01-21-2015, 16:12 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | ATF can't read mcu from nokia 106 Code: Detected Phone Type: RM-962 MCU File Saved: C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-962\rm962_03.100 PPM File Saved: C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-962\rm962_03.10ic CNT File Saved: C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-962\rm962_nai03.10ic VPL File Saved: C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-962\RM962_059T2H2_03.10_001.vpl Performing Final File Checks... ERROR: MCU File is Incomplete! Deleting MCU File... PPM File is OK... CNT File is OK... Flash Files Dump Success! Total Time: 00:02:06 |
02-04-2015, 19:44 | #2 (permalink) |
Freak Poster Join Date: May 2007 Age: 25
Member: 503942 Status: Offline Thanks Meter: 61 | This is not a bug. You just can't read flash via fbus cable from most Nokia 105/106. If you want read flash from your phone, disassebly your mobile, desolder metal frame near battery connector and use special SPI-adapter to read full flash ( or solder 8wires directly to flash IC). After that you can write this "backup" to new phone with simlock + imei preservation. |
02-04-2015, 20:12 | #3 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | thank you for the valuable infos,can anyone provide pinout for this operation ? will I need other component other than ATF ? thank you |
02-04-2015, 20:37 | #5 (permalink) |
Member: 503942 Status: Offline Thanks Meter: 61 | I've use this one. Work's perfectly with ATF. http://forum.gsmhosting.com/vbb/f609...106-a-1827975/ SPI pinout you can find inside SPI folder in your ATF installation folder on your HDD. Last edited by suchywilk; 02-04-2015 at 20:42. |
02-06-2015, 21:19 | #7 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | I found pinout in other thread ,just one question should I just solder VDD pin to pin2 of rj45 then set software to 3.30v or should I connect VDD to 3.30v external power ? |
02-07-2015, 00:06 | #8 (permalink) |
Insane Poster Join Date: Nov 2008
Member: 911152 Status: Offline Thanks Meter: 4 | If i understand correctly, what it says is that to pull 3.30V from the ATF pin 2, the nitro box needs to be modified. So my idea is: - if you have an ATF nitro, use an external PSU set to 3.30V - if you have an ATF Chrome/big, use the RJ45 PIN 2 and set ATF software to 3.30V as the chrome box doesn't need hardware modding to work at 3.30 |
