12-02-2013, 18:44 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sudan
Member: 281857 Status: Offline Thanks Meter: 214 | ATF dead after jtag activation .. ?? - SOLVED (SOLUTION INSIDE) and not connected i checked drivers and found it appears like attached .. how to fix this |
12-02-2013, 19:33 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Sudan-Mobiles 1. Install Drivers for Dual Rs232 HS... Get it here: http://www.ftdichip.com/Drivers/CDM/...0Certified.zip 2. Disconnect ALL GSM Boxes from USB Port including ATF BOX. 3. Run ATF Software 4. Connect ATF BOX to USB PORT 5. Goto "Product Support" ---> "Box Tools" ----> click "Restore EEPROM" 6. After it finishes, disconnect ATF BOX from USB Port 7. Connect ATF BOX to USB port and Install ATF BOX drivers here: C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS\ 8. Force Windows to use Drivers from #7... otherwise you will have BIG problems. 9. Close ATF Software, then run ATF JTAG Software 1.0.4 or above... This will auto activate your Box if you have internet connection and 39 credits. B.R. |
12-02-2013, 21:42 | #4 (permalink) | |
Member: 281857 Status: Offline Thanks Meter: 214 | Quote:
thanx its works | |
