01-13-2013, 08:51 | #1 (permalink) |
Banned Join Date: Mar 2012 Location: BANGLADESH
Member: 1728755 Status: Offline Sonork: 100.1613242 Thanks Meter: 290 | ATF Box Problem My Atf light problem USB DEVICE NOT RECOGNIZED Not connet i will change USB cabal But same problem.. Look... [email protected] |
The Following User Says Thank You to Shopno jaker For This Useful Post: |
01-13-2013, 09:19 | #4 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | Dear remove atf drivers remove afte setup dell atf folder to program file install new setup 1st time install setup 9.20 and then update ' conect box insstall drivers u will b done |
01-13-2013, 09:47 | #7 (permalink) |
Member: 1728755 Status: Offline Sonork: 100.1613242 Thanks Meter: 290 | my atf light cable is broken i resold all wires then it work good but problem is cable even too shorter now i want to make cable large ... when i try put this wire error come usb device not recognised .. see here wire (orginal gpg cable cut for this ) when i put same orginal short cable of atf it not works Last edited by Shopno jaker; 01-13-2013 at 09:53. |
01-13-2013, 10:09 | #8 (permalink) | |
Insane Poster Join Date: Feb 2008 Location: khulna ,bangladesh Age: 51
Member: 699384 Status: Offline Thanks Meter: 44 | Quote:
just few minutes ago i solved by doing the following . 1. Remove ATF Drivers using this: 2. C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 3. Reconnect ATF Box to USB Port and install the Proper Drivers. All DONE ............................... | |
