04-07-2014, 11:26 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | ATF chrome box activation problem...please help... Actually I bought 1 year back i think, now i try to activate this showing contact Distributor/Reseller, but i dont know who the resseller this box i forgetted, i have one more nitro it will fully activated its working fine. so i forgetted activate this box, now i want to activate this box. is it possible? or i must buy activation? AdvanceBox SN : E64BC0AAC4ADC8A3D9543722 Your Box Distributor/Reseller has requested that your Box should be Disabled. Please Contact your Box Distributor/Reseller and settle the Problem. If you think you are getting this Message by Mistake, please visit ATF Support: http://forum.gsmhosting.com/vbb/f609/ BR, Srinivas Reddy. |
04-07-2014, 11:29 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, download and install new ATF software v11.20, connect box to USB Port and open AdvanceBox.exe. After make screen shot or copy/paste entire logs here BR |
04-08-2014, 18:53 | #7 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @swechacnu Post picture of your Box Sticker BAR CODE on the bottom of the casing. This problem can be caused by mismatching serial number on sticker. I can solve this for you, but I need to see actual sticker first so I can trace it easier. B.R. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
04-09-2014, 09:13 | #8 (permalink) |
Insane Poster Join Date: Apr 2012
Member: 1743429 Status: Offline Sonork: 100.1653461 Thanks Meter: 9 | My box is a similar problem. any solution for me. Version 11:00 So far I can not use. sonork : 100.1653461 Last edited by vinhkiengiang; 04-09-2014 at 09:23. |
04-09-2014, 09:15 | #9 (permalink) | ||
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Quote:
Here is the scrrenshot but its totally gone not showing bar code or serial number. Quote:
Code: 17:19:56 : ================================================ 17:19:56 : Advance Turbo Flasher Found 17:19:56 : ================================================ 17:19:56 : Driver Version : 00020830 17:19:56 : Library Version : 00030207 17:19:58 : Box Type : AdvanceBox Turbo 17:19:58 : Box Firmware : LogiCore 11.0.00 17:19:58 : Software Version : v11.20 17:19:58 : AdvanceBox SN : E64BC0AAC4ADC8A3D9543722 17:19:58 : Box Status : NOT ACTIVATED 17:19:58 : 17:19:58 : ================================================ 17:19:58 : Please Activate your Box 17:19:58 : ================================================ 17:19:58 : 17:19:58 : * Follow these Instructions 17:19:58 : 1. Disconnect any phones connected to ATF Box 17:19:58 : 2. Go to "Product Support Tab" 17:19:58 : 3. Go to "Box Tools" Section 17:19:58 : 4. Fill in the Required Information 17:19:58 : 5. Click "Activate Box" button 17:19:58 : 17:19:58 : ================================================ 17:19:58 : Box Successfully Initialized 17:19:58 : ================================================ 17:19:58 : Srinivas Reddy. | ||
04-09-2014, 10:23 | #13 (permalink) | |
Member: 1743429 Status: Offline Sonork: 100.1653461 Thanks Meter: 9 | Quote:
log: PHP Code: Last edited by vinhkiengiang; 04-09-2014 at 10:30. | |
