03-09-2011, 07:31 | #1 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1415427 Status: Offline Thanks Meter: 2 | ATF cannot fix for upgrading from v21.003 to v30.033 (N96) Yesterday, I use ATF 6.5 to upgrade my N96 firmware from v20.050 to v30.033, it has no problem after upgraded, the phone working fine. (and I have backed-up full pm , rpl , sim lock certification, etc...) Then, downgrade to v21.003, and use "Easy Fix" -> "Quick fix SL1/SL2 downgrade...." option to fix downgrade problems, after fixing completed, the phone also working fine on v21.003. But, when I try upgrade from v21.003 to v30.033, ATF flush v30.033 firmware successfully, but failed at "Reading MCU Version" after flushing. N96 now became white-screen and auto-reboot again and again. When trying "FBUS Check", ATF can complete the FBUS Check procedure, and the logs shows that ATF can find out this is the SL1/SL2 phone, but the phone cannot go into the Local Mode / Test Mode / Normal Mode, N96 just keeps white-screen and auto-reboot. (At this moment, I can write the backup RPL success, but failed to write full pm with sx4, because before writing full pm with sx4, ATF will do a "Reading MCU Version", and this operation always failed!) (In fact, I can write backup RPL success at any time, even when IMEI became 123456789123..., but ATF always failed to write pm 308 though sx4 authorization success!!) As for the phone could not start-up when upgrade from v21.003 to v30.033, so, I downgrade it to v21.003 again, and N96 come back to normal and working again. Why I cannot upgrade from v21.003 to v30.033, why I can upgrade from v20.050 to v30.033 ?? Why must be v21.033 ?? Why cannot write pm 308 when sx4 success ?? Now all I want is to upgrade N96 to v30.033 (I have all firmware files with all product code on my computer), please help me / guide me with a step-by-step procedure by using ATF. Million Thanks. |
03-09-2011, 09:10 | #2 (permalink) |
Member: 1415427 Status: Offline Thanks Meter: 2 | Suddenly, I think I may find out the root cause, When flushing from v21.003 to v30.033, I have chosen a different product code firmware of v30.033, maybe I should use the firmware as the same as the one when downgrading from v30.033 to v21.003. Maybe I am wrong, but I will do it a try later today. If it is the root cause, then I will have another question for asking : Why does it cannot use different product code firmware of the same firmware version ?? |
03-09-2011, 09:21 | #3 (permalink) |
Member: 1415427 Status: Offline Thanks Meter: 2 | Another solution for giving a try is to change the product code before any version flushing ??? I never change the product code before flushing though I known the product code is different. ??? |
03-09-2011, 10:28 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hello. Post logs please,, of all your operation. |
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post: |
03-09-2011, 19:27 | #8 (permalink) | |
Member: 1415427 Status: Offline Thanks Meter: 2 | Below logs operation : 1. Upgraded to v30.033, then "Quick Fix SL1/SL2 Downgrade". 2. FBUS CHECK 3. Scan Phone 4. SD Check Quote:
03-09-2011, 19:30 | #9 (permalink) | |
Member: 1415427 Status: Offline Thanks Meter: 2 | Then write Full PM : Quote:
03-09-2011, 19:32 | #10 (permalink) | |
Member: 1415427 Status: Offline Thanks Meter: 2 | Then write Good Backup RPL : Quote:
03-09-2011, 19:35 | #11 (permalink) | |
Member: 1415427 Status: Offline Thanks Meter: 2 | Now, following operation : 1. FBUS Check 2. Scan Phone Quote:
03-09-2011, 19:37 | #12 (permalink) |
Member: 1415427 Status: Offline Thanks Meter: 2 | That is all, N96 will not go into Local Mode / Test Mode / Normal Mode now, it just keeps white-screen and reboot again and again. What is the problem ? What to do now ? Thanks. |
03-09-2011, 20:17 | #13 (permalink) |
Member: 1415427 Status: Offline Thanks Meter: 2 | If I downgrade it back to v21.003, IMEI will back to normal automatically (Don't need to write backup RPL) and phone will working again, but I don't want to back to v21.003, I just want v30.033 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
