03-20-2013, 08:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: vadodara
Member: 1849215 Status: Offline Thanks Meter: 136 | atf box erro ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List after update shows error whts the problem i had tried all update firmware and restoracion but not solved plz help |
03-20-2013, 10:19 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Solution is here: Code: * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your BR |
03-20-2013, 11:39 | #6 (permalink) |
Member: 1849215 Status: Offline Thanks Meter: 136 | mine is [email protected] |
03-20-2013, 11:41 | #7 (permalink) |
Member: 1849215 Status: Offline Thanks Meter: 136 | here is log of updation...... Initializing Target Device... Reading Security... Performing Data Authentication.................................... .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ................. Programming UROW... Programming Array............................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ........ Verifying Array............................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ..........r Programming Rlock... Programming SILSIG... Advance-Box Secure AES-128 Channel Open Port Success... Exit code = 0... Status: Firmware Update was a Success! Elapsed time = 00:04:00 |
03-20-2013, 12:17 | #8 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | What is your problem ? Quote:
Br - srinibas | |
03-20-2013, 13:32 | #9 (permalink) |
Member: 1849215 Status: Offline Thanks Meter: 136 | done it with my way no need to knock any ones doors and sonork... we are not beggers and i told you supporter i dont have sonork and if you realy want to support then i had given you my yahoo id so.......... leave it thnx |
03-20-2013, 14:25 | #10 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Remember it ,here we dealing hundred of users per day No regards - srinibas | |
03-20-2013, 14:35 | #11 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | Quote:
wbr Dilip | |
