03-03-2013, 23:18 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | ATF box question I want to buy ATF box and decide what select, need the best of I found next: 1. ATF full Advance Turbo Flasher (ATF Box) 2. ATF Nitro Advance Turbo Flasher (ATF Box) Nitro Nokia flash, unlock, repair box 3. ATF Lighting Advance Turbo Flasher Lighting (ATF Box) Nokia flashing and unlocking software tool (do i need it?) So: a. what box has more functionality? (need max nokia support and Lumia repair/unlock) b. for what 2 RJ connectors on ATF full ? c. how many connectors in Nitr (i dont see on picture)? d. what cable are compatible (UFS, JAF, MTbox, Cyclone)? e. what select for Lumia unlock/repair? f. what max microSD capacity supported for password remove g. any other advice Hope on help from all with AT experience Thanx Last edited by SVH; 03-03-2013 at 23:28. |
03-04-2013, 01:58 | #2 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | a: Yes b: 1 for Nokia Based and other Infineon based c: i dont know d: compatible JAF/ufs e: Is suppoted, check 9.61 latest upgrade f: i dont know, you need lbf for attak Both are good, because 98% of sulution is by USB Only Big Metal have a SD reader. Best Regards Polaco |
03-04-2013, 07:30 | #7 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
1 - Chrome ( Without Network activation & with Micro SD card unlocker slot ) 2 - Lighting ( Without Network activation & without Micro SD card unlocker slot ) 3 - Nitro ( With Network activation & without Micro SD card unlocker slot ) Answer a - About main functionality all box are same ( Network activated box are more powerful ) b - 2 port as FLASH BUS & EXTENSION , Infinion Fbus need to connect on EXTENSION , others Fbus on FLASH BUS c - Nitro / Lighting have one port for all d - UFS / JAF cable e - Cant understand your question ( Probably answer is - Two type of unlock we support for Lumia , TP & Direct ) f - Personally i have test with 32 GB . g - ?????????????? Br - srinibas | |
03-05-2013, 10:10 | #8 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | bought ATF Nitro and have some questions: 1. in set i have just box, no USB cable. What should be in ATF Nitro set? 2. there are any free credits with new Nitro? 3. is possible to check iPhone carrier via imei and how much it costs Thanx |
03-05-2013, 10:22 | #9 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
1. Only box, without cable, you can use any Nokia CA-01 USB cable in order to connect the BOX with PC 2. ATF Nitro are pre-activated boxes for the ATF Network, no free credits with new box. 3. iPhone carrier check is down with ATF Box for now... BR | |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
