 09-26-2010, 06:08   #4 (permalink)
Member: 823633
Thanks Meter: 1,705
okey my prob is solve here
but flash bus not conect phone error
Old 09-26-2010, 12:47   #5 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
The Following User Says Thank You to kabul For This Useful Post:
Old 11-21-2010, 06:30   #6 (permalink)
Member: 731317
Thanks Meter: 5
my problem is same pls any body help me .i try to new setup 6 ver instaal but same prolem and driver not assept
Old 11-21-2010, 06:44   #7 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@all
Hi,,, check here:
1. Make sure to 100% remove all boxes (except ATF) from your USB PORT...
2. In Device Manager, make sure the Driver Version of your USB to Serial Converter A and
B are year 2009 or above versions. If it is below year 2009, then you need to
download this:
http://www.ftdichip.com/Drivers/CDM/CDM20808.zip
and update the drivers for USB to Serial Converter A and B
*** Restart PC after updating the drivers...
3. Go here --- > C:\AdvanceBox Turbo Flasher\Driver\MProg 3.5 Release\
4. Run "Mprog.exe"
5. Click "File" ---> "Open" then select "new abox turboflasher.ept" file
6. Click "Device" ---> "Erase"
7. Click "Device" ---> "Program"
After successfully Programming, close MPROG software and disconnect ATF Box from
PC for 5 seconds... Then reconnect it.
It will ask for drivers,,, select the correct one here:
C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS
B/R
X
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
Unlock all locks all phones *HERE* manfred GSM Mobile Links 0 02-19-2000 10:50
buy your GSM here midlandcellular Main Sales Section 0 09-04-1999 17:14
Page generated in 0.15287 seconds with 10 queries
