07-11-2014, 15:33 | #1 (permalink) |
Freak Poster Join Date: Apr 2012
Member: 1751722 Status: Offline Thanks Meter: 19 | ATF BUG in 11.45 520/620 flash error but flash ok with 11.10v i found this error whilke treying to flash many 520 and 620 lumia phones with latest atf exe than i tried same phone with 11.10v flash ok here is log... v11.45 gives error ERROR: Flash File ROOT_KEY_HASH Mismatch! This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! V11.10 ok Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== IMEI: 35************* Version: 1.1.1.3 Product Code: 059S1N6 Module Code: 0205435 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P6036.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011C00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.28 Query ROOT KEY HASH... ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:02:26 |
The Following User Says Thank You to .::GSMUnlock::. For This Useful Post: |
