05-19-2015, 12:21 | #1 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | ATF DRIVE v12.31 Update!! Public Discussion Thread: May 22, 2015 1. You Need to click "Check For Updates" then get ATF 12.31 2. Run ATF 12.31, then click "UPDATE IMPORTANT FILES" eMMC Tool 3.2 (PRO) ---> Fixed UAC Problems for ATF DRIVE 32/64-BIT "Mount Drive Failed!" ---> Added "Direct ATF BIG Box Connection (3.25V on PIN 2)" in CPU Type. Now you can use again your home eMMC Adapters with ATF BIG BOXES ================================= Release Date: May 19, 2015 Firmware Version Required : 11.0.10 or 11.0.12 ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit) ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit) ATF Plus eMMC Tool 4.0 (PRO) Introducing ATF Drive !!! 100% FREE FOR ALL ATF BOX USERS D.R.I.V.E. = Data Recovery Interface Via EMMC First In the World Solution that will MOUNT eMMC Partitions as a Windows Removable Disk! Now you can Recover Data from a Dead Phone by Simply using Windows Explorer "Search" and "Copy + Paste". Special Features: --> Supports Windows XP, Vista, 7, 8.0 and 8.1 (All 32-Bit and 64-Bit Versions) --> You can load Partitions via Direct ISP eMMC Connection (4 wires + Vcc/VccQ) or via eMMC Binary Dumps --> Supports FAT12, FAT16, FAT32, exFAT, NTFS Windows Phone Partitions --> Supports EXT2, EXT3 and EXT4 Android Partitions (1) --> You can READ + WRITE to Mounted Partitions as if they were USB Drives on your PC! (2) --> Supports Recovery of Windows Phone 8.0/8.1/10 DATA Partition EVEN if MBR, GPT and BOOTLOADERS are ERASED! --> Faster READ/WRITE Speeds when compared with other Products --> Supports MBR + GPT Partitions of Android and Windows Phones Video Demonstration on Lumia WP8 Phone Here: http://forum.gsmhosting.com/vbb/f609...phone-1949888/ Video Demonstration on Android Phone Here: http://forum.gsmhosting.com/vbb/f609...phone-1949890/ (1) : EXT2, EXT3 and EXT4 Support Requires Additional Installation of a FREE Software Paragon EXTFS which can be downloaded here: https://www.paragon-software.com/home/extfs-windows/ (2) : WRITE Operations on EXT2, EXT3 and EXT4 are not Supported by FREE Software Paragon EXTFS. If you want to WRITE to Android/Linux Partitions, you can still do so "AT YOUR OWN RISK" via using another FREE Software named Ext2Explore. More Information here: Ext2Read download | SourceForge.net ---> Added "Samsung eMMC Write CID" Function for writing Custom CID to Samsung eMMCs Lumia 8.0 + 8.1 BOOT RECOVERY via USB --> Windows Phone 8.0/8.1/10 Flasher now has an improved BUILT-IN BOOT REPAIR Function via USB. --> If your WP Phone is TOTALLY DEAD or HALF DEAD or TOTALLY ALIVE, ATF WILL FLASH it via USB ONLY! (3) Added Support for 40 New Lumia 8.1 Phones RM-1068 : Lumia 435 DS RM-1069 : Lumia 435 DS RM-1070 : Lumia 435 RM-1071 : Lumia 435 RM-1114 : Lumia 435 DS RM-1017 : Lumia 530 RM-1018 : Lumia 530 RM-1019 : Lumia 530 DS RM-1020 : Lumia 530 DS RM-1031 : Lumia 532 DS RM-1032 : Lumia 532 DS RM-1034 : Lumia 532 RM-1115 : Lumia 532 DS RM-1089 : Lumia 535 RM-1090 : Lumia 535 DS RM-1091 : Lumia 535 RM-1092 : Lumia 535 DS RM-976 : Lumia 630 RM-977 : Lumia 630 RM-978 : Lumia 630 DS RM-979 : Lumia 630 DS RM-974 : Lumia 635 RM-975 : Lumia 635 RM-1027 : Lumia 636 4G RM-1010 : Lumia 638 4G RM-1040 : Lumia 730 DS RM-1038 : Lumia 735 RM-1039 : Lumia 735 RM-1078 : Lumia 735 RM-983 : Lumia 830 RM-984 : Lumia 830 RM-985 : Lumia 830 RM-1049 : Lumia 830 RM-927 : Lumia Icon/929 RM-1045 : Lumia 930 RM-1087 : Lumia 930 RM-937 : Lumia 1520 RM-938 : Lumia 1520 RM-939 : Lumia 1520 RM-940 : Lumia 1520 Refreshed Support for 28 Old Lumia 8.0 Phones (Now uses loaders based on RM-xxx Type) RM-820 : Lumia 920 RM-821 : Lumia 920 RM-822 : Lumia 920 RM-824 : Lumia 820 RM-825 : Lumia 820 RM-846 : Lumia 620 RM-860 : Lumia 928 RM-867 : Lumia 920T RM-875 : Lumia 1020 RM-876 : Lumia 1020 RM-877 : Lumia 1020 RM-885 : Lumia 720 RM-887 : Lumia 720T RM-892 : Lumia 925 RM-893 : Lumia 925 RM-910 : Lumia 925 RM-913 : Lumia 520T RM-914 : Lumia 520 RM-915 : Lumia 520 RM-917 : Lumia 521 RM-941 : Lumia 625 RM-942 : Lumia 625 RM-955 : Lumia 925T RM-994 : Lumia 1320 RM-995 : Lumia 1320 RM-996 : Lumia 1320 RM-997 : Lumia 526 RM-998 : Lumia 525 (3) : Not all Phones can be Repaired via USB Cable Only. Some Phones might have a buggy eMMC Inside which requires Direct EMMC Connection or JTAG to Repair. BUG FIXES: 1. Fixed Bug on Nokia X2 (Android) Flashing/Boot Repair Added New Lumia Models to Nokia.ini --> Lumia 540 Dual SIM (RM-1140) --> Lumia 540 Dual SIM (RM-1141) *** WARNING *** Starting ATF 12.30, "Skip Flash File Checksum Verification Before Flashing" is now SELECTED in "Settings" ---> "Nokia Settings". This allows FASTER LUMIA Flashing Procedure on Slower PCs. However, your Phone might DIE if your FFU File is Corrupted. Anyway, you can still repair the phone via USB Cable after your have Downloaded a NON-CORRUPTED FFU File. Who will buy this if you can get more in ATF? __________________________________________________ ________________________ Buy only from ATF [Advance Turbo Flasher] authorized resellers: ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List ATF [Advance Turbo Flasher] official web sites: International - http://www.advance-box.com/ ATF [Advance Turbo Flasher] official support forums: World Wide: Advance Turbo Flasher - GSM-Forum Indonesia: ATF (Advance Turbo Flasher)) Philippine: Gsmph Syria: Arabic Support (Syria) GsmVIP Chinese support forum : ATF Box Vietnam: Saigonmobile India: Advance Box - .:: GsmIndia ::. Official Iran Support Forum : ASANGSM FORUM Bangladesh: Advance Box - Dhaka Mobile Chinese Support forum : www.yananliuhuan.com The Master Piece Last edited by Advance-Box; 05-22-2015 at 15:37. |
The Following 19 Users Say Thank You to gsmfun For This Useful Post: |
05-19-2015, 13:35 | #3 (permalink) |
Junior Member Join Date: May 2015
Member: 2388409 Status: Offline Thanks Meter: 0 | lumia 630 RM 978 repair boot error If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ================================================== ==== Recovery Handle Found! - (WinUSB) PBL Emergency Download Detected Start Sending Firehose Loader... Firehose Loader Sent! Executing Firehose Loader... Start Processing Firehose Payload... MSG_SIGNATURE Sent.... ERROR: error code= 1 value= HW_INIT:init storage:fail ERROR: Flashing Failed! |
05-19-2015, 13:43 | #4 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Look at error code. Means probable emmc problem. Check phone pcb, probably just needs rework. | |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
05-19-2015, 13:55 | #5 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Turkey
Member: 1169259 Status: Offline Sonork: 100.1648194 Thanks Meter: 149 | Samsung eMMC Write CID why this option i need more info please ? Someone requested this option since some MTK phones check the emmc type. So now you can clone CID of other emmc and make phone think it is the required emmc. Last edited by Advance-Box; 05-19-2015 at 14:02. |
05-19-2015, 17:52 | #9 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote:
You try download from here ATF_v12.30_Full_Installer.rar But why don't have patience to enter captcha ., that would take 20 sec ., | |
The Following 4 Users Say Thank You to Smart-gsm For This Useful Post: |
05-19-2015, 18:50 | #11 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Tadjikistan, Dushanbe Age: 35
Member: 1533366 Status: Offline Thanks Meter: 131 | big boom update sir thx all atf team !!! i think if you add samsung tool i'm buy 1st in customers D.R.I.V.E. = Data Recovery Interface Via EMMC )))))) cool name |
05-19-2015, 19:19 | #12 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Not use at the moment "Autoupdate" button, leave this UNcecked, will be solved soon i think. BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
