Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #16 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2010 Location: pakistan Age: 24
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks: 181
| Quote:
| | #17 (permalink) |
| why team u not reply here we r upset if me connect atf nitro than this box work but if me connect atf turbo than not why plz guide me |
| | #24 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2007
Member: 618626 Status: Offline Sonork: 100.1592779 Thanks: 12
| 5 Days Passed And Still Problem Not Solved Just Wondering If There Is No Solution For This Problem Or Atf Team Is Too Busy To Help A User.. |
| | #25 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2009 Location: CASTELLI - BS.AS - ARGENTINA
Member: 1057178 Status: Offline Sonork: UseGooGle Thanks: 252
| Please, Look This Pic If you are using old version Like a 9.10 or less, the Logicore for this version is differente for New Version. (10.3.30) After write the 10.3.30 Logicore Install Last ATF Version, Then Press Update. Unplug atf, restart PC, and check ATF Software.- Here a Guide in Pic http://www.4shared.com/photo/4ESpMbpQ/solution_1.html http://www.4shared.com/photo/XCQFlbtJ/b4post.html Fonts ThRead Error in my atf.. help me Good Luck and Happy New 2013 for All user and ATF Team Polaco |
| | #26 (permalink) | |
| Quote:
| | #27 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2008
Member: 674711 Status: Offline Thanks: 47
| bro this is not a problem install driver or give me you tv id i will install for u sohailhshaikh@gmail.com |
| | #28 (permalink) |
| Junior Member Join Date: Mar 2010
Member: 1271361 Status: Offline Thanks: 2
| it cant be driver problem,i have the same issue i installed all drivers on different os-s and different pc-s,i plugged in my atf box at 12.03 and is used it than i unplugged it and when i plugged it to the same pc at 16.05 than the software doesn't recongized it and in that time (12 t 16 )i even used the pc i just plugged and unplugged my atf turbo,so dont say it's driver problem,it isn't!!!!!!!(and even mprog doesnt recognized it and yes i used it with 9.40 and at 12.03 it worked with 9.40) |
| | #29 (permalink) | |
| Quote:
You must have your profile as hard and soft in that picture (screenshot) Some cases, the device does not appear ATF within the program and is solved by the skin changed. - Observe LogiCORE versions, Respect atf driver version. With all operating systems, you must indicate that drivers need FTD (path), and it is very important to use the own ATF . Pay attention, in the bottom right (next to the speaker of windows) not have 2 icons ATF. There must be that icon when ATF program is closed, and there should be two icons when ATF is open.(something wrong) Dont use Mprog, No eep Error from ATF!! A simple guide, for simple error ![]() I apologize for writing a horrible English. is what you get .... A Tips for 2013.....Dont use Anti virus in a pc unlocker...make many OS in the same partition HDD, and Enjoy Windows XP x3 and 7Br Last edited by el-polaco; 01-01-2013 at 16:21. | |
| | #30 (permalink) | |
| Quote:
Code: 14:12:37 : ================================================ 14:12:37 : Advance Turbo Flasher Found 14:12:37 : ================================================ 14:12:37 : Driver Version : 00020824 14:12:37 : Library Version : 00030207 14:12:39 : Box Type : AdvanceBox Turbo 14:12:39 : Box Firmware : LogiCore 10.3.30 14:12:39 : Software Version : v9.40 14:12:39 : AdvanceBox SN : F8A320C38E11F6E8E2E0742C 14:12:39 : Box Status : ACTIVATED 14:12:39 : ================================================ 14:12:39 : Box Successfully Initialized 14:12:39 : ================================================ 14:12:39 : 14:12:39 : VBATT Powering Down <<<< 14:12:43 : VBATT Powering Up >>>> 14:12:43 : SET VCCIO Level Done 14:12:43 : SET BSI Load Done ![]() ![]() And About Drivers And Disabling Theme These Are All The Things Which I Have Already Tried But Not Solving The Problem... And Your English Is Not Bad.. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
