Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 12-27-2012, 17:47   #1 (permalink)
prince_arsalan's Avatar
Member: 618626
Sonork: 100.1592779
ATF Box Problem <<< SOLVED >>>
Hi, I Am Having Problem With My Atf Box..
It Is Always Detected As ADVANCE BOX TURBO FLASHER A..
After Installing Drivers From C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS..
But When Open Atf Software.. Atf Box Is Not Detected..
I Tried To Repair Box With MProg 3.5 But When I Press Device Search Magnifying Key In MProg It Automatically Shuts Off.. And I Am Just Stucked With Non Working Atf, Please Need Urgent Help Regarding This Issue..
Old 12-28-2012, 07:16   #2 (permalink)
Member: 618626
Sonork: 100.1592779
Atf Team Waiting For Your Reply...
Old 12-28-2012, 07:53   #3 (permalink)
3cellcare's Avatar
Member: 1398631
Sonork: 100.1614508
tv id try this problem resolve
br
3cellcare
Old 12-28-2012, 10:40   #4 (permalink)
Member: 618626
Sonork: 100.1592779
br
3cellcare
Waiting For You On Sonork Then..
Old 12-28-2012, 10:57   #5 (permalink)
saleem5001's Avatar
Member: 1197620
Sonork: 100.1602278
i m also face this problem plz help me
http://forum.gsmhosting.com/vbb/f609...oblem-1589423/
The Following User Says Thank You to saleem5001 For This Useful Post:
Old 12-28-2012, 14:54   #6 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
This prolem is fixed with this drivers
ATF Official Windows 8/7/XP 32-bit/64-bit Signed USB Drivers
Polaco
The Following User Says Thank You to el-polaco For This Useful Post:
Old 12-28-2012, 16:30   #7 (permalink)
Member: 618626
Sonork: 100.1592779
Polaco
Tried Still Same Problem Box Is Not Detected By Atf Soft And Mprog Turns Off On Pressing Magnifying Key...
Old 12-28-2012, 16:41   #8 (permalink)
unlock.mk's Avatar
Member: 1671934
Sonork: 1612800
try to Deactivate theme in settings and restart application.
Old 12-28-2012, 16:48   #9 (permalink)
Member: 618626
Sonork: 100.1592779
Tried But Same..
Old 12-28-2012, 16:50   #10 (permalink)
Member: 618626
Sonork: 100.1592779
My Questions Are Why Atf Is Detected As ADVANCE BOX TURBO FLASHER A..
And Why MProg Is Not Able To Detect My Box..
Old 12-29-2012, 08:01   #11 (permalink)
Member: 618626
Sonork: 100.1592779
2 Days Passed And Not A Single Reply From Any Product Supporter Great Disappointment....
Old 12-29-2012, 08:16   #12 (permalink)
Advance-Box's Avatar
Member: 651945
pm me teamview id and pass...
Mprog is not by ATF. It is by FTDI.
If mprog exits when you try to scan,
then it could be driver problems.
Old 12-29-2012, 08:45   #13 (permalink)
Member: 618626
Sonork: 100.1592779
Team Viewer Id And Pass Sent Sir..
Old 12-29-2012, 09:30   #14 (permalink)
saleem5001's Avatar
Member: 1197620
Sonork: 100.1602278
i m w8ting this problem solve than post method i m also same problem
Old 12-29-2012, 10:13   #15 (permalink)
Member: 618626
Sonork: 100.1592779
Sir If You Are Too Busy To Solve The Problem Via Team Viewer Can You Please Post An Appropriate Solution Here So It Will Help Including Me All Other Atf Users Facing Similar Problem...
Because I have Tried Several Drivers Including Drivers In C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS And Drivers You Posted Here ATF Official Windows 8/7/XP 32-bit/64-bit Signed USB Drivers Every Time Removing Atf Drivers With Remove_ATF_Drivers.bat But Problem Still Remains Same Mprog Is Not Able To Detect My Atf Box With Any Driver Installed...
Page generated in 0.30700 seconds with 10 queries
