08-09-2013, 10:05 | #1 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Almoradi (ALICANTE) . SPAIN
Member: 1677266 Status: Offline Thanks Meter: 90 | atf box not wroking after firmware update <<< SOLVED >>> the box was working good but after updating the firmware is not working any more any help plz ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 10.3.70 Software Version : v10.00 AdvanceBox SN : 83********8 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Forcing Test Mode via BUSCHECK... Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed ERROR: FBUS Boot FAILED ================================================ Basic Phone Information ================================================ Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed Forcing Test Mode via BUSCHECK... Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed ERROR: FBUS Boot FAILED ================================================ Basic Phone Information ================================================ Changing MODE : FLASH Booting Phone via FBUS... BootFlashModeDCT5Ex Failed |
The Following User Says Thank You to Movileuropa For This Useful Post: |
08-09-2013, 15:38 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Which box you have ? If big box then you select wrong PCB type Check PCB type & update again Br - srinibas |
08-09-2013, 16:25 | #3 (permalink) | |
Member: 1677266 Status: Offline Thanks Meter: 90 | Quote:
thanks,it is the big box i try restore box after that i chose modified pcb and than update firmware,when software begin whit update it select automatically normal pcb. i can add you to my sonork and you see self | |
08-09-2013, 16:27 | #4 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Now update firmware with NORMAL PCB , Box will works Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
02-16-2014, 12:44 | #6 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1899876 Status: Offline Sonork: [email protected] Thanks Meter: 0 | Not to worry! Guyz simple! update your atf by v11.00 and an auto driver update appear and install it and open atf where u've installed and enjoy! the atf v11.00 search on google! |
